Old 05-19-2013, 02:47 PM   #1
Drftfan
Drives: Argento FR-S
I like smallerish wheels especially for drifting
I am leaning towards just going with a 17x9 wheel and using the stock tires. I left the Japanese car scene for about 6 years or so. As I am getting back into it with my FRS I have started looking around after different wheel options and since I am a huge drifting fan, hence my handle, having smaller diameter wheels with thinner tires should make it a much easier car to drift until I boost it.
Anyone else into drifting follow my train of thought on this?
With my sr swapped s14 240 I was only running 15 inch rims with about 230 hp give or take with the red top and what minor mods I had.
Seemed to work fine then so wondering why everyone goes to 18 inch rims nowadays. Maybe I am a little more old school.
Drftfan is offline   Reply With Quote
Old 05-19-2013, 02:53 PM   #2
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Doesn't take much to drift this car, the difference to 17 to 18 inch wheels won't make that much of a difference.
A lot of people are more into tracking this car then just drifting it, i'm a mix of both. Though i'm parital to 18 inch because the wheel i want is only in that size, i don't mind.
Though i'd love to see more people running 15's!
Also i wouldn't recommend the stock tire of drifting, assuming your going to buy more sets of them. They are quite expensive, its a MPG tire. Theres better non grippy tires that you can get for cheap.
Old 05-19-2013, 02:58 PM   #3
Drftfan
No once these wear out then I will buy new ones. Then I may looking into jumping to an 18 for dd then 17's for drifting. I was looking at the rocket bunny running those ultra wide 16's and it just looks sick to me.
Old 05-19-2013, 03:44 PM   #4
fatoni
how will a smaller diameter make it easier to drift?
Old 05-19-2013, 03:56 PM   #5
Drftfan
I can't say it makes it easier other than from a weight savings standpoint. Typically though when going up in diameter most people go with a wider tire which adds more contact patch which theoretically would make it more difficult to get the tires to break loose.
I am just looking at all options at this point. On some frs with 17 inch rims they look too small vs. some it looks perfect.
Old 05-19-2013, 04:15 PM   #6
mrk1
Drives: Sterling BRZ Ltd
I like to run the smallest wheels that will clear the brakes. For me that's 17 with the stop techs. I love a meaty 17 any day.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-19-2013, 05:32 PM   #7
fatoni
well less weight makes everything better but you arent confined to what people typically do so just buy what you want. most decent drifters ive encountered like more grip, not less. my advice would be not to waste time on rims if you are going to run the same tires instead of buying wider rims despite not wanting wider.
Drifting frosty86 Off-Topic Lounge [WARNING: NO POLITICS] 8 11-14-2012 09:04 PM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
Keep Drifting Fun coyot BRZ Photos, Videos, Wallpapers, Gallery Forum 4 05-21-2012 01:54 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
