#29 | ||
Drives: '93 Toyota MR2 - V6
Toyota leans extremely hard on dealerships to not perform warranty repairs unless absolutely necessary. If a TSB exists for a concern and a VIN range is specified, Toyota will oftentimes decline to authorize payment for a warranty repair. Dealerships do not have carte blanche to throw parts at cars and have Toyota corporate pay for them. "Free $$$" for the dealer actually isn't that much money either since they have to buy the part from Toyota, charge minimal mark-up and Toyota warranty labor times are very low compared to normal customer pay warranty times. For example.. it might cost a customer 1.5 hours to have a water pump changed but Toyota will only pay .8 hours. Toyota has, in the past, cracked down on specific dealers that performed lots of warranty repairs and audited those dealers previous repairs as well, charging the dealership back when they found improper documentation of Complaint/Cause/Repair (aka CC&R) or even missing "mileage out" on repair orders. They get very nitpicky.. They are a business and businesses do not make money by giving stuff away. |
#30 | |
Drives: Attitude
#31 | |
Drives: Supercharged Golf Cart
Good. Everyone with even an ounce of auto knowledge knows that the books used to determine labor hours are exaggerated by a factor of 2-3 times! If your statement is correct, they're still making profit from unspent labor hours than needed. |
#32 | |
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Other cars with direct injection has the cricket noise also, maybe not all, or not in other places(higher octane gas?), but when I heared it on a kia w/di, and even on a lexus is(not sure is 250 or 350) that was idling, I was preety much convinced. Some or most of us here is new to Direct-Injection technology, preety much the first car owned w/Direct injection, so we wear some thing not normal does not mean something is broken or something is wrong.
I.G. @mytoy86
#33 |
Hold on.....I found a picture of a 2012 FR-S:..wait...what.......that's not a 2012? |
#34 | |
Toyota Master Tech
Drives: Whiteout MT
#35 | |
Further, warranty times are typically times that are so low that they assume the technician in question has done the repair before/knows each step of the repair exactly. In the case of new models and low-volume models (both of which the FR-S is), a technician is going to be doing pretty much any repair for the first time. To make matters worse (for Scion owners, anyway..), the FR-S is virtually all Subaru and very little about it crosses over to Toyota in terms of maintenance familiarity. Having said all that it's not surprising that a dealership would want to avoid unnecessary warranty repairs on an FR-S at all costs. |
#36 | |
And here's why your statement is false: has anyone here actually gotten a "refund" on the unspent labor hours when the job did in fact take multiple times less than the book quoted? I think the answer is going to be a unanimous NO. They claim it takes 3 hours, they call you back with the car ready to pick up after 1 hour...you still paid for all 3. Obviously it didn't take 3 if it was done in 1...so why do they charge the full amount? Because the book is full of shit! It was written with a first time mechanic using hand tools AND taking both a shit and lunch break in mind...working out of a broken garage. |
#37 | |
Drives: '13 FRS - STX
Dad's F150 was running poorly, would die while cruising out on the freeway. Temporary solution was to pull over, let the car sit for about five minutes and dust off the air filter. Went to a dealership since they treated us well under warranty with little things and the diagnoses was "#x coil pack is dead, needs replacement" (coil pack had something to do with the spark plugs iirc) Cost to fix? $600-$900 bucks, (can't remember it was almost a decade ago). How'd they diagnose it? They pulled each coil pack individually and replaced it with a new one until the truck was running properly. How much did the diagnoses cost? $60 Laughed, drove it home, bought a coil pack at Craigens and a couple weird extensions to get around the stuff in the engine bay for less than $100 and did it over the weekend. He's done it 2-3 times since then on his own.
#38 |
#1362
Drives: 2014 Ice Silver WRX
i thought it was decided among the forums that ethanol free gas was the only solution to this
#39 | |
Real world example: It pays ~3.5 hours to change the timing belt on a lot of Toyota cars/trucks/vans/SUVs/etc. If I set you up in my garage at home with the factory repair manual and all of my tools (yes, even air tools), do you think you could change the timing belt in my Camry in 3.5 hours? This includes: - walking to the back yard to get the repair order (like walking to the office in a professional shop) - walking to the front yard to get parts - going across the street and halfway down the block to get the car, pulling it into the garage - doing all the work, not screwing it up or getting the car dirty - road-testing the car - filling out paperwork - walking back to the garage to begin your next job I can do most Toyota timing belts in under an hour. Because I've done them a zillion times before. Does that mean I should only charge an hour of time for my expertise? And for the record, when it comes to diagnosis, I often don't use up the full estimate when it's something ridiculously fast/simple like a loose gas cap. YMMV, everyone's different. |
| The Following User Says Thank You to Conor For This Useful Post: | CamryDS (05-22-2013) |
#40 |
Just drive it
Drives: 13' FR-S
My car was assembled in 12/12, so technically I guess it's a 12' car.
#41 |
Hey guys, just so you know the TSB replaces the high pressure fuel pump that you are getting the chirping from but I can assure you the chirping is ,unfortunately for us all, normal. The TSB replaces most of the early release buyers pumps which had what they call an abnormal chirping sound. I'll try and upload the video we get for our TSB tommorrow. Trust what the rest of the guys who have been thru this have told you though, its normal and unless you purchased yours fairly early after it released, thats probably the sound you will hear for awhile. If your car applys to the fix the parts guys can easily tell once your VIN is put in our systems. If it doesn't anything they replace will more than likely give you the same effect.
#42 | |
Drives: 2003 Camry Blue | 2013 FR-S White
Since i've been doing work on my own car, I look at mechanics with a whole new point of view. Though I still hate the stupid ones. |
| Engine idle chirping (cricket) noise poll. | Hanzo | Issues | Warranty | Recalls / TSB | 5031 | 05-18-2017 09:41 AM |
| Engine idle chirping (cricket) noise poll. | Hanzo | BRZ First-Gen (2012+) — General Topics | 229 | 02-16-2016 01:21 PM |
| P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? | Xdragonxb0i | Engine, Exhaust, Transmission | 23 | 04-24-2013 12:29 PM |
| 2012 or 2013 Build? | benoh | AUSTRALIA | 16 | 09-27-2012 12:56 AM |
| USA get 2013 Aus get 2012? | Toy86 | AUSTRALIA | 13 | 06-21-2012 01:00 AM |
