Old 05-27-2013, 11:40 AM   #57
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Originally Posted by driver01 View Post
The charcoal canister stores all the fuel fumes created withing the fuel tank assembly, its a way of releasing pressure (created by heat) without releasing fuel fumes into the atmosphere. as the charcoal canister gets saturated with fuel we need to empty it, so we connect a hose between the charcoal canister and the intake manifold. now the engine will run too rich due to always having extra fuel from the charcoal canister, thats when the purge vsv comes into play. it is a valve opened and close by the ecu. and thus we control the amount of fuel fumes that go from the charcoal canister into the intake to be burnt out by the motor
@killerkid08 @vubaru Lets break down the install of the boost solenoid controlled by Ecutek in two parts.
- Boost hoses connection
- Wiring of the boost controller
I will edit this later ono when i have more time
just like i thought.
killerkid08 is offline   Reply With Quote
Old 05-27-2013, 01:55 PM   #58
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
What sort of new hoses do you need? Can't you just reuse the stock ones and leave the purge valve in place?
Sorry I'm still very new at this.
Thank you for the write-up so far!
vubaru is offline   Reply With Quote
Old 05-27-2013, 02:31 PM   #59
FirestormFRS
I'm not sure removing the VSV is such a great idea?
What are you using to purge the vapor from the fuel tank or are you venting to the atmosphere?
Also VSV means vacuum switching valve...that vacuum is used for two differant things what's the second?
FirestormFRS is offline   Reply With Quote
Old 05-27-2013, 02:46 PM   #60
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I think you would just hook something up to it
Old 05-27-2013, 05:53 PM   #61
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I want to know the answer to this too. @driver01
Thank you so much for the great info!
Old 05-28-2013, 01:08 PM   #62
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
FYI the line connecting the intake to the purge solenoid blew off on my car. causing a large vacuum leak. I put clamps on 3 hoses to prevent this from happenning. two clamps on the two hoses attached to the purge valve and one more clamp on the end of the line that connects to the intake
What boost level did you hit when the hose blew off?
Old 05-29-2013, 03:56 PM   #63
vubaru
Now with Boost!
vubaru's Avatar
Driver01 if you could take some more pics of the install, including the connections of the purge valve and ebcs, that would be really helpful. I'm still pretty lost on this install, and there aren't any instructions available for the install.
Old 05-29-2013, 04:56 PM   #64
Sportsguy83
Drives: Limited BRZ
I think I got it nailed down. If we were closer I'd install it for you.
Old 06-01-2013, 06:38 PM   #65
vubaru
Now with Boost!
vubaru's Avatar
I'm out of town for another day but I'll hit you up and pick your brain, I need some help for sure.
Any concerns with the way the purge valve?
Old 06-01-2013, 07:00 PM   #66
Sportsguy83
Drives: Limited BRZ
I tried googling about it but didn't find anyone concretely saying its bad. If its any consolation, I have another car (2000 Camry) and it hasn't work for a long time with no noticeable effects. Let me know!
Old 06-04-2013, 01:55 AM   #67
vubaru
Now with Boost!
vubaru's Avatar
Ok, that doesn't sound like it will be too problematic. @Visconti said he'd walk me through it. I'll just grab some extra zipties and hose clamps then give him a call when I'm ready, and keep you posted.
With the injector seal failures in the other threads I'm going to take things nice and easy.
Old 06-05-2013, 09:15 AM   #68
Visconti
Drives: 05 STi
Here and ready
Visconti is offline   Reply With Quote
Old 06-05-2013, 02:20 PM   #69
vubaru
Now with Boost!
vubaru's Avatar
Here and ready
Work is kicking my ass this week, I'll hit you up this weekend!
Thank you John!!!
Old 06-08-2013, 04:36 PM   #70
vubaru
Now with Boost!
vubaru's Avatar
About to attempt this, of course I pick a weekend where it's like 95 out already. Will take some photos of the purge valve in place and a few other aspects of the install.
The Following 2 Users Say Thank You to vubaru For This Useful Post:
Draco_PR23 (06-08-2013), pmccut (06-08-2013)
Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned Visconti Forced Induction 697 11-13-2013 06:18 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
Worlds fastest BRZ - Accelerated Performance Built - Visconti Tuned !!! Visconti Forced Induction 135 09-06-2012 05:43 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
