Old 05-19-2013, 08:26 PM   #603
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
This happen twice today
Will fix it tomorrowName:  ImageUploadedByTapatalk1369009596.684146.jpg
Old 05-19-2013, 08:50 PM   #604
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Will fix it tomorrowAttachment 37922
hmmmm pushing some PSI!!
Old 05-19-2013, 08:52 PM   #605
Sportsguy83
Drives: Limited BRZ
Guys, look at this video, either completely or press play to jump to the 1:14 Mark [ame="http://www.youtube.com/watch?feature=player_embedded&v=xEuNzNNcpw0#t=74s"]Jump To the 1:14 Mark[/ame]
The car under the tent is my BRZ!! We had an awesome meet today down here in South FL. This is the start of some great friendships!
Old 05-19-2013, 09:00 PM   #606
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@ 2:29 another boosted 86 ?
Old 05-19-2013, 10:14 PM   #607
Sportsguy83
Drives: Limited BRZ
Yes sir, @lexusb3 car with @FA20Club.com kit!! Very clean!
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
lexusb3 (05-19-2013), SmsAlSuwaidi (05-19-2013)
Old 05-19-2013, 10:16 PM   #608
lexusb3
Drives: FRS
blue car with the sticker on the front window.... i just talk to my boy he working on the video now and said its going to be amazing
lexusb3 is offline   Reply With Quote
The Following 2 Users Say Thank You to lexusb3 For This Useful Post:
SmsAlSuwaidi (05-19-2013), Sportsguy83 (05-19-2013)
Old 05-19-2013, 10:20 PM   #609
Sportsguy83
Drives: Limited BRZ
Can't wait!
Old 05-20-2013, 10:09 AM   #610
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Ok guys one more question and hopefully @King Tut can chime in
(Now with pics)
I know i have to cut the hose that goes from vacuum block to wastegate port but this house has a T that also goes to the BOV.
Sounds like David already fixed you up, but you only want the MBC to modify the vacuum/boost signal going to the side port on your wastegate, so you want it between any vacuum tee and the wastegate itself so all other items still see the full vacuum/boost signal. That is also the first time I have seen anyone grab vacuum from that location. Where does the other end of that hose go to?
Old 05-20-2013, 10:12 AM   #611
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Lookin at that clamp and the fact that it looks fully compressed, my guess would be that you don't have the right size T bolt clamp for that size pipe/coupler. Full Blown did not do a very good job sizing clamps for this kit as I have a couple that are fully compressed as well. My recommendation is measure it and order a slightly smaller one or find a shop that has them locally and get the next smaller T bolt clamp for that hose. Also, make sure that the pipe is far enough into the coupler that the clamp is behind the bead rolled portion of the pipe.
Old 05-20-2013, 10:36 AM   #612
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
no sure if it's supposed to be, but after seeing your kit yesterday im curious. where your intake connects to the silicon hose is it supposed to look so stretched? seemed like the fitment there was off or something
lbroskee is offline   Reply With Quote
Old 05-20-2013, 10:56 AM   #613
Sportsguy83
Drives: Limited BRZ
That inlet pipe is supposed to connect to the OEM airbox, so I'm running a never test fitted setup. Perrin's CAI matted to AVO inlet pipe, that is why the fitment is not near perfect, but it works.
Old 05-20-2013, 10:58 AM   #614
lbroskee
lbroskee's Avatar
o ok. i thought perrins was setup to the oem inlet
Old 05-20-2013, 11:02 AM   #615
Sportsguy83
Drives: Limited BRZ
It is, but remember the OEM inlet is very flexible contrary to the AVO piping which is not. That coupled with the fact the AVO pipe connects below to the turbo and all the routing it takes, is bound to throw its exact location off a bit.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
lbroskee (05-20-2013)
Old 05-20-2013, 12:02 PM   #616
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Goes to vacuum block
Is that oK? Or should i do something about it?
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 10:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 02:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 07:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-12-2012 11:35 PM
