Old 05-23-2013, 08:38 PM   #15
cfusionpm
Drives: Firestorm 6MT Scion FR-S
I did it for 8 years with a tC, which ran like a champ for 77k miles. Just regular maintenance and tires over the whole lifespan. Lived <1 mile from work.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 05-23-2013, 09:21 PM   #16
GNS
Drives: .
The occasional commute of under 1 mile will have no ill effects on your car. However, once or twice a week, take it for a 30min spin (10 min warm up, 20 min spirited driving). That will help to burn the moisture off in your crankcase. Simple...
GNS is offline   Reply With Quote
Old 05-23-2013, 09:39 PM   #17
fistpoint
Drives: Supercharged Golf Cart
Take a bike, screw ankle express(walking).
You car will remain ding-free for longer this way too.
fistpoint is offline   Reply With Quote
Old 05-23-2013, 10:29 PM   #18
AznBRZer
Drives: 16 CBS WRX Limited
QFT
AznBRZer is offline   Reply With Quote
Old 05-23-2013, 10:36 PM   #19
mid_life_crisis
Drives: FR-S 10 #103 AT
I'd go the long way to work just to get to enjoy the car.
mid_life_crisis is offline   Reply With Quote
Old 05-23-2013, 10:56 PM   #20
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
This is exactly why its ill advised to commute short destinations .
The crankcase accumulates moister and eventually pools in the crankcase. sort distances with im proper warm up period will not allow the water vapors to escape.
if you are going to commute for destinations please advise to my recommendations:
1. 5-10 mins of leaving your home start your vehicle and allow to the engine to warm up.
2. Cars today have come such a long way . you can use the stock tem gauge as reference . once you see the needle risen about a quarter way to fully warm feel free to drive it.
You might wonder way i say a quarter way and not all the way?
Ill explain.
the cooling system is designed to obviously to always maintain coolant in the engine.
When the engine is cold the Thermostat the basically sits in between the radiator and the engine is also cold and when its cold its its closed. As the engine is running its warming up the coolant inside the block .when you see the gauge begging to move its also reference that the coolant in the engine if fully warm causing the thermostats to open allowing cool coolant to enter and hence warming up the rest of the system.
(This of course helps warms up the engine oil along with the action of are FA20 engines)
I will always advise the use a visual data stream from the OBDII but the gauge works just fine for everyday life.
any questions feel free to PM me.
Good luck, hope this helps
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 05-24-2013, 08:13 AM   #21
Mikem53
Drives: FR-S 6MT
Ill explain.
This is bad advice.. Sorry to say.. Starting the car and letting it idle for 5 to 10 minutes causes more harm than good.. Because at idle when cold the engine is running rich and the engine is not under a load and will take LONGER to warm up allowing gas to dilute the oil. You should start the car and drive within seconds which warms it up quicker. Also oil temps are slow to follow coolant temps. It's takes another 15+ minutes for oil temps to come up under load.
Just drive the car to work as you need.. Take it out a couple times a week and drive it good! Change you oil more frequently, don't worry about this shit and enjoy your car.
Mikem53 is offline   Reply With Quote
Old 05-24-2013, 10:32 AM   #22
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
This ^
whaap is offline   Reply With Quote
Old 05-24-2013, 11:00 AM   #23
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by slowbrz View Post
I live very close to work and the driving commute will be under 1 mile. I plan to walk most of the time but want to drive on rainy or very hot days. Is this bad? Should I drive a couple miles around before going to work?
The variable here is time. One mile in SoCal traffic might take a half-hour, plenty of time for oil to reach best operating temperature.
Otherwise, I'd stick with a good full synthetic like Red Line or another premium brand in factory recommended 0W-20 weight for best cold start protection and follow the owner's manual oil change time interval if mileage is below average.
torqdork is offline   Reply With Quote
Old 05-24-2013, 11:10 AM   #24
Kayzer Soze
Drives: 2013 BRZ 6MT Satin White Pearl
He makes a valid point, but maybe needs to be explained the new features of cars.....
Back in the day, you had to drive at least 5 miles or else when you tied your horse to horizontal wooden bar in front of the saloon, they risked being hyper and running away, breaking everything in their path (picture a horse on redbull)
Now a days, despite the reference of Horse Power in your car, there arent actually horses, so you can drive 40 feet and shut off car if you want. Thank you modern technology! could you imagine how much horse feed would cost now a days!?
Kayzer Soze is offline   Reply With Quote
Old 05-24-2013, 11:18 AM   #25
Doctor Who
Equinsu Ocha
Doctor Who's Avatar
Drives: SWP BRZ Limited
Lol.
Doctor Who is offline   Reply With Quote
Old 05-24-2013, 12:32 PM   #26
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
wtf i dont even....
zaptorque is offline   Reply With Quote
Old 05-24-2013, 12:43 PM   #27
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Originally Posted by supramkivtt2jz View Post
potato
someone calling me?
chenshuo is offline   Reply With Quote
Old 05-24-2013, 12:57 PM   #28
regal
Drives: Scion FR-S/Toyota Yaris
with a 1 mile commute your car will be considered sever conditions, this is because the unburnt fuel in the crankcase doesn't get warm enough to evaporate thru the pcv. Best thing you can do is change the oil often (every 4 months) to prevent the fuel left in the crankcase from dissolving the gaskets. This was a very common issue with Subaru engines requiring a complete $3k teardown with less than 30k miles for folks with very short commutes.
I would start be doing an oil analysis every month and see how bad the situation is, with this engines very tight rig seal it may be fine.
Ideally a bike, an electric vehicle, or a very small 4 cylinder the heats up fast (Scion IQ) for the commute would be perfect for your situation.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
flux capicator overload, joetheegyptian's new un
>>>Rev Works - Clutches - Drive Shafts - Short Shifters -All Your Drivetrain Needs<<< Rev Works Transmission and Driveline 210 09-12-2014 03:45 PM
Short ram Intake/CAI ? QC-FRS Engine, Exhaust, Transmission 12 02-01-2014 08:02 PM
BPS Short Shifter Alabang 86 Transmission and Driveline 8 09-02-2013 12:58 AM
FS: NRG short hub for frs Pekingduck Interior Parts (Incl. Lighting) 0 01-26-2013 04:55 PM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 08:30 PM
