Old 05-12-2013, 02:24 PM   #15
ft_sjo
Drives: GT86
Sounds like a nice spec. Would be nice to see you making the most of it with some more turbo-oriented cams and a nice torque curve.
Old 05-13-2013, 10:58 AM   #16
wparsons
wparsons's Avatar
Have you seen the post by Visconti about the new accelerated performance fuel system? Apparently the stock fuel rails flow a ton and aren't a bottle neck at all. Just need a modified pump setup to avoid fuel starvation below half a tank in corners. You can upgrade the lines and run a return style system as well, but for 400whp your only issue with stock stuff will be starvation in corners.
flickr
Old 05-13-2013, 03:36 PM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Very interested in the completion of this build.
