Old 03-15-2013, 03:33 PM   #1
Area51
Area51's Avatar
Drives: 13 FR-S
Nitrous Express Plate Kit
Fr-S/BRZ plate kit . Pics of what is included in the standard kit. Purge and Automatic heater I ordered is extras needed. Kit comes with a electronic wide open throttle switch to ensure safe activation. I will be posting few install pics as well as dyno results for 50hp an mabe 65_75hp jets. All aspects of this kit from the car specific instructions to quality of the parts are top notch. Car will have intake, drop in filter, lightweight crank pulley and muffler delete. I will keep anyone interested updated. Thanks[IMG][/IMG]
Area51 is offline   Reply With Quote
The Following 7 Users Say Thank You to Area51 For This Useful Post:
Books (04-22-2013), ftc~brz (04-11-2013), GaN-MaN (03-26-2013), JDMenrique (03-23-2013), Opposed (03-15-2013), Sonolin (03-18-2013), UltraFRS (03-15-2013)
Old 03-16-2013, 05:02 AM   #2
DannyFRS
Drives: White out FRS
Keep us posted. Thought about going this route too.
DannyFRS is offline   Reply With Quote
Old 03-16-2013, 05:27 AM   #3
EZWood
BAMF
EZWood's Avatar
Probably gonna be a lot of criticism on this. Nitrous is cheap power, and if it works for your application the way you want it to, that's all that matters. I would do an afr meter to make sure you don't run too lean. May need to have it tuned to keep from running too lean, but I want to say that these cars run the ratios a little rich stock.
Old 03-16-2013, 05:58 AM   #4
mad_sb
Drives: 2013 Asphalt FR-S
saw video spot a while back, i think it was focus sport or perhaps some other aftermarket engine building company, where they talked about using nitrous to find the limits of O.E. engine components. They would start out with like 100 shot and keep adding more and more during dyno stress testing until a component would fail. Then they would make replace what failed with something stronger and up the shot again etc etc. They said it was a very quick and easy way to find the power limits of stock internals for R&D work.
Good luck with the kit. Interested in seeing the results. I might consider something like this except i think most HPDE groups don't want it on track.
Old 03-16-2013, 06:25 AM   #5
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
I'm definitely watching this thread... I have no idea where it's gonna go, but I'm watching!
TyperRspec789 is offline   Reply With Quote
Old 03-16-2013, 08:49 AM   #6
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
That's exactly what GM did to lay the foundation for their early 2.2l Ecotec engines. Just kept cranking up the nitrous until failures would occur to see what power level things would let go. Turned out to be a very accurate way of determining what required replacing at certain power levels. Nitrous is a viable option when done correctly although there will always be those who bash it (typically also have never used it). I am excited to see someone playing with this as well even though for the moment I will stick solely with a permanent FI option.
AZFA20 is offline   Reply With Quote
Old 03-16-2013, 10:47 AM   #7
Area51
Area51's Avatar
Drives: 13 FR-S
EZwood I definitely agree on the afr gauge. Ran them in the pass with nitrous setups. I plan on maken this kit more complex but as for this thread I am trying to keep it simple. Bolt on, test, spray then head to dyno for results. Then after that I will make the kit more advance with other options. Mabe after I upgrade clutch who's to say with a good tune that the 100shot in two 50shot stages cant be done safely. Just trying to keep to a safe but novice level of testing for new users to nitrous.
Old 03-16-2013, 10:55 AM   #8
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Nice! I might go this route for cheap fun.
sent from my Note 2 using Tapatalk 2
Freeman is offline   Reply With Quote
Old 03-16-2013, 01:48 PM   #9
cruzinbill
Drives: Argento 6spd FR-S
Why not get an ecutek tune for it? Im sure you can make some pretty nice safe reliable power if you did. I think @Visconti could make a sweet NOS tune.
"Bitches be watching you do burnouts for hours"
cruzinbill is offline   Reply With Quote
Old 03-16-2013, 01:54 PM   #10
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
[ame="http://www.youtube.com/watch?v=DDmKr8slxmk"]http://www.youtube.com/watch?v=DDmKr8slxmk[/ame]
SilverSkyline210 is offline   Reply With Quote
The Following User Says Thank You to SilverSkyline210 For This Useful Post:
themajesticone (10-19-2014)
Old 03-16-2013, 01:56 PM   #11
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
I do have a NX universal kit laying in the garage hmmmm
NeedsmoreCowbell is offline   Reply With Quote
Old 03-16-2013, 03:41 PM   #12
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Can't wait to see these results. There will always be a lot of hate towards nitrous but it has its time and place like everything else.
Will be great to see how the engine responds to nitrous
pheoxs is offline   Reply With Quote
Old 03-16-2013, 05:31 PM   #13
Area51
Area51's Avatar
Drives: 13 FR-S
I will do a ecutek tune in the near future. First I have to do just a bolt-on 50 and present my results and unbiased opinions for those looking to break into the nitrous world. Mounted the plate, looks good. [IMG][/IMG]
Old 03-16-2013, 06:16 PM   #14
NeedsmoreCowbell
where did you mount the bottle? can you post a bigger pic of the engine bay and a closer one on where you connected for fuel source.
Thanks...
Nice job... hope the jets are right ))
VA Cops on 495 express lanes SneakyPete Mid-Atlantic 35 03-02-2013 09:19 PM
Jack Burton's Porkchop Express JACK 8URT0N BRZ First-Gen (2012+) — General Topics 14 07-23-2012 10:49 AM
Auto Express article Andy EUROPE 4 11-02-2011 07:54 PM
