Old 05-24-2013, 07:44 AM   #155
Area51
Area51's Avatar
Drives: 13 FR-S
Yes please do it right.....window switch would not of prevented this...put your car in neutral, arm the nitrous, smash the gas and let it spray, this will mimic the act of my clutch letting go during the run..your revs will build so fast you would not know what happen, so having the juice kick off at 6800rpm still would not of prevented the float that was created!! My motor is back in action, with act clutch... Im not done but with the posters rambling I just wont bother to release my dyno sheet/results/proper jetting for you will all find out the jets you get are far from correct. Carry on.....
Area51 is offline   Reply With Quote
The Following User Says Thank You to Area51 For This Useful Post:
Argento_FR-S (05-28-2013)
Old 05-24-2013, 08:43 AM   #156
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Shoebox (05-24-2013)
Old 05-24-2013, 09:09 AM   #157
crook
crook's Avatar
Drives: storm black GT
LOL
crook is offline   Reply With Quote
The Following User Says Thank You to crook For This Useful Post:
Sportsguy83 (05-24-2013)
Old 05-24-2013, 10:18 PM   #158
Shoebox
Shoebox's Avatar
Drives: 2013 Subaru BRZ
Lol!
Shoebox is offline   Reply With Quote
Old 07-04-2013, 08:27 PM   #159
mrk1
Drives: Sterling BRZ Ltd
Has anyone else tried there hand at this?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-16-2013, 05:26 PM   #160
forzajuve
Drives: Ultramarine 86 - 6MT
Is this thread dead? None of the OP's pictures show up so I have less insight on what the current status is...
forzajuve is offline   Reply With Quote
Old 10-19-2014, 03:25 PM   #161
brznoob
brznoob's Avatar
Drives: 2014 subaru brz Limited 6mt
I will be installing this kit soon. It might not revive the thread but wanted to make some valid points. First, in the install manual says not to run over the 50 shot on Stock tune. The master Subaru tech that works on my car contacted a nitrous express engineer to confirm all the information. Your pump will max out over a 50 shot and needs to be upgraded to at least 255 lph . the rpm window switch must be set 200rpms under the Rev limiter. Make sure you have a bottle warmer to maintain the pressure stable. Also over 50 shot you need a tune as the ignition timing needs to be retarded. The clutch limitations or having stock internals had nothing to do with this failure. Also the spark plugs need to be changed to 1 step colder for 75 shot and over. So as you can see this was not N2O's fault. As they say in the fast and the furious: amateurs don't use nitrous. ... And please take some time to actually read the instructions, plus consult professionals and not "garage tuners".
brznoob is offline   Reply With Quote
The Following 2 Users Say Thank You to brznoob For This Useful Post:
GT86_PRAGUE (06-01-2015), mrk1 (10-21-2014)
Old 10-19-2014, 03:27 PM   #162
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Plugs are already cold enough
Old 10-19-2014, 07:29 PM   #163
brznoob
brznoob's Avatar
Well according to a nitrous express engineer plugs are cold enough for up to a 50 shot but they recommend one step colder for 75-100.
Old 10-21-2014, 10:48 PM   #164
mrk1
I am still interested in nitrous, however I have yet find a local source. This forum will just recite F&F quotes for days before you get any info. You had the right idea about talking to NX.
The Build Thread
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
brznoob (11-03-2014), GT86_PRAGUE (06-01-2015)
Old 02-28-2015, 05:22 PM   #165
brznoob
brznoob's Avatar
Guys, This is probably dead by now but wanted to add the latest updates. Kit is running. Some details still need to be sorted out as the RPM window switch as the tech couldn't find the tach signal but looks like it'll be resolved soon. For now using the TPS wot switch.
2014 BRZ Limited 6MT World Rally Blue.
Mods: Tomei UEL header, Tomei overpipe, HKS Dual Resonated Front Pipe, Stock Catback, JR C30 kit with HBP, DW700cc injectors, DW 65C pump, Delicious Tuning FF kit, Forrester XT oilcooler, ACT HD Street clutch, ecutek #mototuned.
The Following 3 Users Say Thank You to brznoob For This Useful Post:
cameronjones239 (03-04-2015), Fastbrz (02-28-2015), GT86_PRAGUE (06-01-2015)
Old 02-28-2015, 05:51 PM   #166
mrk1
nice to hear, I'm still interested
The Build Thread
Old 02-28-2015, 05:57 PM   #167
brznoob
brznoob's Avatar
https://plus.google.com/116431783151...ts/fC7LVnj5y9u
Link to some pics of the setup
Fastbrz (02-28-2015), JDsThatGuy (06-01-2015)
Old 02-28-2015, 06:05 PM   #168
brznoob
brznoob's Avatar
According to TrueStreet Performance, the shop where I fill the bottle, a 50 shot should be good for up to 22 passes at the drag-strip. Not that I'm interested in drag racing at all but based on that calculation now that is at wot only means it will last close to a month under normal driving conditions. I'll let you all know. Once the rpm window switch is on it will change as it will be based on rpm and not throttle position. I tested it a little bit but nothing crazy because the weather is too cold and I don't want to embarrass myself LOL doing something stupid and losing traction and control of the car. the 50 shot though is not mind blowing I'm sure a lot would like that in their cars it gives the car that lacking torque. The car should be a little over 200 wtq or maybe even more as the dyno pull was 165 wtq and 204 whp. Nitrous makes more torque than power so in theory 50 whp would be 60-65 wtq which would put the car in about 220 torque. I'm eager to get some numbers as soon as the weather gets a little warmer.
Fastbrz (02-28-2015), mrk1 (03-01-2015)
VA Cops on 495 express lanes SneakyPete Mid-Atlantic 35 03-02-2013 09:19 PM
Jack Burton's Porkchop Express JACK 8URT0N BRZ First-Gen (2012+) — General Topics 14 07-23-2012 10:49 AM
Auto Express article Andy EUROPE 4 11-02-2011 07:54 PM
