Old 05-15-2013, 05:07 PM   #365
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The AEM Failsafe has a wire that can either provide a ground signal or a 12V signal when a certain AFR/Boost condition is met. That signal can be used to do quite a few things including telling a boost solenoid to return to wastegate psi working or to tell an electronic boost controller to return to wastegate psi or to power a big red shift light that says DANGER WILL ROBINSON. I don't know how you would put that signal into the ECU for EcuTek to utilize it though.
EcuTek apparantly has options to control an external boost solenoid similar to OEM Subaru turbo setups, but I haven't seen anything on this other than the few bits Visconti has posted.
Old 05-15-2013, 05:32 PM   #366
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by dabocx View Post
So for controlling boost would you do that through ecutek or can that been done with the AEM failsafe?
I'm experimenting with an AVO Electronic boost controller right now, I've had many different kinds. This one has a very nice install with only 2 wires to actually cut and solder, everything else has a harness. I may or may not end up using Ecutek boost control, my EBC does have a boost cut you can set that cuts the wastegate reference so I'm thinking that coupled with the AEM Failsafe should be double safe in theory, I guess we'll see in reality.
Pure Automotive is offline   Reply With Quote
Old 05-15-2013, 05:54 PM   #367
Frs300
Frs300's Avatar
Drives: Pile of junk
@Supermassive is running one that @Visconti setup for him or at least he did anyway. maybe he can chime in on how its setup if he knows.
Frs300 is offline   Reply With Quote
Old 05-15-2013, 06:07 PM   #368
Visconti
Drives: 05 STi
I dont want to see this thread get side tracked but there is absolutely nothing wrong with omni's upgraded map sensors PERIOD! Any tuner that says omni has problems, well they're wrong.. they just dont know how to calibrate the sensor correctly !
There are 2 advantage's of running a upgraded map sensor.
1. Both you and the tuner able to see how much boost you running in the datalogs
2. Overboost protection
Aftermarket failsafes work but do not offer the protection a overboost setting in the ecu would. If the wastegate it hooked up the wrong way or lines melt there so way for the aftermarket failsafe to remove boost. ECU Controlled overboost protection can close the throttle body and cut fuel injectors.
FRS300 wouldn't have a blown motor right now if he had this type of protection in his tune.
Anyone running forced induction should have this type of protection in their car.
It's saved at least 6 motors this year.
-John
Visconti is offline   Reply With Quote
Old 05-15-2013, 06:23 PM   #369
bulldog11267mad
bulldog11267mad's Avatar
Drives: 2013 BRZ Limited manual
It really isn't mind boggling to me. LJ is providing a turbo kit and a basemap for the OEM MAP sensor. Neither requires an upgraded MAP sensor to run. My car was running just fine before I upgraded the MAP sensor, and the only real advantage I have gotten from it so far is being able to log accurate boost in EcuTek which I was able to do previously with my AEM Failsafe gauge.
With that being said, I would recommend buying one, and it wouldn't surprise me if LJ includes it in future kits. Just remember that you have to run a modified tune specificially for the new MAP sensor so it isn't just a bolt on affair.
my FBM stage one premium kit came with a 4 bar map sensor. i believewas the 3rd person to get the kit from FBM so maybe they are not giving them with the kit anymore.
IAG built stage 3 block, HKS camshafts, built and tuned by national speed. 1050 ID injector, garret GTX3071 93 octane 415whp, E85 524whp monster! Quaife QBE69G sequential transmission!
bulldog11267mad is offline   Reply With Quote
The Following User Says Thank You to bulldog11267mad For This Useful Post:
crook (05-16-2013)
Old 05-15-2013, 08:15 PM   #370
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You can't guarantee that if he was just leaning out due to the fuel pump not flowing correctly. Overboost is just one way to blow a motor.
Old 05-15-2013, 08:17 PM   #371
Visconti
Drives: 05 STi
I've had several turbo customers at 14.0 air fuel mixtures and no rods through the block.
Overboost enough, and a rod will come out
So I say this with almost 100% certainty.
-John
Old 05-15-2013, 08:46 PM   #372
Gen
Drives: Scion FR-S
I think that's the heart of the issue with the aftermarket industry as well as tuning specifically. How do you know who to trust? Well respected vendors and tuners will have differing and often conflicting accounts of the proper way to do something, with each side having hordes of loyal fans. Makes it difficult to get a straight answer. You can pick anything and anyone in the industry, no matter how respected, and find a hundred people that will state emphatically that the product / person is absolute garbage.
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
Brzzee (05-15-2013)
Old 05-16-2013, 12:37 AM   #373
crook
crook's Avatar
Drives: storm black GT
They still do it, I got an omni 4 bar with my fbm premium kit as an option
crook is offline   Reply With Quote
Old 05-16-2013, 01:45 PM   #374
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Interesting. Maybe only the premium kits came with it. I know I got one of the first production based basic kits, and mine didn't come with it. I know the two basemaps I got from LJ were setup for the OEM MAP sensor as well. I will have to ask him about it along with seeing how the oil cooler is coming along.
Old 05-16-2013, 02:02 PM   #375
Frs300
Frs300's Avatar
my kit is a premium kit and i didnt get one dont know if they stopped putting them in the kit or forgot to give me one or what
Old 05-16-2013, 03:32 PM   #376
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
-John
It saved my motor
Old 05-16-2013, 03:34 PM   #377
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
My base kit didnt come with the 4bar sensor.
I bought it from John @Visconti
Thanks God i did otherwise i would have blown my engine already
Old 05-16-2013, 03:36 PM   #378
Visconti
Drives: 05 STi
Oh yeah, completely forgot that happened to you too.
I bet you thought I was trying to give you a hard time when I wouldn't tune your car without it.
Happy it worked out
John
700 Miles Blown Clutch Bonburner Issues | Warranty | Recalls / TSB 76 09-23-2012 09:32 PM
Exhaust Stage enkubus Engine, Exhaust, Transmission 3 08-14-2012 09:31 PM
Initial D stage 5 86boyAF1 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-08-2012 10:00 AM
Battle Stage 2 trueno86power Other Vehicles & General Automotive Discussions 2 09-26-2011 03:04 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
