Old 05-01-2013, 11:09 AM   #57
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
This might sound stupid, but I find it easier to smooth shift in this clutch then the stock one. Maybe all of this will change when its completely broken in, but that's how it is driving so far.
I noticed this on my other car running the FX300 as well. I think its because you can actually feel what the clutch is doing now.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 05-01-2013, 11:17 AM   #58
OrbitalEllipses
Drives: Attitude
Drove a co-workers 2005ish TL-S the other day. Liked the clutch in that car better than ours; much stiffer and lower/less travel. I'm assuming by adjusting the clutch as per the DIY I can get shorter travel, but stiffness is mainly a factor of the clutch disk itself.
Spent some time yesterday breaking in the FX300//350. I need to drive a 6 puck clutch to know the real difference, but this clutch seems pretty easy to drive. This might sound stupid, but I find it easier to smooth shift in this clutch then the stock one. Maybe all of this will change when its completely broken in, but that's how it is driving so far.
ACT 6 puck I drove was hell. Owner told me it's more manageable now that it's broken in, but...
Old 05-01-2013, 11:42 AM   #59
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Pansies all of you. I can drive it just fine now that I am used to it.
Old 05-01-2013, 12:26 PM   #60
OrbitalEllipses
Drives: Attitude
King Tut, the manliest of men.
Old 05-30-2013, 09:23 AM   #61
dabocx
dabocx's Avatar
Drives: Scion FRS
I keep seeing that the Fx300 is a clutch/flywheel set but I cant get a weight on the flywheel? Anyone happen to have this data?
dabocx is offline   Reply With Quote
Old 05-30-2013, 09:27 AM   #62
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by dabocx View Post
I keep seeing that the Fx300 is a clutch/flywheel set but I cant get a wheight on the flywheel? Anyone happen to have this data?
If I recall correctly, its between 11-12 lbs. Also, FYI, I bought a kit labeled "FX300" but it was in fact a 350. Also, if you go to clutchmasters site, you cannot build an FX300 for our cars, only 350. Its VERY streetable, no complains on it at all.
Old 05-30-2013, 09:31 AM   #63
dabocx
dabocx's Avatar
Drives: Scion FRS
Yeah your review sold me on it so I ordered one.
Old 05-30-2013, 01:25 PM   #64
scraejtp
Drives: 2013 Subaru BRZ
I see that, what is the official torque capability? (350 ft-lb?)
scraejtp is offline   Reply With Quote
Old 05-30-2013, 01:31 PM   #65
Sportsguy83
Drives: Limited BRZ
It says 110% increase over stock. The most conservative case, stock would be 130 WTQ, 110% increase= 273 ft-lb. So conservatively, make less than 273 wtq
Old 05-30-2013, 07:29 PM   #66
scraejtp
If the claim is 110% more torque capability than stock, I would assume that to mean over the stock clutch. The stock clutch is at least capapble of 175 ft-lb, so the FX350 should be good to 350+ ft-lb?
Old 05-30-2013, 08:06 PM   #67
Sportsguy83
Drives: Limited BRZ
Well yes, that is a GREAT point. Stock clutch is good to 220-230 FT-lb at the wheels, but obviously that is pushing manufacturer specs, so a good estimate is around your 350.
Old 06-01-2013, 09:26 PM   #68
Sportsguy83
Drives: Limited BRZ
I wanted to once and for all tell the community I finally deciphered what Clutch I have. It's an FX350. Part # CM15738-HDFF-SK.
For some reason they put on the box the sticker for FX300, but if you look at their parts catalog that part number is for FX350. Moreso, they don't sell an FX300 for our cars.
Lastly, in their products page they describe the FX300 as having a Kevlar clutch (this is basically the difference between the FX300 and FX350, material of the clutch). I didn't get a Kevlar clutch, but a "Formula Button disc" as they call it. All in all very happy with my clutch and very happy CM erred on my side.
Also want to send a BIG shoutout to Brady @Pure Automotive. I requested this part like at 9 a.m. on a Thursday for it to arrive next day Friday. He went on a mission and got it in the mail before the cutoff time for next day shipments AND even helped me offset some of the cost for the next day shipping. Great guy, can't be happier with him!!
Old 06-01-2013, 09:40 PM   #69
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Every parts catalog I've seen still calls it a 300, it makes it so confusing, lol
Pure Automotive is offline   Reply With Quote
Old 06-01-2013, 11:18 PM   #70
dabocx
dabocx's Avatar
Drives: Scion FRS
Mine was labeled as FX300 with steel flywheel. I got it in yesterday, so weird on the labeling!
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
