Old 05-22-2013, 10:59 PM   #29
brzadmir
Drives: 13' BRZ, 05' 325xi, 02' RAV4
Yes, its very similar minus the "raspines". Nice, deep tone. Get the catted downpipe, they Dynoed both versions and there is no power gains from going Catless, only rasp and loudness is added.
Yeah but i feel as if i go catless my sound will be very similar to what was shown in the video as opposed to going catted the sound may differ because in this video the pipe was a invidia catless downpipe so i figure the nameless catless will have a similar sound as opposed to nameless catted... any thoughts???
brzadmir is offline   Reply With Quote
Old 05-23-2013, 08:13 AM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If you are looking EXACTLY for this sound, then yeah I agree with you you should go Catless.
Old 05-23-2013, 11:26 PM   #31
brzadmir
One more question man, appreciate the help though! What does it mean when it says exhaust bushings??? So if i purchase the "no mufflers" that is loudest out of the 4" or 5"? Thanks again
Old 05-24-2013, 07:49 AM   #32
Sportsguy83
Drives: Limited BRZ
I forgot about that part of your question. The bushings are rubber or compound hangers that hold your exhaust in place. Do you plan to race your car at all? If yes, you should get at least two for the farthest back ones. IF you plan on racing a lot, get the 5 and replace them all.
Old 05-24-2013, 10:24 AM   #33
qoncept
qoncept's Avatar
I remember reading that and groaning a little bit. What's the difference between racing a little and racing a lot? Either you need them or you don't.
@brzadmir, the point of the poly bushings is presumably to help better stabilize the exhaust over the stock rubber bushings. If your exhaust is bouncing around and hitting anything, you need more. How many you need up front is anyone's guess. My guess is zero, but I'm planning on 2, and I will be racing my car "kind of a lot."
On the WRX the point of poly hangers is that they're longer than stock, in case your exhaust doesn't fit quite right. But I haven't seen anything that indicates these are longer, and in any case, after 6 different exhausts on the WRX I never found one that needed longer hangers.
qoncept is offline   Reply With Quote
Old 05-24-2013, 10:30 AM   #34
Sportsguy83
Drives: Limited BRZ
Ok, let me put in in simpler, more detailed terms... If you race " a little", you are not the most experienced driver, you rarely go to events and as a consequence, you don't push the car to the MAX. Hence, no need for full bushing change.
If you race "a lot" it means you regularly do track, are an experienced driver and will be pushing the car to the max. Hence, changing the 5 bushings is highly recommended.
Old 05-24-2013, 10:40 AM   #35
qoncept
qoncept's Avatar
:P If you saw me drive you might change your mind. I'm so not smooth it would blow your mind. If anyone is going to bang a muffler on the bottom side of the car it's me.
If anyone is going to bang a ***** on the bottom side of the **** it's me.
Seriously though, you put more in until the exhaust doesn't hit anything. Since you're ordering, guess how many you'll need and hope it's enough. My opinion without any evidence to back it up is get at least 2 and you'll be fine.
Old 05-24-2013, 10:42 AM   #36
Sportsguy83
Drives: Limited BRZ
Every rule has an exception In any case, I agree, as a general rule two should be fine.
Old 05-24-2013, 01:23 PM   #37
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
On the WRX the point of poly hangers is that they're longer than stock...
Just to be clear, that's not always the case. For instance, Kartboy sells "XL" hangers to drop an exhaust with poor clearance. They are available in 15mm or 12mm (this refers to the size of the holes for mounting). Our car uses the 12mm I believe, same as 08+ Imprezas. 02-07 uses 15mm. But both sizes are available in stock size or Extra Long. I'm sure other manufacturers have this as well, I'm just a KB fan.
I had both long and standard on my 05 WRX (Invidia N1 catback). The short ones made the exhaust bump the underside of the car, but the XLs made it look horrible. I ended up just banging a dent in the pipe and using the standard length hangers. No more knockin!
Don't be caught with a floppy pipe! I'm all for replacing 4. That 5th one was a PITA to get installed on the WRX so I have no intention of bothering with this car. They're so cheap anyway, why just buy two?
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
Sportsguy83 (05-24-2013)
Old 05-24-2013, 03:53 PM   #38
Sportsguy83
Drives: Limited BRZ
Very well written. Wanted to point out the 5th is fairly easy on our cars.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
2point0 (05-24-2013)
Old 09-20-2014, 06:39 PM   #39
2much
I wanna go fast
Drives: 2013 FR-S 6MT
OK OK... so how many pieces are there between the exhaust ports and the exhaust tips?
headers - over pipe - down pipe - mid pipe - axle back
2much is offline   Reply With Quote
Old 09-20-2014, 09:12 PM   #40
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Depends on whether you count clamps, nuts, bolts and gaskets.
2much (09-20-2014)
Torque App - What does your layout look like? DriftEightSix Electronics | Audio | NAV | Infotainment 27 05-01-2016 08:52 PM
TRD Dual or Quad Exhaust? Confused? sharkasport AUSTRALIA 16 12-10-2012 09:07 PM
New forum layout ahausheer Off-Topic Lounge [WARNING: NO POLITICS] 85 04-17-2012 02:56 PM
RHD Engine bay layout from: CarTop (Japanese magazine). VLN car. sirus Scion FR-S / Toyota 86 GT86 General Forum 47 11-22-2011 12:09 PM
FT-86 vote for you engine layout 2.0L NA vs 2.0L Turbo vs 6 banger Allch Chcar Scion FR-S / Toyota 86 GT86 General Forum 87 08-17-2011 02:31 AM
