Old 05-31-2013, 12:36 AM   #1
DarthThinmints
DarthThinmints's Avatar
Drives: scion fr-s raven
FR-S / BRZ Big 3" Cat Back Exhaust
http://www.perrinperformance.com/brz...t-back-exhaust
Does anyone have any sound clips for this exhaust yet?
Pros/Cons?
DarthThinmints is offline   Reply With Quote
Old 05-31-2013, 02:27 AM   #2
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
You're going to have to move A LOT of air to need that much exhale... and I mean A LOT for this car.
FT-86 SpeedFactory is offline   Reply With Quote
Old 05-31-2013, 08:10 AM   #3
FR-S Matt
I don't think it will be a problem with a tune and header. 3" exhausts are just heavier and work well with turbo applications. You shouldn't have a problem with a 3" NA + a header and tune. You might see some low end loss at real low rpms on a stock tune due to the size, but I'm talking an entire full 3" system. The 3" catback alone won't make a difference from the 2.5". 3" systems also are louder, but even the resonated Perrin is still fairly quiet in my book. Sounds a bit more throaty with the 3" though.
My 3" Nameless axleback doesn't do anything different from the 2.5" because the front half of my exhaust is stock. I just want the 3" in place for when I do get the rest of the 3" portions of the exhaust.
Old 05-31-2013, 08:29 AM   #4
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
With NA and 3" exhaust on this car you will LOSE power. FA20Club built a full 3" system and it lost substantial power. If you go turbo then it will help out but until then don't waste your money.
chadstyle is offline   Reply With Quote
Old 05-31-2013, 08:42 AM   #5
Gardus@Supersprint
Drives: Clio TCE
76mm on a 200 hp NA car? It will kill the power delivery.
We usually use 76 on cars with well over 300 hp.
65-70mm is enough for 2.0l turbo car under 300 hp.
Gardus@Supersprint is offline   Reply With Quote
The Following 3 Users Say Thank You to Gardus@Supersprint For This Useful Post:
meeks (06-05-2013), ngabdala (05-31-2013), Sportsguy83 (06-01-2013)
Old 05-31-2013, 08:51 AM   #6
FR-S Matt
Do you have a link to that?
I'd like to see more info on where it kills power. I was considering going 3" to be a placeholder for a bit before I went turbo. If that's the case, I may go 2.5" in front then.
Possible dyno charts?
Old 06-01-2013, 12:01 AM   #7
DarthThinmints
Dyno charts would be awesome(:
Old 06-01-2013, 12:03 AM   #8
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
^ Been waiting for this info. I will go for the smaller version since buying turbo will take a really long time. But thanks guys. Would still want to see dyno charts of the power loss on a fully stock car..
Marcoscrdo is offline   Reply With Quote
Old 06-01-2013, 12:27 AM   #9
frslee
Just drive it
Drives: 13' FR-S
3" exhaust for this small engine? Even Audi S4 V8 guys run 2.5 and 2.25 at the end.
frslee is offline   Reply With Quote
Old 06-01-2013, 11:25 AM   #10
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
http://www.ft86club.com/forums/showthread.php?t=37542 - Install Thread
[ame="http://www.youtube.com/watch?v=gI1fRwlLI_c"]NWMotiv - Project BRZ - Perrin 3" Exhaust - YouTube[/ame] - Sound clips
Pros:
Room for growth in terms of HP if you decide to go F/I
Louder(if you like that)
Cons:
Louder(if you dont like that)
Less clearance
Heavier
That's the basics of it. Like others have stated, I would suggest a 2.5 exhaust if you plan on staying with bolt ons. If you go F/I 3" hands down is the way to go.
Also, engine size has no bearing on what exhaust size you should run. Its all about power and moving the air out as fast as possible.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 06-01-2013, 12:02 PM   #11
jamesm
i don't know much about n/a tuning cars (i'm a turbo guy), but i grew up around motorcycle racing and used to tune race bikes for a living. in that arena, it's generally accepted that the higher compression, the more flow you can afford on the exhaust side without losing midrange. of course there's a lot more that goes into building a 1000cc engine to 220whp, but that's a basic principle a lot of people agree with.
you see this in cars as well. k-series honda motors are relatively high compression and see gains with 3" exhaust over 2.5". i'd imagine the same holds true for our even higher compression engines.
in the end, gains from any catback will be negligible, so it's probably a moot point. if you're going turbo, get the 3", if not, get what you thinks sounds good and fits the budget.
Old 06-01-2013, 12:40 PM   #12
Surfacer
Aearonjer Circumstance
Drives: none
I've been told that it does. To do with back pressure?
Surfacer is offline   Reply With Quote
Old 06-01-2013, 12:46 PM   #13
Tansey86
Tansey86's Avatar
Well a naturally aspirated car wants back pressure. A turbo car does not want any back pressure.
That being said, its not the engine size that's making the difference so much as if its all motor or it has some sort of boost application.
Old 06-01-2013, 04:23 PM   #14
FR-S Matt
Until someone proves otherwise, I don't see a problem running 3" N/A on this engine, especially if you plan on doing FI in the future.
PTUNING FR-S/BRZ DS-325 3" Dual Cat Back Exhaust System ... Coming Soon!! Mrc@ptuning Engine, Exhaust, Bolt-Ons 246 04-06-2014 12:52 PM
AVO 2.5" Cat Back Exhaust New In Box JMPoole Engine, Exhaust, Bolt-Ons 8 05-11-2013 09:54 AM
Long "Scion" sticker on back bumper CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 7 04-12-2013 10:31 AM
PTUNING FR-S/BRZ DS-325 3" Single and Dual Cat-Back Exhaust System. Group Buy!! Mrc@ptuning Engine, Exhaust, Bolt-Ons 35 12-10-2012 11:55 AM
My Wife Found a New "Cat Back" Exhaust Toyota86Fan Other Vehicles & General Automotive Discussions 6 10-15-2012 08:17 PM
