#29 |
Pegasus White
Drives: 86
If the rack is electronic why can't we use something like ecutek to modify it to make it a stiffer feeling?
Driving: Pegasus White Manual GTS 86.
#30 |
Because compromise ®
Drives: Red Herring
#31 | ||
Drives: Red Herring
Different tyres, bushes and springs. I'm not sure about the suspension geo. Quote:
Maybe these solid steering rack bushes would assist: http://turninconcepts.com/product_in...oducts_id=1260 http://turninconcepts.com/product_in...oducts_id=1270 Review for the aluminium bushes here: http://www.ft86club.com/forums/showthread.php?t=27727 Last edited by Captain Snooze; 05-20-2013 at 07:35 PM. |
#32 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
TiC steering rack bushings do help give the car more feel of what the tires are doing...I just installed mine this weekend that I purchased from the initial group buy many months ago. Really wish I had done so sooner! Running the stock tires slightly stretched on lighweight Enkei Fujins (17x7.5 with +40mm offset) and I love how the handling is now more than ever with the bushings installed. I notice that there seems to be more front negative camber as well, which is reasonable due to the fact that the steering rack is slightly higher than it was with the stock rubber bushings - slightly pushing the tie rods up and out more. Front camber seems much closer to what the rear suspension is (with completely stock suspension/ride height.) Really makes the turn in superb and so precise in comparison to stock...
Personally, 'tire feel' is not a big deal to me, as long as the chassis is communicating the tire grip and car balance that's all I really want. That said the FRS has plenty of tire feel to me with the stock tires. You'll need to get rid of all the isolating elements from the between the tires and steering rack if you want to feel the tires to the maximum potential of the vehicle - which means replacement of factory rubber bushings with stiffer, more rigid materials. Front control arms with spherical bearings would be the extreme way to go all out and reduce isolation points to the absolute minimum - making as direct an energy pathway from the tires to steering wheel as possible. A well engineered chassis bar would probably help out some as well.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#33 | |
http://www.autospeed.com.au/cms/A_111532/article.html It is basically is a piggyback setup and one can tailor it to what they want, not that hard to do either. Ultimately it isn't really what I was after, I really wanted the full lock-1 turn so the suggestion of machining a new rack and pinion is a much better option. |
#34 | ||
Drives: Subarus
| The Following User Says Thank You to EarlQHan For This Useful Post: | s2d4 (05-21-2013) |
#35 |
The manual already states that the motor might overheat and increase steering effort in hot weather and lots of low speed driving with lots of steering, decreasing the ratio in the rack by about 30% (stock it's 1.5 turns from center to lock) will probably put too much load on the motor.
#36 | |
The quaife kit for AE86 and the AW11 is actually the same, sell like hot cakes worldwide... If you guys do one, I would buy it.
#37 |
Drives: GT86
Is it possible that the rack is stiff when brand new? Perhaps explaining my relative disappointment compared to other testimonies?
I had another car that had this effect, not much feel in the beginning, after 6000miles or so, it loosened up and really started talking to me... |
#38 |
Drives: GTS 86 Galaxy Blue
I think you will find a big difference once you change to stiffer springs. A bigger front sway bar will also sharpen the steering feel. I have just got the whiteline rack mount bushes and look forward to see how much they sharpen the feel along with the perrin lower arm bushes.
As I understand the engineering of the front lower arms they wanted the car to basically under steer in initial steering then by making the bush flex it turned in better. Changing that bush should make a difference to that initial turn in softness you may be feeling. |
#39 |
Drives: 1
Could you please expand on this a bit more? I thought the sizing, etc. was identical? Mine's being shipped over at the moment and hopefully I can do the install this weekend.
#40 |
Drives: GT86
Steering rack/rod geometry has no influence on camber, only toe in various flavours (different dynamoc situations). Let us know how the upgrade feels!
#41 |
/dev/null
Drives: Uphill
Hej 37:an, tjänare! :-)
Are you still basing your judgement on that single test drive? I would seriously consider doing another, in a GT86 with at least 5000km on it. I am saying this because in my case, the steering wheel "feel" has either improved a lot or I have become more attuned to it. Basically, I love the way my 100% stock GT86 talks to me. It's a beautifully engineered car IMHO. |
| The Following User Says Thank You to Sarlacc For This Useful Post: | PowderfaceTr. (06-16-2013) |
#42 |
Drives: GT86
Tjena
![]() Actually I did already and it didn't bother me as much as before. So now I think I will be happy with a stock set-up! I guess one will adapt, I also suspect it was because the first car was so new it was a bit stiff, the latest one had some miles already, bit hard to tell for sure... Although I would want to try the steering rack bushings, seems too easy mod to not try... |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| Feel sorry for guys in LA | Pscylo | Southern California | 16 | 08-21-2012 10:26 AM |
| does rwd LSD feel the same as fwd lsd? | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-13-2012 08:04 PM |
| Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) — General Topics | 8 | 12-08-2011 11:16 AM |
| Stock suspension adjustability? | #87 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-02-2010 04:36 PM |
