Drives: FRS Silver LS1 swapped.
CF6 FRS
For those who have been following my build,...do to the cat injestation into my turbo I'm going with a Garrett GTX2867R turbo now,..along with that I'm upgrading the fuel system converting from OEM returnless fuel system to a return system utilizing Full Blown fuel rails (I guess I'm the first to try these out), Full Blown fuel pressure regulator, and custom lines. Combined with the forged Arias pistons 9 to 1 compression,..Pauter rods/stage 3 block the outcome should be interesting with E85. May have to go with a surge tank,....we shall see....oh yah,...catless now.
#2 | |
Boosted
Drives: Not a supra....yet
Good luck with your build though
Drives: ZC6, Junk of ALL sorts
Thats what the man said.
I like it. ![]() Keep us updated.
# 1. Always know where your towel is.
ZC6-CBS, is home |
Drives: DGM BRZ Limited
I'm glad to see this. Any larger of turbo will lack track mannerisms on this platform.
Do you really need half those supporting mods to max out the GTX28??? Sounds like you're shooting for 700whp with a ~400whp turbo?
You can easily run 400whp on e85 and stock internals. Higher compression means less boost is needed, less boost = less heat.
Yes you need these mods, fuel system wise, once you reach about 15 psi and above ,( key word is about) cause it goes way lean. My car is built for reliable track use,...trust me 400whp+ is more than enough on this platform, actually to much unless you are planning only for straight line drag racing or drifting. Higher compression with boost on cast components and stock head bolts (at least to me).... is asking for trouble.
#7 | |
Boosted
Why 9:1 though, if you're tracking it just get forged pistons with closer to stock C/R and beefier rods? You'll get way better throttle response with 12.5:1 than with 9:1 and will need much less boost to make the same power.
gtx2867r is perfect for this application. too many people chase numbers, with little concern for the actual performance associated with those numbers. response, area under the curve, dd/track driveability, are all more important than that last 50whp.
#11 |
Version 2 Coming Soon...
Drives: Turbo Argento FRS, Asphalt FRS
GTX35... I'd want to take advantage of that lower compression and should for earth-shattering numbers. My gt28 made 460whp SAE maxed out.
Part Out Thread: http://www.ft86club.com/forums/showthread.php?t=39992
#12 | |
Boosted
#14 |
Totally understand,...I would like to see at what point this engine says uncle,... torque/horsepower wise.
