Old 05-17-2013, 07:45 PM   #29
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
I agree, but it'd be nice to have better options around here.
Eh, until someone posts dyno sheets I doubt that you'd notice using your butt. My money is on < 5hp increase at most. I'd certainly buy it if it was available but I'd consider using 91 for daily driving.
Anthonytpt is offline   Reply With Quote
Old 05-17-2013, 09:31 PM   #30
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Originally Posted by FRiSson View Post
"Essence" ?
I think he meant the mixture of aether, phlogiston and unicorn farts from the thaumaturge next the local pub.
Old 05-18-2013, 12:30 AM   #31
FRiSson
Drives: FR-S MT
Originally Posted by cwb48 View Post
Not a troll, just a European who doesn't get American English, lol.
Swedes aren't Europeans. They are Scandinavians. That's like calling someone from the US a "North American".
FRiSson is offline   Reply With Quote
Old 05-18-2013, 01:04 AM   #32
oTaGGeDo
oTaGGeDo's Avatar
Drives: Currently driving a 2013 turbo Tc
I use non ethanol 91 octane only pure-gas.org tells you locations with pure gas ethanol is terrible unless your car is setup to handle all of its downfalls ( better fuel pump,correct fuel Injectors, fuel lines made to withstand it and proper tuning) and most. 93 octane gas is simply 91 octane with ethanol added to it to increase the octane rating just an FYI
oTaGGeDo is offline   Reply With Quote
Old 05-18-2013, 01:55 AM   #33
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
I'd be surprised if there were any difference at all, honestly, especially if you aren't at sea level. The only reason there would be a power difference would be if the lower octane caused detonation (and thus the ECU had to retard the timings a bit). 91 should be high enough to avoid that except in possibly extremely hot, sea-level conditions. As was mentioned by a prior poster, here in Colorado, 91 is as high as it gets (since the altitude reduces octane requirements).
chrisl is offline   Reply With Quote
Old 05-18-2013, 11:14 AM   #34
cwb48
cwb48's Avatar
Drives: 2013 FR-s Firestorm
Someone from the U.S. is a North American.
cwb48 is offline   Reply With Quote
Old 05-18-2013, 11:38 AM   #35
FRiSson
Drives: FR-S MT
Yes, that's the point. But we call someone from the U.S. an "American".
Old 05-18-2013, 01:00 PM   #36
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
Originally Posted by l0aded View Post
Here in cali we get the worst... 91 octane max normally and up to 10% ethanol.
Same here in Arizona, wish I could get 93 prefer to be at recommended not min
Kwisak is offline   Reply With Quote
Old 05-18-2013, 01:04 PM   #37
bcj
Geo Tyrebighter Esq
bcj's Avatar
Now you're sucking in two whole continents 8)
Old 05-18-2013, 01:21 PM   #38
FRiSson
Drives: FR-S MT
Well, some would say it is an imperial prerogative.
But actually it is legitimate, since the USA is the only nation on the two continents that has "America" in its name.
E.G. "Brazilians" are from the "United States of Brazil".
Old 05-18-2013, 08:18 PM   #39
JLMtm
Drives: FRS
Where do you find grades higher then 91? That's all I have around here in northern San Diego , is 91 ok for the long run?
JLMtm is offline   Reply With Quote
Old 05-19-2013, 03:24 PM   #40
Nik33615
Nik33615's Avatar
Drives: 2013 FR-S MT
Did you forget about Central America?
Nik33615 is offline   Reply With Quote
Old 05-19-2013, 03:46 PM   #41
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by Logical View Post
Yes it does, just checked!
On a side note, I now know it's called a "fuel filler gun".
What happens if I continue to add more gas???
I always do this
Carlitoz3 is offline   Reply With Quote
Old 05-19-2013, 04:12 PM   #42
tomato88
tomato88's Avatar
Drives: Mazda 3
I always do this
You mean clicky clackity topping off? I heard that it is actually bad for the car as the overfilled fuel will evaporate and go to places that is not designed to go. Also you end up paying more for less gas as some of the fuel will shoot back into the pump.
tomato88 is offline   Reply With Quote
The Following User Says Thank You to tomato88 For This Useful Post:
Carlitoz3 (05-20-2013)
