Old 05-16-2013, 08:19 AM   #1
jadewbj
jadewbj's Avatar
Bass Rattles Driver Side Window Switches....
Ok I have been hearing this annoying little buzz every time my bass hits. This is not only when the radio is up loud just if the right frequency hits you hear a buzz coming from the drivers door.
After much holding and pushing on the door to find the source I finally put a little pressure on the window switches and bang no buzz.
Does this happen to anyone else car?
jadewbj is offline   Reply With Quote
Old 05-16-2013, 08:35 AM   #2
#87
I usually post drunk
#87's Avatar
All of them
When you find out the exact areas to dynamat please post a DIY and send me a link
#87 is offline   Reply With Quote
Old 05-16-2013, 09:47 AM   #3
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
same here but passenger side. Not the switches but the centre door panel
Sookainian is offline   Reply With Quote
Old 05-16-2013, 10:58 AM   #4
jadewbj
jadewbj's Avatar
If mine was door panel I could probably take the door apart and fix it in a jiff. Since mine is the switches it makes it a pain to fix.
Old 05-16-2013, 11:06 AM   #5
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
This happened in my tc all the time when I had it. I just put some thin foam in between the plastic contact points between the switch panel and the door panel.
Panda Grahams is offline   Reply With Quote
Old 05-16-2013, 11:28 AM   #6
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
I put dynamat in my door panels and went so far as to take the switches that you are talking about and wrap them in dynamat as well. Got rid of all my rattles and the stock speakers actually sound surprisingly decent at high volume.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 05-16-2013, 11:35 AM   #7
radroach
Drives: car
Yes it happens on my car, I've found ways to alleviate it a lot by lowering my source volume control, either by turning down the volume on my bluetooth device and then cranking the radio 100%, or by changing the brz's radio SVC (source volume control) to -10dB. This allows for much higher clean headroom and your bass and treble wont distort, at the cost of some loudness.
The Following User Says Thank You to radroach For This Useful Post:
Turbowned (05-17-2013)
Old 05-17-2013, 03:15 AM   #8
Adam86
Adam86's Avatar
Drives: Toyota 86
i dont find this problem but i do find the entire boot shaking im not sure if theres maybe too much bass but thats how it goes. any one??
Adam86 is offline   Reply With Quote
Old 05-17-2013, 12:59 PM   #9
Turbowned
Turbowned's Avatar
Oh no, don't tell me these things! I'm like a dog when it comes to those little noises; that's gonna drive me crazy!!
Old 05-17-2013, 01:22 PM   #10
jadewbj
jadewbj's Avatar
That is why it is killing me, I am the same way.
I also hear the window it self buzz when it crack it like an inch or 2. 3/4 down no problem anything inbetween I hear a little rattle.
Old 05-19-2013, 12:08 AM   #11
StOpNG0x
StOpNG0x's Avatar
Drives: Firestorm MT FR-S
Unless I have my knee pressed against the door where the speaker is... at certain parts of a song I hear this annoying noise being described as well.
StOpNG0x is offline   Reply With Quote
Old 05-19-2013, 12:28 AM   #12
jflogerzi
jflogerzi's Avatar
Want to come do that to my car? :happy0180:
Old 05-19-2013, 11:25 AM   #13
jadewbj
jadewbj's Avatar
I thought that too. Next time u hear the buzz juat take your fingers and pul up a tiny bit like you are going to raise the window.
Old 05-19-2013, 12:10 PM   #14
3_NA_HAF
Diesel Tech
3_NA_HAF's Avatar
Drives: 2013 FR-S Hot Lava 6MT
It's where the window switches clip into a second piece that screws to the main panel. I just used 4 small pieces of dynamat to hold it. If you take the door apart you'll see what I mean. It's not too hard and makes a huge difference.
3_NA_HAF is offline   Reply With Quote
Driver Side Window Rattle RiceCooker Issues | Warranty | Recalls / TSB 23 08-18-2015 10:20 AM
driver side window scratch Celica00 Scion FR-S / Toyota 86 GT86 General Forum 13 07-31-2013 10:59 AM
Window control rattles from stereo Panecki17 Issues | Warranty | Recalls / TSB 11 07-27-2013 10:49 PM
Driver window controls don't work Hops Normal Issues | Warranty | Recalls / TSB 5 01-27-2013 08:35 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 12:32 AM
