Old 05-23-2013, 02:54 AM   #15
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
Off topic, but what suspension are you running? Your car sits perfect!
Low&Slow is offline   Reply With Quote
Old 05-23-2013, 03:08 AM   #16
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Actually... if that happens the TSC is suppose to kick in and brake a little so the wheel on the ground will have traction... thats what mine does... but if I do the pedal dance the TSC wont turn on and do exactly what yours did.
Even if you have TSC off it shouldnt do that... only after doing the pedal dance your car wont do that.
RAWR BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to RAWR BRZ For This Useful Post:
636 (05-23-2013), Bristecom (05-23-2013)
Old 05-23-2013, 03:12 AM   #17
636
636's Avatar
Drives: '23 CWP BRZ
BC Racing Extreme Drop coilovers.
Thanks!
636 is offline   Reply With Quote
Old 05-23-2013, 03:14 AM   #18
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yeah, I would hope that they would have designed the TC/VSC to brake the lifted wheel in those situations to let the LSD work. But yes, I imagine you have to hold the throttle and let it spin a bit to activate. That's definitely the major disadvantage of a Torsen.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 05-23-2013, 03:29 AM   #19
RAWR BRZ
Mine acts almost immediately with flashing lights on the dash and the car jerks like hell like it is about to break something
The Following User Says Thank You to RAWR BRZ For This Useful Post:
Old 05-23-2013, 03:57 AM   #20
636
636's Avatar
Drives: '23 CWP BRZ
Sounds about right..
Loud noises also, right?
Old 05-23-2013, 04:42 AM   #21
RAWR BRZ
Yeup lound grinding sounding noise.
636 (05-23-2013)
Old 05-23-2013, 05:20 AM   #22
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Nah, its about average. What makes it "good" IMO for snow is the weight distribution, and the fact it has no power so the accidental slippage of throttle won't do much.
For Scandinavian conditions, and the cars most people drive here, the Toybaru is below average on the following conditions:
Ice/packed snow: Suspension too hard, and the AT shifts too hard even in "snow" mode, AT must be manually locked in gear to avoid accidents around corners and up/down hills.
Loose snow/slush: Too low ride heigt, even at stock, floats and loses traction.
Conclusion: The Toybaru is not unusable in winter, but compared to most new Subarus and Toyotas sold here it is not a good winter car.
I will nonetheless enjoy driving my GT86 through the winter, and I will be constanly looking for empty, iced parking lots...
