Old 05-15-2013, 10:17 AM   #211
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by cslntuee View Post
HI,
I have a question for the TRD intake.
How much for order an EmissionsCompliance Label form local Toyota/ Scion dealer?
Thanks.
Sorry, I don't know as my state doesn't require it. I thought I read somewhere that you just need to request it and they will provide, nobody mentioned any extra cost.
The Following User Says Thank You to switchlanez For This Useful Post:
cslntuee (05-15-2013)
Old 05-16-2013, 04:12 PM   #212
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
HI,
Thanks.
Per the install instructions:
Emissions Compliance Information:
A new process has been implemented. The
Emissions Label is No Longer included in the
Performance Air Intake Kit.
If your state requires an Emissions
Compliance Label, one may be ordered
through your Scion dealer or the Toyota
Materials Distribution Center (MDC)
310-468-9800 or
MDC@toyota.com
This TRD Performance Air Intake Kit has
received 50-State Emissions Compliance via the
California Air Resources Board (CARB). Not all
states require the Emissions Compliance Label
but TRD does recommend ordering one. To
receive the proper Emissions Compliance Label
for this TRD Performance Air Intake Kit, please
order MDC part number
00602-21140. Proof of
ownership may be required.
Beyer Subaru is offline   Reply With Quote
Old 05-16-2013, 04:50 PM   #213
cslntuee
Drives: Subaru BRZ Limited
Actually, I am asking how much I need to pay when I orderthrough the local dealer?
I am trying to find the lowest price on EBay. Some vender providethis service and some this not.
I need to consider this price, in order to know which thebest price is.
Thanks.
310-468-9800 or
MDC@toyota.com
cslntuee is offline   Reply With Quote
Old 05-20-2013, 01:31 AM   #214
switchlanez
Since I've slowed down on my modding, I've been collecting this junk lol. The mechs are from a Japanese arcade/anime called Gyrozetter - Orange=transformed form of an 86, Blue=transformed form of a BRZ, red=Raibird (fictional supercar, main character). Also got some Hachirokus, 2000GT, and an "infamous" Supra by Hot Wheels.
ill86 (06-16-2013)
Old 05-20-2013, 01:33 AM   #215
switchlanez
Very recently, I've found new ways to blow some money. Got Weathertech mats to make cleaning easy and this:
It's lighter (I estimate 25% to 33%) than the stock wheel. The girth is about the same as the two lumps on the stock wheel's 2 and 9 o'clocks but uniform throughout. I like the form of it over having 2 lumps but that introduces an ergonomics issue. When I drive for an extended period with my hand not turning the wheel (like on a highway), I tend to pistol grip the wheel. My hand started to cramp because of this wheel's thickness. But it is 5mm smaller in circumference than stock (360mm v. 365mm). That difference wasn't too noticeable when I first put my hands on it. But when I started driving, steering felt a touch more nimble and direct. Very subtle. I paid $500 for this (+100 shipping from Japanparts). Without the branding, I feel something like this would be more worth $300-$400.
Tom's tail lights due out in July are up next. Then I should be done for awhile.
Old 05-20-2013, 01:59 AM   #216
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
Tom's taillights are the ones I want as well. Impeccable taste! Keep up the good work.
The Following User Says Thank You to BugeyedWagon For This Useful Post:
switchlanez (05-20-2013)
Old 05-20-2013, 11:15 PM   #217
cslntuee
Did you get better mileage (or worse) after installing TRD intake?
Thanks.
Old 05-21-2013, 03:59 AM   #218
switchlanez
Thanks.
I don't pay close attention to my mileage so I wouldn't know. If anything, it might be worse but more due to my driving habits... I press the gas a bit more spiritedly because I like the sensation of extra punch from the throttle. I thought I read in the engine mods section that it preserves the stock a/f ratio and doesn't run lean (that's also why people said it won't benefit much from a tune). If it provides more air, then it must burn more fuel to maintain the same a/f ratio. That extra kick on throttle input is the result.
cslntuee (05-21-2013)
Old 05-21-2013, 10:06 PM   #219
cslntuee
Sorry for bother you this question again.
Did you still recommend the TRD intake, if stock a/f ratio doesn't run lean?
I did interested to remove the sound tube.
However, I am not sure that just simply buy the Silicone Intake Pipe as below.
http://www.zetaperformanceltd.com/ou...nings-218.html
http://www.perrinperformance.com/brz...brz-inlet-hose
or TRD intake.
What’s your suggestion and opinion?
Thanks a lot.
Old 05-22-2013, 12:13 AM   #220
switchlanez
or TRD intake.
Thanks a lot.
Yes, I highly recommend the TRD intake if it keeps a/f ratio the way the factory intended because that indicates normal operation whereas running lean is abnormal.
I haven't researched those other intake pipes enough to give you an informed opinion on how they compare. My initial opinion is they may improve airflow but the amount of air provided thru them may not be as much as the TRD intake. One advantage is the TRD is warrantied for Scion whereas those other intakes aren't. Not to say the TRD intake will be bulletproof but it must have gone through some sort of rigorous development testing to qualify for an OEM warranty even though it doesn't apply to me (Subaru).
cslntuee (05-22-2013)
Old 05-22-2013, 07:06 AM   #221
cslntuee
HI,
Do you know, normally (or from the history) will Subaru (orSTI) release the upgrade intake for their stock car?
Thanks again.
Old 05-22-2013, 11:25 AM   #222
switchlanez
HI,
Thanks again.
I don't think Subaru ever has and from STI's website, it looks like most of their other cars only have an air filter upgrade: http://www.sti.jp/parts/catalogue/index.html
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
cslntuee (05-22-2013), humanshield (05-23-2013)
Old 05-25-2013, 02:01 PM   #223
Beyer Subaru
Yep, they've never released an intake. The OEM intakes for the WRX/STi are designed to support up to 350 wheel hp and will only become a bottleneck at that type of wheel power.
The closest USDM thing that I've ever seen is the SPT Intake that looks a lot like a rebadged K&N Typhoon.
The closest JDM/EDM thing that I've ever seen is the Prodrive Intake that was a rebadged AEM Intake.
Both were released for the turbo'd Suby's.
Old 05-25-2013, 07:14 PM   #224
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Andrew, you going to Scoobapalooza?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
August 1st Charity Lapping Day - Subaru Canada - Davenport Subaru - SPDA - TSC wparsons CANADA 10 07-22-2015 01:24 PM
Subaru Cross Sport Design Concept = Subaru BRZ Shooting Brake Hachiroku BRZ First-Gen (2012+) — General Topics 91 04-01-2014 06:53 PM
Subaru LIBIRD Supercar Concept & BRZ (April Fools) switchlanez BRZ First-Gen (2012+) — General Topics 18 04-15-2013 02:20 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
