Old 02-20-2013, 02:30 PM   #71
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Evan@D3PE View Post
Still offering both systems ready to ship!
Still loving mine:
Sportsguy83 (02-21-2013)
Old 02-20-2013, 10:42 PM   #72
Evan@D3PE
Evan@D3PE's Avatar
Drives: 1969 Opel GT
Excellent! Thank you for the great picture!
Evan@D3PE is offline   Reply With Quote
Old 03-01-2013, 01:07 AM   #73
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
What is the current wait time for these? After I order and pay, how much time to get it home? Zip code 33196.
Thanks.
Old 03-01-2013, 08:45 PM   #74
ANTI_LAG
ANTI_LAG's Avatar
Drives: Ones with Big Turbos
Series 1 are ready to ship, series 2 are an extra 1-2 days to ship from the day the order is placed. We usually have these on shelf but we sold out of the series 2.
ANTI_LAG is offline   Reply With Quote
The Following User Says Thank You to ANTI_LAG For This Useful Post:
Sportsguy83 (03-01-2013)
Old 03-01-2013, 10:08 PM   #75
Sportsguy83
Drives: Limited BRZ
Thanks!
Old 05-16-2013, 11:29 AM   #76
sierra
Drives: Skoda Yeti DSG diesel 4x4
Is this the catch can you ended up buying?
I read in one of your posts that you fitted one to stop the fumes you were getting in the car after fitting the turbo. If that's correct and this stopped them, how were the fumes getting in the car from the closed system in the first place?
sierra is offline   Reply With Quote
Old 05-16-2013, 11:40 AM   #77
Sportsguy83
Drives: Limited BRZ
At some point I considered getting a different one and selling this one but ended up keeping it. Since this one vents to ATM, what I did was relocate the filter on top of it to below the car so that the fumes escape far away from the A/C vents when it is not set to recirculate air. Cars that have Auto A/C controls (at least in my climate) tend to almost always start off in non-recirc mode, so the fumes would get inside the cabin. With the relocation mod (see last pic in my build thread), the fumes no longer get in the cabin and I'm extremely happy with the Can. Extremely simple to install.
Old 05-16-2013, 11:51 AM   #78
sierra
Thanks David. So it was the filter breathing to atmosphere under the bonnet causing the fumes.
I'm getting the odd wiff of engine fumes, mainly with the window down straight after a hard run to the 6000rpm + range. It's much better since I changed the oil and barely noticeable but I can't get my head around where they're coming from?
The oil stays clean for thousands of km's and it's not using any.
No leaks and the breather pipes are tight.
Old 05-16-2013, 12:38 PM   #79
Sportsguy83
Drives: Limited BRZ
I think I always got a little fume smell too after spirited runs before catch can. The PCV connection to Throttle Body is not clamped, maybe a little bit of leakage there?
Old 05-16-2013, 12:43 PM   #80
Sportsguy83
Drives: Limited BRZ
I am very happy with the Catch Can, here's a pic of it installed.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
charged86 (05-17-2013)
Old 05-16-2013, 03:02 PM   #81
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Have you checked the pump plate on the back of the engine near the battery for leaks? There is a thread in the Issues forum about it leaking oil on the overpipe causing an oily smell. Mine has this issue, but I haven't taken the time to fix it yet. It is a gold plate held on with three bolts and if you have the issue you will feel oil on the bottom corner of the plate.
Sportsguy83 (05-16-2013)
Old 05-16-2013, 03:03 PM   #82
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Here are pictrures of my filter relocation:
Old 05-16-2013, 08:22 PM   #83
ANTI_LAG
ANTI_LAG's Avatar
With any open element releasing oil vapor into an engine bay there will always be some smells, with ac in recirculate it rids this problem for the most part. For those who would like to have ac not on recirculate we are working on a relocation option, it will be built from mandrel bent aluminum tubing that matches the catch can finish. We will also have some other updates coming along as we are always using customer feedback and testing to further develop our products.
Dave
The Following 2 Users Say Thank You to ANTI_LAG For This Useful Post:
King Tut (05-17-2013), Sportsguy83 (05-16-2013)
Old 05-16-2013, 10:40 PM   #84
Sportsguy83
Drives: Limited BRZ
Dave
Thanks for everything Dave. Highly recommended products and quality!
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 04:07 PM
~D3PE FRS/BRZ Catch Can System~ Evan@D3PE Engine, Exhaust, Bolt-Ons 26 06-12-2013 04:39 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 11:58 AM
For those who were compensated, what's the catch? TurnOne Issues | Warranty | Recalls / TSB 27 02-08-2013 02:20 PM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 04:55 PM
