| NY / NJ / CT / PA NY, NJ, CT, PA |
Drives: 2013 Scion FR-S (Hot Lava)
Advice on running catless
Is anyone able to provide input on running a catless (i.e., Borla UEL) header? The sound is absolutely beastly. The only thing stopping me is the whole 'cars must have a cat converter' law, which carries pretty monstrous penalties in NY if you're not track-exclusive. I've read and seen plenty of setups from the area that run that header.. is there away around the legal troubles?
Thanks guys. |
#2 |
Drives: 2013 Subaru BRZ
Had a Berk test pipe on my S2000 and when it came time for inspection I just swapped the cat back on the week I was going to go in. Also cleaned the spot that developed from soot on the bumper
![]() This was in NJ
#3 |
Thanks dude. Isn't a header a little harder to swap out, though? What about these rumored 'spot inspections' for getting pulled over? Have never seen one, only heard..
#4 | |
SLO NO MO
If you don't care about legality, then perhaps if you have a tune that won't throw any O2 errors and a smog inspection that only checks for OBD2 readiness and no visual, you'd be ok in theory. Header removal/installation can be a bit of a job, but fortunately you'd only need to worry about it once a year. I'm not aware of any spot inspections in New York. Where'd you hear that? |
| The Following User Says Thank You to Foobar For This Useful Post: | iamdaspoon (11-14-2013) |
#5 |
The legality of it isn't such an issue as long as I won't be facing thousands of dollars in fines if caught. I see a ton of people running catless headers, and I was wondering if they know something I don't about how passing inspection works in NY. I don't have a lift, but I have a full shop of tools. Is that enough to replace the header once a year for inspection?
I haven't "heard" of spot inspections in NY, only in general. I guess that answers that question. The only fear I'd have, I guess, is being pulled over for the sheer noise level and being questioned on it. |
#6 |
The header and exhaust were legal, it was only the test pipe that made the car illegal, inspection wise. Pop the cat back on between the header and the exhaust and you're good to go.
| Borla Catless Midpipe? | Vegas Racing | Engine, Exhaust, Transmission | 38 | 02-23-2016 11:02 AM |
| Anyone Running Full Catless w/Muffler Delete? | djliquidsteele | Engine, Exhaust, Transmission | 32 | 08-30-2013 02:39 AM |
| Catless Vs HFC? | Koolkiid | Engine, Exhaust, Transmission | 14 | 05-28-2013 09:03 AM |
| Invidia Catless front pipe NEW | Area51 | Engine, Exhaust, Bolt-Ons | 1 | 05-21-2013 02:54 AM |
| SRT header back exhaust catless w/ tip A | serial gixxer | Engine, Exhaust, Bolt-Ons | 6 | 12-05-2012 12:00 AM |
