Old 05-23-2013, 02:10 PM   #1
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
Crickets?
What is meant when members describe "crickets"?
Jertronic is offline   Reply With Quote
Old 05-23-2013, 03:14 PM   #2
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
A chirping sound coming from the fuel pump. Generally very faint, only audible with the stereo off and idling, or from outside the car with the hood open.
Mandy is offline   Reply With Quote
Old 05-23-2013, 03:24 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
[ame="http://www.youtube.com/watch?v=29coLbwXqf0"]My frs with annoying chirping noise! - YouTube[/ame]
ineedyourdiddly
Enraged21 (05-23-2013)
Old 05-23-2013, 03:27 PM   #4
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
its the same chirping noise and its annoying as snot. even my tech called it a sound from hell before i got the TSB taken care of.
supramkivtt2jz is offline   Reply With Quote
Old 05-23-2013, 06:43 PM   #5
BRZJonny
Drives: 2013 Satin White BRZ Limited
Just got my crickets exterminated yesterday...
BRZJonny is offline   Reply With Quote
Old 05-23-2013, 06:50 PM   #6
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
There is an entire thread about this in the TSB forum, but I got rid of mine by using Ethanol-free gasoline.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 05-23-2013, 08:10 PM   #7
taimysho0
Drives: frs
living in CA, is there any gas station using 91 octane that doesnt have ethanol? i used shell and still have crickets in my car
taimysho0 is offline   Reply With Quote
Old 05-23-2013, 09:10 PM   #8
deucethemoose
You can check at www.pure-gas.org
Old 05-23-2013, 09:22 PM   #9
strat61caster
There aren't, at least not conveniently located (might try filling up if you're on your way to Thunder Hill)
Personally had the best luck with ARCO, quieter than Shell and 76 under normal driving conditions.
ineedyourdiddly
Old 05-23-2013, 09:42 PM   #10
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
For what causes it, check here. These guys are saying that it might not actually be the ethanol. It's a short thread btw.
http://www.ft86club.com/forums/showthread.php?t=37166
Old 05-23-2013, 09:44 PM   #11
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Is search broken?
Old 05-23-2013, 11:58 PM   #12
Number 6
Drives: Limited 2013 Pearl White - Manual
So the 'cricket' noise in this video is the air cond compressor cycling on and off... right?
Number 6 is offline   Reply With Quote
Old 05-24-2013, 12:48 AM   #13
Jertronic
Jertronic's Avatar
Not much luck at all with the search function. It provides so many threads that sometimes have 100+ pages. Where do you find your phrase or search subject?
Will the dealerships fix the chirping fuel pump? What has been the predominant outcome from the crickets problem?
Can u ask another silly question? And yes, I did attempt to search for this and got nowhere. What is the "noisemaker" replacement or removal that members have been commenting on?
Old 05-24-2013, 01:25 AM   #14
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
No, it's the chirping which happens regardless.
There are threads about it in the Issues | Warranty sub-forum. http://www.ft86club.com/forums/forumdisplay.php?f=72
They have revised the pumps but some claim the chirps are still coming back.
The noise generator is some piping that flows into the cabin to give you more of an intake sound. Some people don't like it so they remove it or mod it with a different pipe from TRD for more or less sound.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
(TSB) No More Crickets Under My Hood!! xpicer Issues | Warranty | Recalls / TSB 1140 12-04-2015 09:53 AM
Different kind of crickets... KSC Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 03-19-2013 06:51 AM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-06-2013 12:29 AM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 07:39 PM
Just changed oil...crickets got but new pulley noise sa1126 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-30-2012 06:45 PM
