Old 05-20-2013, 12:34 AM   #5125
troek
troek's Avatar
Drives: 2012 Toyota 86
dang that looks nice. is that 93 tune with all ur bolt ons?
troek is offline
Old 05-20-2013, 03:21 AM   #5126
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by troek View Post
awesome, good to know. you dynoed ur car with that tune yet?
nop. i haven't and not planning to for a while.
butt dyno feels good tho lol
Nardi330 is offline
Old 05-20-2013, 04:38 AM   #5127
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Stg1 pumpgas tune
Received my first ROM file from John, loaded fine.
Waiting for John to check my datalog and ROM file as I think i have a problem, as I cant select maps and I can get 8000rpm in all gears.
Decided to do a quick dyno to see what results the tune made and was pleasantly surprised. 11wkw gain over OEM.
I have the Works DIF and the BRZ performance exhaust made in SA, which is decatted front pipe and resonated back. I'm also using 98 RON.
for interest I have dyno run each time I have added
Stock 115wkw
Works DIF I gained 3wkw against OEM = 118wkw
Works DIF and BRZ exhaust gained 4wkw against OEM = 119wkw
Works DIF, BRZ exhaust and stg1 tune 11wkw = 126wkw
I have just received the Borla header, which I will fit once I have the Tune working correctly and dyno again.
Ryan86 is offline
Old 05-20-2013, 09:14 AM   #5128
Opposed
Drives: 2013 Asphalt FR-S
The 93 dyno run was only the tune, stock everything else.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 05-20-2013, 12:27 PM   #5129
troek
troek's Avatar
awesome! i was really hoping that was the case. mid 180s wouldnt be unreasonable with full catless exhaust and drop in filter then im hoping.
troek is offline
Old 05-20-2013, 04:13 PM   #5130
Visconti
Drives: 05 STi
Thanks for the posts
Can't wait to get feedback on my new tune that hasn't been released yet
John
Visconti is offline
The Following 4 Users Say Thank You to Visconti For This Useful Post:
JiB (05-21-2013), Opposed (05-20-2013), tripjammer (05-20-2013), troek (05-20-2013)
Old 05-20-2013, 04:29 PM   #5131
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
John
Well any of the new tweaks end up in the vortech tune eventually?
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline
Old 05-20-2013, 10:07 PM   #5132
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
What's the newest version of EcuTek software? I can't seem to get above 1.0.0.12275 no matter how many times I try to update it.
iketiak is offline
Old 05-21-2013, 12:03 AM   #5133
KamalT
Drives: Pearl 86 GT
Having an issue with starting my car from cold. Temp 5" (41F). Cat will not swing. Have to try 3-4 times before I hear a slight pop and then it will work. Trying not to burn starter motor. But that is yhe only way. Remember US guts J ad similar issues when you had your winter.
What did you do to fix issue. I am running e85. Is this the issue and should i use e70. When car is warm there is no issue starting it.
ps. I have submitted but car is kinda dead in the water at the moment.
White GT | Visconti_TUNED
KamalT is offline
Old 05-21-2013, 12:11 AM   #5134
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
John
Yeah John.. just keep on teasing...
Do you think you'd be in Annapolis late June/early July? I'd want to see what you can do with live tuning my NA car. It'll have a relatively unique setup that I think will run well with e85.
- FA20CLUB CAI
- JDL UEL Header
- 2.75" Overpipe-back exhaust
It should sound pretty badass on the dyno!
- Russell
TyperRspec789 is offline
Old 05-21-2013, 12:47 AM   #5135
iketiak
iketiak's Avatar
Originally Posted by Carwhisperer View Post
Same boat, once it downloads and says its complete, I click, "Check updates" and downloads it again. Never seen it do this before.
But you are still able to connect and query your ECU?
iketiak is offline
Old 05-21-2013, 12:51 AM   #5136
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Latest version of EcuTek software is 1.0.0.12458.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline
The Following User Says Thank You to Apoc For This Useful Post:
iketiak (05-21-2013)
Old 05-21-2013, 03:02 AM   #5137
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
How long is the wait usually to receive your map after receiving the ecukit in the mail?
Build Thread
Instagram
midnight23 is offline
Old 05-21-2013, 03:41 AM   #5138
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Did you submit a ticket on his website to let him know you have the kit?
JimmyMac is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
