Old 05-13-2013, 02:22 AM   #71
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Originally Posted by LeeMaster View Post
If you're asking why the hole is so big, that's because the bigger hole allows the intake to breathe in extra hot air. The more the merrier.
uhhh.. anyways im talking about the side of the box where the intake tube goes in.. seems like the hole on the box is too big for the intake tube?
Minovsky is offline   Reply With Quote
Old 05-13-2013, 03:12 AM   #72
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
That's what I just said, the hole is bigger because it allows the intake to breathe in air from that direction....
EDIT: Let me rephrase, you get airflow coming through the radiator, some of those air that passes by will get sucked into that hole because the intake is doing everything it can to suck in as much air as possible.. (Which can be a bad thing, as the airflow that had passed through the radiator is hot)
If you notice how restricted the box is for the filter, you even have four vents on top of the cover as well....
LeeMaster is offline   Reply With Quote
Old 05-13-2013, 04:02 AM   #73
Minovsky
Minovsky's Avatar
Oh damn .. Sorry I misunderstood..
Old 06-06-2013, 08:43 AM   #74
86muscle
86muscle's Avatar
Drives: Toyota 86
Installed mine last week. This is what it sounds like from inside that cabin:
http://www.facebook.com/#!/photo.php...51482264256219
86muscle is offline   Reply With Quote
Old 06-06-2013, 11:32 AM   #75
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Wrap that intake with some heat barrier cloth or something. Those injen intake heat soak up pretty good.
2superblus is offline   Reply With Quote
Old 07-21-2013, 02:19 AM   #76
mas3oodi
mas3oodi's Avatar
Im having pretty much all the same issues with the Injen intake. I installed an Ecutek Flash by Perrin and matters got even worse. Now I'm running the stock tune and it feels better, but still issues 2,000 rpm.
mas3oodi is offline   Reply With Quote
Injen Short Ram Intake Installed on my 86 :D R2RO Engine, Exhaust, Transmission 57 06-10-2014 07:14 PM
Injen Technology Intake ;) staycrushing Engine, Exhaust, Transmission 61 08-21-2012 09:28 PM
Injen Intake IN STOCK! Mach V Dan Engine, Exhaust, Bolt-Ons 0 08-14-2012 01:04 PM
