Drives: Scion frs
Is it a bad idea to run headers without a tune??
I have enough money for headers but not yet for a tune, would tou guys suggest i wait or is it okay to run headers without a tune? I know ill make less power but it would just be temporary? I was wondering how it would affect the afr and i would be completly catless also so maybe a chek engine light? I know the bungs are gonna be welded on already so i can still plug my o2 sensors just wondering how the car will react to this!!
Thanks, mike |
#2 |
Drives: First SWP BRZ-L
I've been running headers without a tune for several thousand miles. AFRs looked fine on the dyno, everything feels great. You could definitely be getting more out of your headers with the tune. Also depends on the headers- I'm sure some have less stock-friendly properties than others.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
| The Following 3 Users Say Thank You to Tainen For This Useful Post: |
#3 | |
Drives: 2013 Asphalt FR-S
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
| The Following 3 Users Say Thank You to Opposed For This Useful Post: |
#4 | |
Drives: 2014 SWP BRZ Limited
I'm in kinda the same boat as the OP, in that I want to get a tune and maybe a new header / front pipe combo. Does the order really matter if I add these one at a time? |
#5 |
Depending on your turner, each time you add a bolt on you would do data logging and your turner would send u an updated tune at no cost (most if not all). The only caveat to this if you went to FI you will need to pay your turner to retune
| The Following User Says Thank You to jflogerzi For This Useful Post: | Jar (05-14-2013) |
#6 | |
Also, as it's been mentioned, most tuners worth their money aren't going to charge too much for a re-tune once you get your headers installed.. some won't charge you at all for any bolt-on additions. |
#7 |
Drives: 2013 Subaru BRZ
I still don't understand the concept of tuning with like the Ecutek or other tuning options when it comes to having different aftermarket products from different manufactures. How does the tuning work like that?
For example, I plan to get a Perrin catback exhaust(resonated), front and over pipe. Perrin doesn't have a header, so in considering a JDM or Rev Works, UEL header. Then if you add a different manufacture air intake etc... So does that mean you would have to purchase a Perrin map license, and a license for each other manufacture aftermarket product? Sorry I'm new to this and still learning all of this tuning stuff. |
#8 | |
Nope. those are independent systems on the car. You just want the tune (think of the software version of the car) manually modified to get the most out of the parts on the car by adjusting timing, AFR, and other variables. Because different parts flow differently, different tunes help get the max out of those setups. So whenever you change the properties of your exhaust or intake setup, a retune would be a decent idea to make sure you are getting the most out of it and operating within safe parameters.
#9 |
Ok so basically you get the initial tune from say ecutec to get more performance from your car. But then I've seen perrin also has a set of maps also and I seem a few other companies with maps which is where I get confused haha. I understand the basic concept of the tune, just now how it works as far as it goes with aftermarket parts added afterwards.
Also I live I Canada in a smaller province where there isn't a huge industry here for performance stuff like this. We have some custome shops and stuff, but I have no idea if we even have a shop here with a dyno. Also the highest grade fuel here is octane 91 which I know you get more performance with 93 or E85 which I have no idea what that is lol. So my other question is, when you get the tune, is a dyno test still needed on your car or no? Sorry if I'm making this confusing. |
| The Following User Says Thank You to Oburn For This Useful Post: | lokvo (05-14-2013) |
#10 |
Pugilist
Drives: GT 86 - Hot Lava (AUS Spec)
^^Thanks for asking the question, I'm in the same situation.
"BOO FOR THE GOO" - Everyone
#11 |
When In Doubt...
Drives: Slowww
Dyno isn't needed for a "mail in" tune. It's a one size fits all deal. Meaning it won't be perfect but it'll be damn close. Like buying your size dress pants off the rack versus having them tailored.
E85 is fuel that is 85 ethanol (alcohol). It'll get your car drunk.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#12 |
Ok so I guess the next question is, how do I go about getting the license? I checked Ecutec site and they only sell to other company's so where should I go to get one?
#13 |
Drives: 2013 Asphalt FRS
why tune first then header second??? Both give similar gains. Get the header first then tune 2nd.
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
| The Following User Says Thank You to NickFRS For This Useful Post: | Texas2016Frs (11-03-2016) |
#14 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
This is where the datalogging features of EcuTek ProECU are incredible. We have been doing this with other platforms since 2009 on the MX-5, back when nobody would really consider custom "e-tuning" viable. Now it is the standard. Usually when we send our tunes to shops to "fine tune" they make 1-2 hp at best on the MX-5, often times nothing. With the BRZ it is a similar story where once the base tune is developed for a product (i.e. header, SC) as long as you have a fairly standard car, the tunes are consistent and can adjust to a degree. But you get 95% of the performance at fraction of the cost since you put the time in driving and not someone billing you.
In regards to the OP's question, it isn't a bad idea as in harm the car IMO, but you're not getting the full potential. A header opens up a big choke point in the motor, and to leave it untuned is leaving more on the table. Sometimes you can have it gain power, but throw off the AFR so much that you pick up even more power from fixing it with a tune (custom via datalogging). You can do all this at a local dyno who has the ability to tune the car, but I like the street tuning method so that you can take into account the learning and it saves a ton of cash not having to tie up the dyno for hours. Do the street tune and get it in the ballpark, then hop on the rollers for a couple of hours and tweak the timing, AFR, and do a mild cam sweep to see where the sweet spots are. Then double check and correct for the learning. The tunes are never "one size fits all though"...I am continuously amazed at how two cars a couple of VIN #'s apart (belonging to the same race team) have trims differing 10% between the two identical setups. Put two nearly identical cars on the dyno, one runs 28 degrees at peak power, the other won't let you get past 24...all variances where you'd think there wouldn't be. Fortunately these things we can tell by street tuning/datalogs, and minimize the dyno costs. |
| The Following 4 Users Say Thank You to Xero-Limit For This Useful Post: |
| Drift Office Tune vs Visconti Tune | mechaghost | Engine, Exhaust, Transmission | 109 | 07-03-2014 12:57 AM |
| Tune now or wait for headers | lbroskee | Engine, Exhaust, Transmission | 7 | 05-01-2013 05:36 PM |
| Any idea what this is? | idreamofdrifting | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 02-08-2013 10:50 PM |
| Dynotronics and their E-Tune/ OTA tune. | Ricepuddin | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 12-24-2012 09:53 AM |
| What do you think about this idea... | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 07-20-2012 03:26 PM |
