Old 05-23-2013, 05:35 PM   #1
slowbrz
Drives: '13 black BRZ MT
Is it bad to drive for short distances?
I live very close to work and the driving commute will be under 1 mile. I plan to walk most of the time but want to drive on rainy or very hot days. Is this bad? Should I drive a couple miles around before going to work?
slowbrz is offline   Reply With Quote
The Following User Says Thank You to slowbrz For This Useful Post:
sittinSideways (05-24-2013)
Old 05-23-2013, 05:38 PM   #2
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
No, and no.
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
Old 05-23-2013, 06:16 PM   #3
chickdigger802
Drives: 1997 Geo Prizm
I think you are underestimating modern cars a bit :/
chickdigger802 is offline   Reply With Quote
Old 05-23-2013, 06:17 PM   #4
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
potato
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Anthonytpt (05-24-2013)
Old 05-23-2013, 06:20 PM   #5
Celica00
Celica00's Avatar
Drives: 86
what is this thread..
Celica00 is offline   Reply With Quote
The Following 7 Users Say Thank You to Celica00 For This Useful Post:
Anthonytpt (05-24-2013), AZOOZ_95 (05-24-2013), Carwhisperer (06-16-2013), CodyFRS (05-23-2013), Enraged21 (05-24-2013), M-17 (05-24-2013), R2RO (05-23-2013)
Old 05-23-2013, 06:28 PM   #6
reeves
It's not necessarily bad, as long you change your oil more frequently. Engine wear occurs most when you're driving on a cold startup, so just don't drive too hard during that 1 mile stretch. Driving short distances like that doesn't give your engine enough time to warm up to proper operating temperatures either.. *the temperature gauge isn't a good indicator of "proper operating" btw.
The Following 2 Users Say Thank You to reeves For This Useful Post:
applekash (06-16-2013), IntotheOcean (05-24-2013)
Old 05-23-2013, 06:38 PM   #7
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Also from what I've learned, unburned stuff from the fuel builds up when operating under temp.
Old 05-23-2013, 06:43 PM   #8
frslee
Just drive it
Drives: 13' FR-S
What is wrong with people
frslee is offline   Reply With Quote
Old 05-23-2013, 06:45 PM   #9
boredom.is.me
Custom User Title
Well your contribution isn't exactly helpful.
The Following 5 Users Say Thank You to boredom.is.me For This Useful Post:
applekash (06-16-2013), AZOOZ_95 (06-16-2013), MmmHamSandwich (05-24-2013), steeloyangster (06-18-2013), WolfpackS2k (05-24-2013)
Old 05-23-2013, 07:02 PM   #10
slowbrz
I dont drive my car hard during the first couple minutes anyway. But from what Ive read, it's just bad to drive for short distances and turning off the engine.
I would have to change the oil more frequently because more stress is put on the engine, right? By this logic, wouldnt it cause more wear to the engine?
Old 05-23-2013, 07:06 PM   #11
taimysho0
Drives: frs
you might see a drop in your mpg
taimysho0 is offline   Reply With Quote
Old 05-23-2013, 07:11 PM   #12
autogyro
Drives: Toyota 86 GTS
Yeah if your car is never getting up to operating temperature due to all the short drives I think it's a valid concern. I don't see why people are being snarky about it. It's a valid question.
I would personally walk all the same though if the work commute is less than a mile, even if it's raining or if it's hot.
autogyro is offline   Reply With Quote
Old 05-23-2013, 07:25 PM   #13
Mikem53
Drives: FR-S 6MT
As mentioned ... U want to bring the engine up to operating temps so it burns off moisture in the oil.. Because you start to get the oil hot on a cold engine... The temp diff cause condensation and other nasty chemical reactions happen.
What you need to do is drive it every now and then to operating temps .. And change ur oil more frequently.. You will be fine.. It can take it.. Just not ideal..
Mikem53 is offline   Reply With Quote
Old 05-23-2013, 07:28 PM   #14
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Maybe every few days take a little bit of a longer drive coming home after work. Do that and I wouldn't worry about it at all.
whaap is offline   Reply With Quote
flux capicator overload, joetheegyptian's new un
>>>Rev Works - Clutches - Drive Shafts - Short Shifters -All Your Drivetrain Needs<<< Rev Works Transmission and Driveline 210 09-12-2014 03:45 PM
Short ram Intake/CAI ? QC-FRS Engine, Exhaust, Transmission 12 02-01-2014 08:02 PM
BPS Short Shifter Alabang 86 Transmission and Driveline 8 09-02-2013 12:58 AM
FS: NRG short hub for frs Pekingduck Interior Parts (Incl. Lighting) 0 01-26-2013 04:55 PM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 08:30 PM
