Old 05-17-2013, 09:39 AM   #1
mrnibbs
Drives: ultra marine frs
gas
Sorry if this is somewhere already but I was unable to find. . Question is what gas do you use reg mid or premium or other and do you notice a difference....
mrnibbs is offline   Reply With Quote
Old 05-17-2013, 09:54 AM   #2
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
I always use 93. This motor has pretty high compression. Definitely don't use less than 91. Using too low of an octane will cause detonation in the cylinders (this is a bad thing).
FReSh is offline   Reply With Quote
Old 05-17-2013, 09:54 AM   #3
Brndn704
Brndn704's Avatar
I mean, doesn't the manual say use premium only?
Brndn704 is offline   Reply With Quote
Old 05-17-2013, 09:55 AM   #4
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Before someone sends the obligatory ,premium and nothing but. Minimum 91, but, 93 is recommended.
Demandred7 is offline   Reply With Quote
Old 05-17-2013, 09:57 AM   #5
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
93 all day.
FRSTRM is offline   Reply With Quote
Old 05-17-2013, 10:05 AM   #6
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
Doesn't it say it inside of the gas cap as well?
Enraged21 is offline   Reply With Quote
Old 05-17-2013, 10:50 AM   #7
shiud
Drives: 6MT Asphalt FR-S
believe so
shiud is offline   Reply With Quote
Old 05-17-2013, 11:29 AM   #8
Brndn704
Brndn704's Avatar
Yes it does, just checked!
On a side note, I now know it's called a "fuel filler gun".
The Following 3 Users Say Thank You to Brndn704 For This Useful Post:
CodyFRS (05-19-2013), Enraged21 (05-18-2013), Opposed (05-19-2013)
Old 05-17-2013, 11:35 AM   #9
wheelhaus
wheelhaus's Avatar
To elaborate on the why:
The difference between octanes is not necessarily more power, it's stability. Higher octanes are more resistant to preignition (knock, ping, detonation, etc), Which is where the mixture may ignite prematurely and momentarily force the crankshaft backward. This is bad, and could eventually lead to the engine beating itself to death. Higher octane ratings allow more aggressive tuning (spark timing, fuel ratio, higher compression, forced induction, etc) because the mixture will ignite when the spark is fired, not a moment before. The ECU has a window for some of these parameters, and it will reduce their values if it detects preignition. If it detects none, it will continue to improve it's parameters until it reaches it's programmed limit. More aggressive tuning is what makes more power, whereas a higher octane rating is simply what enables it.
As everyone has stated, for the 86, "premium" fuel (91+) is necessary for the engine to perform well. Lower octanes could preignite, and cause the ECU to retard timing and run a little richer.
wheelhaus is offline   Reply With Quote
The Following 3 Users Say Thank You to wheelhaus For This Useful Post:
kthxbai (05-17-2013), Richard Cranium (05-17-2013), strat61caster (05-17-2013)
Old 05-17-2013, 11:37 AM   #10
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
The difference between octanes is not necessarily more power, it's stability. Higher octanes are more resistant to preignition (knock, ping, detonation, etc), Which is where the mixture may ignite prematurely and momentarily force the crankshaft backward. This is bad, and could eventually lead to the engine beating itself to death. Higher octane ratings allow more aggressive tuning (spark timing, fuel ratio, higher compression, forced induction, etc) because the fuel will ignite when the spark is fired, not a moment before. The ECU has a window for some of these parameters, and it will reduce their values if it detects preignition. If it detects none, it will continue to improve it's parameters until it reaches it's programmed limit. More aggressive tuning is what makes more power, whereas a higher octane rating is simply what enables it.
Old 05-17-2013, 11:54 AM   #11
GNS
Drives: .
Use super essence only. Because ordinary essence isn't enough.
GNS is offline   Reply With Quote
Old 05-17-2013, 12:01 PM   #12
ReVoiD
Drives: mazda 6 mps
also we put in a liquid so its pretty silly to call it gas.
call it petrol or fuel instead.
http://en.wikipedia.org/wiki/Fuel#Solid_fuel
or go all out on the JDM train:
ガソリン
ReVoiD is offline   Reply With Quote
Old 05-17-2013, 12:23 PM   #13
Richard Cranium
Ted
Drives: Raven FR-S
ガソリン
lol, "petrol" and "fuel" can be just as ambiguous as "gas" if you want them to be. Your own source lists "gasoline" in the liquid category as a secondary terminology. Not sure if troll or..........
2013 Scion FR-S - Sideways and Smiling
Bone-yard: 2010 Toyota Tacoma, 2008 Honda Civic SI, 2002 Audi A4 1.8T Stage 3 K04, 1999 Honda Civic SI
Richard Cranium is offline   Reply With Quote
Old 05-17-2013, 12:56 PM   #14
tomt5078
tomt5078's Avatar
I did notice while driving thru south dakota last year I couldn't find any gas above 87!!!!!
tomt5078 is offline   Reply With Quote
