Old 05-15-2013, 11:51 AM   #43
ebphoto
Drives: FR-S, NA8, S13
giddy to see this setup in person... i need to sell my wheels.
ebphoto is offline   Reply With Quote
Old 05-15-2013, 12:02 PM   #44
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Figured I would update my thread. I have discovered it is definitely my Dell Laptop that gives me issues flashing the car with EcuTek. I used my EcuTek cable and a buddies Samsung laptop and it flashed the car much quicker and didn't fail. The car is running great at 14 psi, and I hope to get some datalogs tonight to send to @Visconti as we are still working on fine tuning my ignition timing. I am still loving my Full Blown kit, and I could not be happier with it. I realized I forgot to post my latest boost curve plot in this thread for people looking at running higher PSI on the Full Blown kit. This is with a Green 9.4 PSI spring in my Precision wastegate being controlled by a Go Fast Bits Electronic Boost Controller:
In other news my Advan RG-D in 18x9.5 +40 Gold form are arriving today. I hope they clear the front Brembos without a spacer. I am still evaluating my coilover options, but I will be definitely switcthing from my H&R Super Sports to coilovers to fit these wheels and will be wrapping them in Michelin Pilot Super Sport 265/35/18 tires. I can't wait.
what a beauty you have their my friend, fsr i always though you and Sports guy had AVO kits
Great choice on the tires they're the best all around tires, but if you end up going for a bit more power the MPSS won't hold up the power in lower gears.
Old 05-15-2013, 12:05 PM   #45
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Did you see another guy got similar Works to yours and ruint it this week?
Old 05-15-2013, 12:07 PM   #46
King Tut
NASA SpecE30 Racer
King Tut's Avatar
When the news of the AVO kit first came out, I was set on getting one. Then the Full Blown kit came out, and it was actually available. I got desperate in December, and I had to have boost, and the Full Blown was available while the AVO was still taking pre-orders. In the end I think I made the right decision, but I do love the sound of David's AVO BRZ.
Sportsguy83 (05-15-2013)
Old 05-15-2013, 12:12 PM   #47
ebphoto
its so tall! haha.
Old 05-15-2013, 12:14 PM   #48
SmsAlSuwaidi
Boosted
I really want to get boosted but I'm still indecisive, it seems like I'm crossing the AVO kit out , because I'm looking for a High HP build. The good thing is my car is going into storage for the next 2~ months and get some off time to think about which kit to get.
Old 05-15-2013, 12:17 PM   #49
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If you are going for big horsepower, then I definitely think one of the front top mount options are going to be best so you can fit larger turbos should you decide.
Old 05-15-2013, 12:18 PM   #50
SmsAlSuwaidi
Boosted
yeah exactly, its either full blown or some other front mount.
Do you plan on getting mad negative camber to fit the 265 up front ?
also any plans on building you motor, and denoting it with the current 14 psi
Old 05-15-2013, 12:26 PM   #51
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am thinking -2 degrees should be enough in the front, and I plan to set the rear to -1 degree. If something should happen to the motor, which I don't expect, then I plan to do a simple low compression build with pistons and rods.
Old 05-16-2013, 02:32 PM   #52
King Tut
NASA SpecE30 Racer
King Tut's Avatar
So the Advan RG-Ds came in yesterday and they fit, but barely :
There is actually more spoke to caliper clearance than on my 18x8 +42 TC105ns. I also ordered my 265/35/18 Michelin PSS and a set of BC coilovers. I figure if they are good enough for Jon Miller, then they are good enough for me.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
nix (06-12-2013), pmccut (06-13-2013), Sportsguy83 (05-16-2013)
Old 05-16-2013, 02:36 PM   #53
OrbitalEllipses
Drives: Attitude
I love gold Advan RG-D. One of my top wheels. Is there enough clearance at full compression? Almost looks like it'll contact the spring perch.
Old 05-16-2013, 02:44 PM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Spring perch and wheel clearance is fixed. They move together. I am not sure the tire will clear the spring perch, but that is why I am getting coilovers as well. I am following the 265 width Bible according to @Jive Turkey.
Old 05-16-2013, 02:47 PM   #55
ayau
Drives: Some rust bucket
265 width bible?
Old 05-16-2013, 02:48 PM   #56
OrbitalEllipses
Drives: Attitude
DUHHHHHHHHHHHHHHHH. OMG I need my coffee, today's been a wreck thus far.
brz, king, limited, subaru, tut
Alex's 2013 WRB Subaru BRZ Limited Alex Member's Car Journals 51 01-03-2014 03:43 AM
2013 Subaru BRZ Limited Long-Term Test - InsideLine brianc BRZ First-Gen (2012+) — General Topics 0 08-01-2012 07:18 AM
2013 Subaru BRZ Limited Start Up, Exhaust, and In Depth Review delta86 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-26-2012 03:25 AM
xcelir8brz's - 2013 Subaru BRZ Limited xcelir8brz Member's Car Journals 4 06-03-2012 05:44 PM
