Old 05-31-2013, 03:19 PM   #1
Calum
That Guy
Drives: 2013 asphalt FRS MT
Oil cooler idea
I've been watching all of these oil coolers coming out and i keep wondering why we only see kits that I find to be overly complicated. The oil circuit is a system that I think should be kept as short and simple as possible in order to keep possible failures to a minimum.
So, in that vane, has anyone put any thought into something like these?
http://www.lxforums.com/board/f77/mo...3/#post4369805
http://forums.corral.net/forums/5-0-...oler-help.html
http://www.fordracingparts.com/parts...KeyField=12905
If we could adapt it to the oil filter, I think putting it in series with the heater core would be pretty easy. This would keep the coolant flow constant even if the thermostat is closed, it would self regulate the oil temperature, and should be fairly easy to plump to the coolant side.
Any thoughts?
Old 05-31-2013, 04:28 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Robi's setup does something similar, except using the radiator to provide both water and some air cooling to the oil.
Those OEM style systems in general I haven't found to be super helpful, my ITR still hits close to 300 degrees oil temps on the track with one. :shrug: The cooling is happening from the water coolant, but the housing gets heatsoaked and the oil isn't there long enough to cool much.
If I werent going for a separate cooler, I'd run Robi's setup instead.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Calum (05-31-2013)
Old 05-31-2013, 05:39 PM   #3
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
It's another option, but honestly to me your just trading complexity in one system of complexity in another.
The Following User Says Thank You to neutron256 For This Useful Post:
mad_sb (05-31-2013)
Old 05-31-2013, 06:17 PM   #4
mad_sb
Drives: 2013 Asphalt FR-S
^this
plus someone already makes it for our cars, HKS or greddy i think. The Robispec route is the best idea IMO as it addresses both oil and coolant cooling capacity with a single solution.
Old 05-31-2013, 06:43 PM   #5
Calum
That Guy
Originally Posted by mad_sb View Post
^this
True Robi's rad looks great. But the fbm rad plus one of those above could be a few hundred cheaper. Also, having complexity and possible failures in the coolant system is a lot easier to recover from.
Sent from mission control
Old 05-31-2013, 07:08 PM   #6
wootwoot
Drives: FRS
I have been trying to figure this out for a while now. I think we are better off trying to get a stand alone heat exchanger and using a sandwich plate with a built in thermostat. The issue I am having right now is that, as I understand it, the upper passenger side of the radiator is the hot side where we want to plumb in the heat exchanger. There is not much room there to put a heat exchanger in, meaning some serious plumbing is involved and/or the use of a very small heat exchanger. Still working on it...
The Following User Says Thank You to wootwoot For This Useful Post:
Calum (05-31-2013)
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler Idea wootwoot Engine, Exhaust, Transmission 1 04-08-2013 10:25 AM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
