Old 05-15-2013, 04:04 PM   #1
Xdragonxb0i
Drives: ex500r
Hey what is this? Black Box, Rear tire compartment.
i am stripping out my trunk, and was curious about this black box, Look like a resonator or a big plug. the wires you see on top goes to the rear tail lights
Xdragonxb0i is offline   Reply With Quote
Old 05-15-2013, 04:29 PM   #2
Mikem53
Drives: FR-S 6MT
I think you are correct about it being a resonator.. something to dampen vibrations and keep the structure from making noises..
I have something similar in a Honda accord..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
jcw99 (10-19-2021)
Old 05-15-2013, 05:42 PM   #3
ahausheer
Re-member
Drives: Toyota camry
Stick a finger in it and see if there are soft rubber flaps on the other side. If so, its to balance air pressure, like when you have the AC on full blast, the pressure has to go out somewhere. If you ever see a car with its rear bumper off you can see the flaps.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
The Following User Says Thank You to ahausheer For This Useful Post:
jcw99 (10-19-2021)
Old 05-15-2013, 10:55 PM   #4
Xdragonxb0i
Drives: ex500r
Tour right its a vent. You do think it will be a problem to block the airflow? I am putting sound deadening in my car
Old 05-16-2013, 12:39 PM   #5
ahausheer
Re-member
I wouldn't block the vents, but I have no I idea if doing so would be a bad thing.
Old 05-16-2013, 12:45 PM   #6
ft_sjo
Drives: GT86
They're to stop condensation in the car and give you ventilation.. all/most cars have them.. not sure if it's a regulatory thing or something that is needed for type approval.
The Following User Says Thank You to ft_sjo For This Useful Post:
jcw99 (10-19-2021)
Old 05-16-2013, 02:26 PM   #7
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
I think it also provides an outlet for the air pressure increase when you close your trunk. Makes it so you don't have to slam it against the escaping air.
NRGBalanced is offline   Reply With Quote
The Following User Says Thank You to NRGBalanced For This Useful Post:
jcw99 (10-19-2021)
Old 05-16-2013, 02:35 PM   #8
OrbitalEllipses
Drives: Attitude
Stop trolling guise! It's a GPS tracker from the FBI that is mandatory in all vehicles. Records conversations as well as vehicle telemetry.
Old 05-16-2013, 02:49 PM   #9
M-17
Ninja Cat Mod
M-17's Avatar
Old 10-18-2021, 09:01 PM   #10
iag48st
Drives: 10Series 0945
Sorry for reviving this old thread but I’ve finally discovered where this plastic buzzing sound is coming from. It’s from this black piece. I put my fingers in and there’s like a plastic sheet or flap that’s buzzing around.
Any idea how I can remove this plastic or stop this buzzing sound that’s annoying me?
Thanks in advance
iag48st is offline   Reply With Quote
Old 10-18-2021, 10:44 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
When does it buzz?
Old 10-19-2021, 01:06 AM   #12
Bubba says to just stick a stick in it, to keep it from closing -
humfrz is online now   Reply With Quote
Old 10-19-2021, 01:31 AM   #13
spike021
spike021's Avatar
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (10-19-2021)
Old 10-23-2021, 09:14 PM   #14
iag48st
When does it buzz?
It buzzed loudest during cold start and during low rpms. I ripped the flaps despite a buddy telling me not to. I’m going to cover it up with duct tape.
Humm Coming From Right Rear Tire Well While Car iIs Parked In The Garage davesrave BRZ First-Gen (2012+) — General Topics 2 05-09-2013 08:06 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 11:14 AM
Where is the sub-floor storage compartment? wbradley BRZ First-Gen (2012+) — General Topics 4 08-19-2012 10:59 AM
Right rear tire chirp FRiSson Scion FR-S / Toyota 86 GT86 General Forum 5 08-05-2012 01:30 PM
Widest rear tire for a staggered setup? Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-22-2012 08:52 PM
