Old 05-27-2013, 07:32 AM   #99
ricerocket93
Does the factory rims fit with the 08 STI Brembo?
ricerocket93 is offline   Reply With Quote
The Following User Says Thank You to ricerocket93 For This Useful Post:
BlueLeader (05-28-2013)
Old 05-28-2013, 03:37 AM   #100
kioton32
kioton32's Avatar
Drives: 14' Monogram FRS, ulramarine, white
I'm a little confused about this so let me see if this is correct...
04 front calipers with switched bleeder valves
08+ rear calipers
04-07 front rotors
08+ rear rotors duel drill to fit 5x100...
Is that correct.
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
kioton32 is offline   Reply With Quote
Old 05-28-2013, 03:51 AM   #101
derek1ee
Drives: BRZ/FRS/STI/M3
08+ rear calipers
04-07 front rotors
Is that correct.
04+ front calipers with switched bleeder valves
08+ rear calipers
04+ front rotors dual drill to fit 5x100
derek1ee is offline   Reply With Quote
Old 05-28-2013, 04:38 AM   #102
OrbitalEllipses
Drives: Attitude
Everybody. STOP. Read this thread: http://www.ft86club.com/forums/showthread.php?t=23512
08+ rear calipers
The red is incorrect. 04 front rotors are specified BECAUSE they are 5x100 natively.
Not without a 15mm spacer MINIMUM. You'll probably need a 20mm.
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
BlueLeader (05-28-2013), cammaxon (01-17-2014), chanomatik (12-02-2014)
Old 05-28-2013, 05:19 AM   #103
derek1ee
I see nothing wrong in my statement re: front rotor.
yes 04 is predrill to 5*100, but 05 and beyond aren't. notice i put the plus sign there.
speaking from brembo swap - i just (yes like 5min ago) took off the front caliper from my 2013 STI. I plan to put it on wife's fr-s and get AP bbk for the STI.
Old 05-28-2013, 05:52 AM   #104
BlueLeader
Drives: Ultramarine Blue Scion FRS
So basically to sum it up the prudent thing to do when doing this mod is to get a set of:
08+ sti calipers front and rear
04+ sti rotors front
08+ sti rotors rear dual drilled to 5x100
20mm spacers if using stock wheels
This should be a fun project to do
Curious if anyne has pics of this setup n stock rims
Sent from my VS930 4G using Tapatalk 2
BlueLeader is offline   Reply With Quote
Old 05-28-2013, 12:27 PM   #105
OrbitalEllipses
Drives: Attitude
Nothing WRONG, but it's not right. Easier for most people to get 5x100 rotors then get rotors drilled. Anyhow, most good STI rotors are dual-drilled except trusty Centric blanks.
Some minor notes:
04-current for front caliper. The shape hasn't changed in 10 years.
04 rotor if you don't want to drill, 05-current if you're okay getting it drilled (as I said most STI rotors will be dual-drilled anyhow).
BlueLeader (05-30-2013)
Old 06-15-2013, 02:45 PM   #106
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Subbed
Cade01 is offline   Reply With Quote
Old 06-20-2013, 05:00 PM   #107
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Can anyone confirm that RockAuto.com has rebuilt brembos directly from the STI?
For instance, part number 14247039 brings up a Front-Right Caliper for the following vehicles:
SUBARU IMPREZA (2004 - 2005)
SUBARU IMPREZA WRX STI (2006 - 2012)
SUBARU IMPREZA WRX STI LIMITED 2011
If this is the case, they have all 4 calipers for $960. I realize this doesn't include rotors or brake lines, but it still seems like a hell of a deal.
Has anyone bought these and can confirm they are legitimate rebuilt Brembos?
Acree is offline   Reply With Quote
Old 06-21-2013, 03:59 AM   #108
OrbitalEllipses
Drives: Attitude
I would trust Centric. I've heard of people buying the remans and they are Brembo calipers; just don't ebay that shit. I'm actually looking at Cardone 2 pot rear remans right now and they dirt cheap...
Old 06-21-2013, 11:40 AM   #109
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I've been too hesitant to be the first as well. Waiting on someone else to be the guinea pig haha. That being said, I think you really need a set
kask2_6.0 is offline   Reply With Quote
Old 09-17-2013, 11:50 PM   #110
wallace03
wallace03's Avatar
Drives: WRB BRZ
Bump on the rockauto.com, has anyone bought calipers off this site? They don't have pictures and specific details, but searching 04-05 wrx 2.5l turbo -> brakes -> caliper i am getting some parts come up that are showing for $100. Also i'm looking to build a set of BBK from 04-05 brembos, what would be a good price for front calipers alone?
wallace03 is offline   Reply With Quote
Old 09-23-2013, 12:03 PM   #111
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
05 brembo's
04 STI DBA 4000 rotors
SS lines
Super blue fluid (arrest me)
Stop tech street pads.
on track this setup felt great.
Jive Turkey is offline   Reply With Quote
The Following 4 Users Say Thank You to Jive Turkey For This Useful Post:
chanomatik (12-02-2014), lxs (04-01-2014), SkAsphalt (09-23-2013), turbocat (04-03-2014)
Old 09-23-2013, 04:15 PM   #112
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Jive Turkey View Post
05 brembo's
SS lines
They say imitation is the greatest form of flattery.
Jive Turkey (09-23-2013)
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
