Old 01-22-2013, 06:16 AM   #43
-max-
Drives: Firestorm FRS
Originally Posted by Yumcha View Post
hey bud did the focals fit well?
also looking to get these for the doors
Fit fine with a 3/4" baffle.
Didn't really care for the krx2s little harsh in the midrange. Earlier k2ps I had were much better.
-max- is offline   Reply With Quote
The Following User Says Thank You to -max- For This Useful Post:
Yumcha (01-26-2013)
Old 01-22-2013, 10:29 AM   #44
Z0rr0
Drives: 2013 Raven 6MT FR-S
Originally Posted by cabasse View Post
goddamn that is a lot of money to pay for a pair of 3.7" paper drivers... still, they look very very high quality. were they a drop in for the midrange unit?
i'm 2 weeks into owning this thing and i'm already trying to figure out what i'm going to do to fix the audio...
yes, they fit perfectly.
yes, they are expensive, but they sound phenomenal!
Z0rr0 is offline   Reply With Quote
Old 02-17-2013, 03:55 AM   #45
Redmist
Drives: Galaxy Blue BRZ
Originally Posted by Z0rr0 View Post
I have Hybrid Audio L3SE's in the dash. 3.7" Wideband driver.
I am going to put in my L6V1's in the doors this weekend.
Are those drivers 7.1" ? Did you manage to get them to fit?
Redmist is offline   Reply With Quote
Old 02-19-2013, 10:43 AM   #46
Z0rr0
just made my own baffles, used the stock speakers as a template.
worked great.
Old 05-19-2013, 10:22 AM   #47
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by so26 View Post
Yes, both the tweeter and mid in the dash are 4ohms but connected in parallel therefore the HU sees a 2ohm load for the pair.
I know I'm doing a Lazarus number on this thread, but as it is listed as a resource, this needed to be addressed.
If I understand the setup correctly, there are passive crossovers for these speakers. That means the amp is only "seeing" them for a limited portion of the sound spectrum. I don't know what the actual points are, but for example, the mid might be seen from 500 to 4000 hertz and the tweeter from 4000 to 20000. Together they present a load from 500 to 20000. Unless there is an overlap between them, you don't add the loads together. This is because a capacitor is essentially an open circuit below its crossover point.
Think about it, when you buy a component set, it has two drivers of a particular impedance with a crossover and you don't add those together to get the rated ohms, do you?
mid_life_crisis is offline   Reply With Quote
Old 05-20-2013, 09:21 AM   #48
so26
Drives: Raven FR-S 6MT
Yes I over simplified the situation. I believe the impedance of tweeters are rated at ~5kHz and small mids are rated at ~1kHz. So yes your point is valid but you are over idealizing the situation. The simple RLC filter setup in our speakers will not produce a sharp impedance vs frequency response.
so26 is offline   Reply With Quote
Old 05-20-2013, 11:36 AM   #49
mid_life_crisis
There are too many people on this site who have no clue that impedance changes with frequency and would take the original statement at face value.
I made the post because I was concerned that someone who didn't know better would read the original and mistakenly believe the H/U was intended to drive a 2 ohm load.
The Following 2 Users Say Thank You to mid_life_crisis For This Useful Post:
Rinzler (05-20-2013), SirBrass (01-08-2014)
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Initial D Stage 5 release this year! 5hairpins Off-Topic Lounge [WARNING: NO POLITICS] 279 07-24-2014 09:41 PM
Exhaust Stage enkubus Engine, Exhaust, Transmission 3 08-14-2012 09:31 PM
Initial D stage 5 86boyAF1 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-08-2012 10:00 AM
Battle Stage 2 trueno86power Other Vehicles & General Automotive Discussions 2 09-26-2011 03:04 PM
