Old 05-23-2013, 01:03 PM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by DAMotorsports View Post
we just singed with Weds Sport and will be running there new SA15 18/9.5. We will be testing them with a 275 and hopefully a 285 set up. We will be running a squired setup so the final tire will be the one that fits the front. the SA15 are about 19 lbs.
I think you will be the first to fit a 275/285 up front.
DAMotorsports (05-23-2013)
Old 05-23-2013, 01:07 PM   #30
DAMotorsports
Drives: 2013 Scion FRS "Raven"
We are going to try and Ill keep everyone posted. With luck the tires will be here saturday.
DAMotorsports is offline   Reply With Quote
Old 05-23-2013, 01:10 PM   #31
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Quality of tire > Width.
There are guys running 8's in the 1/4 on a 275, you just need the right 275. Suspension also plays an enormous role in how the car hooks up. Getting the weight to the rear and having the car " squat " is imperative.
I also understand many people want to DD their FI setups and have to factor in wet weather performance as well, which eliminates any real sticky tire.
Tuning solutions such as boost by gear also help tremendously with traction, which would eliminate the need for such a wide sticky tire and maintain decent wet driving attributes.
Many things to consider. Hope I was of some insight.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 05-23-2013, 01:29 PM   #32
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by dabocx View Post
Im going to run the full blown kit on the stock 215s like a madman
Tires/wheels should have come first but ill manage somehow.
I'm on the same boat
Old 05-23-2013, 01:48 PM   #33
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
225 on stock wheels, 11 psi.
Not scary, its fun.
killerkid08 is offline   Reply With Quote
The Following 2 Users Say Thank You to killerkid08 For This Useful Post:
SmsAlSuwaidi (05-23-2013), Sportsguy83 (05-23-2013)
Old 05-23-2013, 02:48 PM   #34
lexusb3
Drives: FRS
255/40/18 on a 9.5 inch on the rear and its fun and sticks when u make it but if u drop the clutch and launch you will spin !!!! Also I have suspension upgrades... I was on the stock rims and tires just for fun and that was a bit scary not going to lie
lexusb3 is offline   Reply With Quote
Old 05-23-2013, 03:04 PM   #35
OrbitalEllipses
Drives: Attitude
Originally Posted by Adeets View Post
Yeah that thread had nothing of use
ORly? You mean it didn't have anything about fitting wider wheels? Think outside of your box, bro.
Old 05-23-2013, 04:45 PM   #36
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Originally Posted by Pure Automotive View Post
Definitely agree with Tut, would not go smaller than 245 on FI, you need that extra contact patch. Both my car and typerrspec789s car are on 255.
Uh oh... Should I be concerned about my 235's even though they're ZIIs then? Not sure I wanna swallow the cost of more performance wheels / tires lol.
nataku is offline   Reply With Quote
Old 05-23-2013, 04:57 PM   #37
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Yeah, pls keep us posted--will be watching your experiences.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
Old 05-23-2013, 05:09 PM   #38
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
There's direct correlations and then theres 5th generation correlations, this was the later. Even apples and oranges are comparable.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-23-2013, 05:26 PM   #39
wheelhaus
wheelhaus's Avatar
...Foot print increases with diameter of rim as well but I want to stay 17"
Incorrect. Diameter of the rim (i.e. 17" vs 18") does not affect the tire's contact patch (or "footprint"), unless you install a tire with a larger outer diameter. If you upsize the rim, you should use a tire of the same outer diameter to maintain speedo readings. This of course means the tire will have at minimum a different aspect.
Consider a 4 wheeler as an extreme example, a factory truck may come with 20" wheels and street tires, and have a contact patch the size of a couple baseball cards. The same truck built for 4WD trails might have smaller 16" wheels mounted with gigantic 40" tires that have a monstrous contact patch.
The Following User Says Thank You to wheelhaus For This Useful Post:
Adeets (05-23-2013)
Old 05-23-2013, 06:38 PM   #40
tg_1981
i've been running dunlop direzza z2 245/40/17, on gram lights 17x9 57dr's. No problem hooking up here on map 3.
tg_1981 is offline   Reply With Quote
Old 05-23-2013, 06:41 PM   #41
SmsAlSuwaidi
Boosted
care to expand on your setup ?
Old 05-24-2013, 12:23 AM   #42
tg_1981
setup is listed below:
http://www.ft86club.com/forums/showt...it+Motorsports
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 03:36 AM
Wheel Size vs. Balance jellygorilla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-11-2012 01:23 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
