Old 05-21-2013, 06:08 PM   #309
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Sniper2606 View Post
By adding the SC kit do we still use the stock 0-20w oil? does it change the 3k mile change?
How often does the SC kit need maintenance?
Oil change interval is not 3K miles, its 7500 miles. You also keep using 0w-20
Old 05-21-2013, 06:30 PM   #310
Foobar
SLO NO MO
Foobar's Avatar
SC needs its own oil change at 2.5k then every 7.5k thereafter. Best to try and coincide it with your engine oil change.
Sent from my Nexus 7 using Tapatalk 2
Old 05-21-2013, 08:26 PM   #311
Sniper2606
Sniper2606's Avatar
Right, sorry 3k is for first oil change
Sniper2606 is offline   Reply With Quote
Old 05-22-2013, 12:30 AM   #312
Dezoris
Dezoris's Avatar
Has anyone done a UOA on their car with a Vortech yet to confirm that the extra heat etc is not breaking down the additive packages faster? Given how hot the oil runs why is it better to keep 0w20?
Old 05-22-2013, 07:49 AM   #313
Sportsguy83
Drives: Limited BRZ
I didn't mean to say 0w-20 is better, just that you can still use it. For someone who drives HARD (and I know you do) go minimum 0w-30. Did you add a Catch Can for the breather? I know you had one already for the PCV. I'm turbo and running 0w-30.
Old 05-22-2013, 09:16 AM   #314
DJCarbine
Thupercharged
DJCarbine's Avatar
Where is the best place to install a catch can? The PCV line (which has the checkvalve included in the vortech kit) or the breather hose that goes to the airbox?
I'm assuming with the checkvalve there is no airflow in the PCV line during boost, so does it makes more sense to have a catch can installed on the breather hose?
DJCarbine is offline   Reply With Quote
Old 05-22-2013, 09:35 AM   #315
Sportsguy83
Drives: Limited BRZ
When you go FI, on both.
Old 05-22-2013, 11:45 AM   #316
Dezoris
Dezoris's Avatar
Thats probably what I will wind up switching too. Trying to figure out the oil cooler situation as well.
I have the catch can on both lines now PCV and Breather.
Old 05-22-2013, 02:01 PM   #317
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
I think mobil 1 ow20 doesnt suffer performancewise till up to 400 degrees but i cant find anywhere what the optimal operating oil temp for the engine is.
Darryljr11 is offline   Reply With Quote
Old 05-22-2013, 03:42 PM   #318
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Has anyone experimented with dual maps for the Vortech / EcuTek setups? We don't have E85 here, at all, its simply not available and its not feasible to drive to the states to fill up.
That being said, seeing the difference between the stg 1 pump gas setup (250whp) and the e85 setup by a fellow member (370whp) has me thinking of options the last while.
Its possible to run Water/Meth injection to boost the octane level, that's easy enough. But how does a fail safe system work with the vortech unit? You can't exactly cut boost like you can with an electronic boost controller. Can we pull enough timing to make it safe on pump gas? (either the stock or smaller pulley).
What I'd like to run is a WMI setup with a fail safe that switches to a second non WMI map that is nice and safe to daily drive around. Then down the road I'd like to wire my own flip switch that would a) put the ecu in non WMI mode and b) disable the WMI pump so that I can drive around daily and not burn water/meth all the time since the supercharger is always in boost (though with the bypass open this might not be needed at all?) . Basically only use it for track / spirited driving use, similar to how nitrous systems can be armed and used whenever needed.
The flip switch part would be a later addition, right now I'm just trying to figure out how EcuTek would play with a dual map setup. Given the FlexFuel setup @Visconti is doing, I'm assuming there's a way to run dual maps off an external trigger?
pheoxs is offline   Reply With Quote
Old 05-22-2013, 04:23 PM   #319
Raven604
This is exactly what I am looking to do also. WMI with his kit on 94 should hopefully put me close to 300whp with exhaust and fuel mods. That would be ideal.
Sent from my Galaxy Nexus using Tapatalk 2
Raven604 is offline   Reply With Quote
Old 05-22-2013, 05:21 PM   #320
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Couldn't you just run an electronic boost control valve, and when your under say E40 limit the boost to 10lbs, and then when your over E40 allow it the full 13psi, or what ever the 2.9 pully equates to?
@Visconti @moto-mike @Brian@Vortech
I use E to symbolize your switch on/map 1 or your switch off/map 2
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-22-2013, 05:33 PM   #321
pheoxs
That's possible, I know Gem was working on a waste gate on his supercharger but I haven't followed that thread much lately due to various things that happened plus been busy.
Based on what I've looked at, even with the same sized pulley, you can make a lot more power on E85 due to already pulling timing as the boost builds up on 94. You can see this in any of the pump gas tunes, the torque curve levels off way too soon even though the unit is building boost up, running E85 or 94/WMI will let me make way more top end power even without swapping to the smaller pulley.
Old 05-22-2013, 05:50 PM   #322
Adeets
OEDC
Adeets's Avatar
I think I would rather run the pully to utilize e85, and clip the boost progress with an EBC when running E10 then let the car pull the timing to cope with the extra boost being shoved down its throat.
@moto-mike @Visconti @Brian@Vortech
How hard could this be? And the EBC locate it on the inter cooler, so it does fuck with the throttle body flow?
@2forme can you contact gem and find out if he's completed this yet? Have him throw me a PM, also while you had your vortech did you try something like this?
My BRZ FI Build
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
