Old 05-30-2013, 07:04 PM   #99
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by lbroskee View Post
1. the vent is cool but can it be turned like OEM
(yes i know that means a turned gauge)
I'm curious as well.
No biggie if it doesn't.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
Old 05-30-2013, 07:04 PM   #100
cb7tuner
Drives: 2013 whiteout FR-S
A sensor was not added for the EGT, I'm assuming it gets its readings from the heaters on the O2 sensors but I'm not sure. And yes the richest the AFR has show for me is 11.1 so I think that's as rich as it will read from the stock sensors
cb7tuner is offline
Old 05-30-2013, 07:06 PM   #101
cb7tuner
Yes it can, as long as you leave enough slack for the ribbon cable to move depending on how and where you secure the black box (brains of the gauge).
cb7tuner is offline
The Following 3 Users Say Thank You to cb7tuner For This Useful Post:
Floggin Tires (05-30-2013), lbroskee (05-30-2013), RedAlert (05-30-2013)
Old 05-30-2013, 07:20 PM   #102
jamesm
Awesome. When can I buy it and who do I send the money to? Now now now lol
jamesm is offline
Old 05-30-2013, 08:01 PM   #103
troek
troek's Avatar
Drives: 2012 Toyota 86
so it uses the stock gauge outer ring? so this could be mountined in an RHD car just fine then? i have an RHD 86 if you need for beta testing....
troek is offline
Old 05-30-2013, 08:19 PM   #104
nlp187
Drives: 2013 BRZ Limited
i want!
nlp187 is offline
Old 05-30-2013, 08:35 PM   #105
Foobar
SLO NO MO
Foobar's Avatar
I'm in, who do I paypal for this?!
Foobar is offline
Old 05-30-2013, 08:53 PM   #106
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by jamesm View Post
I want one. Now. Just a couple questions: do you need to add a sensor for egt? I assume you do. Also, if you're adding an aftermarket 0-5v, how do you scale the output? I.e. does it just output the voltage or can I somehow program in a curve to get something like '0-200psi' from '0-5v'? Also, is the stock afr still limited to 11:1 or whatever on the rich side?
Awesome work!
Yeah, it uses OEM O2 sensor and that goes down to 11.02 to be exact. I have been tuning and been 10 something AFR and needed to take the log off the AEM wideband gauge to see exactly where it was.
BTW, gauge looks very awesome!!
Sportsguy83 is offline
Old 05-30-2013, 09:02 PM   #107
cb7tuner
Yep pretty much but they supply the "ring" (vent assembly), I was looking at this today and I'm almost 100% sure hat if they put one of these gauges in the passenger side (U.S. left hand drive) vents that it would work for RHD cars. They seem to both be the same vents just exact opposites if that makes any sense.
cb7tuner is offline
Old 05-30-2013, 09:59 PM   #108
jamesm
You may need to get a longer obd2 right-angle extension cable, but even that shouldn't be an issue to find online.
jamesm is offline
The Following User Says Thank You to jamesm For This Useful Post:
evo4g63 (07-22-2013)
Old 05-30-2013, 10:38 PM   #109
TemeCal
Drives: 86
Originally Posted by RedAlert View Post
Can a y splitter be used at the obd port. So run this gauage off one leg pf the y and a blutooth adaptwr off the other y leg?
According to Tony (page 1??), they will have a Y-splitter available. Should be around $35.
TemeCal is offline
The Following User Says Thank You to TemeCal For This Useful Post:
Old 05-30-2013, 11:38 PM   #110
FA20Club.com
Drives: 2013 White Out FR-S
the factory ecu calculates egt based on o2 sensor temp and resistance readings
FA20Club.com is offline
Old 05-30-2013, 11:40 PM   #111
FA20Club.com
your ecutek map has to be calibrated to read lower than 12.17 which most tuners do when creating FI maps
The Following User Says Thank You to FA20Club.com For This Useful Post:
Sportsguy83 (05-30-2013)
Old 05-30-2013, 11:40 PM   #112
FA20Club.com
we will post the sale starting this weekend. we have an updated timeline and availability from p3cars this week. stay tuned in ladies/gents
The Following 4 Users Say Thank You to FA20Club.com For This Useful Post:
86_ZN6 (05-31-2013), APS86 (05-31-2013), lbroskee (05-31-2013), TemeCal (05-31-2013)
gauge, p3cars
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 06:19 PM
Dash Cam + HU + Reverse Integration JDMSushi Electronics | Audio | NAV | Infotainment 0 12-04-2012 06:47 PM
iPod®/USB Integration in the glove box? 8987846 Electronics | Audio | NAV | Infotainment 26 12-04-2012 12:45 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 11:39 AM
