Old 05-16-2013, 06:12 AM   #15
F360
Drives: M5 (F10)
TSW nurburgring gunmetal 18x8 +35
TSW nurburgring gunmetal 18x8 +35 with 235/40/18
F360 is offline   Reply With Quote
The Following 4 Users Say Thank You to F360 For This Useful Post:
armythug (05-16-2013), mikalem (05-16-2013), normancw (05-16-2013), SkAsphalt (05-16-2013)
Old 05-16-2013, 08:50 AM   #16
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Just got the same set loaded up on my car as well - I'll share for those that want to see what they look like on a different color: (Edit: Same rims, different tire size: 245/35/18)
mikalem is offline   Reply With Quote
The Following 2 Users Say Thank You to mikalem For This Useful Post:
F360 (05-16-2013), SkAsphalt (05-16-2013)
Old 05-16-2013, 02:00 PM   #17
BigRedDog
Drives: FR-S Firestorm 6MT
Wheel looks good.
stock suspension?
BigRedDog is offline   Reply With Quote
Old 05-16-2013, 02:04 PM   #18
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I like your tire choice! I'm running the same but 235's
The Following User Says Thank You to ATL BRZ For This Useful Post:
Old 05-16-2013, 02:27 PM   #19
mikalem
mikalem's Avatar
Stock suspension on mine still.... I have noticed the BRZ wants to push a lot more with this wheel/tire combo on the stock suspension - the backend doesn't want to step out anymore like it used to. Hoping to do a little research to figure out a good spring setup to help remedy that.
Old 05-16-2013, 02:34 PM   #20
ATL BRZ
ATL BRZ's Avatar
RCE Yellows and RCE Sways set softer in front and stiffer in the rear will make the car handle wonderfully. That's what I have now and I love the razor sharp turn in and the progressive oversteer, as well as zero body roll!
$599 shipped for the Spring + Sway package is still going on: http://www.ft86club.com/forums/showthread.php?t=29453
Old 05-16-2013, 03:09 PM   #21
mikalem
mikalem's Avatar
You just kept the stock strut? I was looking at that setup and wondering if I would be better off building off the koni strut to have something that was more replaceable as a unit, just so I could replace wholesale without having to disassemble the suspension off the car. Thanks for the input!
Old 05-16-2013, 03:18 PM   #22
ModBargains.com
ModBargains.com's Avatar
Those look great!!!! Thanks for sharing with the forum
ModBargains.com is offline   Reply With Quote
Old 05-16-2013, 03:49 PM   #23
ATL BRZ
ATL BRZ's Avatar
Yup OEM struts. By the time I have the need for adjustable struts I won't have any desire to disassemble and cut my stock struts open to insert Konis. I'll likely just get some coilovers and then sell my stock struts with the Yellows on them, assuming they are still good.
Old 05-16-2013, 04:18 PM   #24
DarkSunrise
DarkSunrise's Avatar
Looks good. I have the same wheels, but in 17" size. One thing I did and would suggest: switch the lugnuts from chrome to black. I think it looks better against the gunmetal wheels.
You can barely see them in this picture, but you get the idea:
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
F360 (05-16-2013)
Old 05-16-2013, 05:45 PM   #25
F360
Drives: M5 (F10)
Originally Posted by BigRedDog View Post
Wheel looks good.
stock suspension?
Yes, stock suspension
Old 05-16-2013, 05:52 PM   #26
F360
Drives: M5 (F10)
Very nice
Old 05-16-2013, 05:55 PM   #27
F360
Drives: M5 (F10)
Very nice care and thanks for the advice
Old 06-22-2013, 07:32 PM   #28
EL7
EL7's Avatar
Drives: 13 BRZ Limited 6MT SWP
Few shots of my TSW Nurburgrings in 18X8 +35 Gunmetal w/ mirror cut face
Went on a run with my local SATX 86 crew. Figured I'd take a few shots of my TSW Nurburgrings. 18X8 +35 square on Nitto NT555s at 225. Stock suspension for now. I might throw on some FEAL coils next month and update. Needs a little more low.
EL7 is offline   Reply With Quote
The Following 2 Users Say Thank You to EL7 For This Useful Post:
JARE_ee (08-06-2014), sprintertrueno86 (06-23-2013)
nurburgring, tsw wheels
Wheel Directory: XXR 527 18x8.75 +35 Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 06-11-2016 02:40 PM
Wheel Directory: XXR 530 18x8.75 +33 white_knight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 11-04-2015 06:22 PM
Wheel Directory: BBS CH 18x8.5 +30 Spaceywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-02-2015 01:05 PM
Wheel Directory: BBS CH-R 18x8.0 +38 Racecomp Engineering Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 10-01-2014 02:12 AM
Wheel Directory: XXR 530 18x8.75 +20 Jon@TrueStreetIndustries Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 04-02-2014 06:15 PM
