Old 05-12-2013, 02:13 PM   #43
Sonolin
Originally Posted by driver01 View Post
I can't believe how much this thing pulls in 5th! Very nice. Love all that low end torque, too.
I'm really starting to like this AVO kit! And the setup looks soo clean I love it.
Sonolin is offline   Reply With Quote
Old 05-22-2013, 03:02 AM   #44
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
I'm going to take the plunge on the ECU controlled boost. Too good of a deal to pass up.
vubaru is offline   Reply With Quote
Old 05-22-2013, 03:48 AM   #45
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
@Visconti so you'll be selling AVO kits with your add-ons included?
JackSmiley is offline   Reply With Quote
Old 05-25-2013, 08:19 PM   #46
vubaru
Now with Boost!
vubaru's Avatar
EBCS came in today but I'm too noob to figure out how to install it. I've called my mechanic buddy to see if he could help but he's away for the weekend.
Have a whole weekend to figure it out though!
Old 05-26-2013, 11:20 PM   #47
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I had installed the Greedy Profec ECB which wasnt controlling boost as well as I and @Visconti would like. His recommendation was to use the purge vsv output to control the boost solenoid through ecutek. Once I got home, the wiring was done enabling ecutek to control boost. I have been back and forth sending datalogs to John while reviews them and sends new maps to try on.
Can you elaborate on how this is wired?
Old 05-26-2013, 11:59 PM   #48
Frs300
Frs300's Avatar
Drives: Pile of junk
good luck getting that info
Frs300 is offline   Reply With Quote
Old 05-27-2013, 12:24 AM   #49
driver01
Drives: brz 13
Delete
Delete
driver01 is offline   Reply With Quote
The Following 3 Users Say Thank You to driver01 For This Useful Post:
King Tut (05-28-2013), Sportsguy83 (05-27-2013), vubaru (05-27-2013)
Old 05-27-2013, 12:29 AM   #50
driver01
Drives: brz 13
FYI the line connecting the intake to the purge solenoid blew off on my car. causing a large vacuum leak. I put clamps on 3 hoses to prevent this from happenning. two clamps on the two hoses attached to the purge valve and one more clamp on the end of the line that connects to the intake
The Following 2 Users Say Thank You to driver01 For This Useful Post:
Old 05-27-2013, 12:33 AM   #51
Frs300
Frs300's Avatar
that wont throw off a cel for disconnecting that? or is that fixed in ecutek
Old 05-27-2013, 12:35 AM   #52
vubaru
Now with Boost!
vubaru's Avatar
Hmm, I'm still not too clear on the instructions. How does the new boost solenoid fit in place of the stock purge valve solenoid? Should I go out and buy extra hose clamps of a particular diameter?
@driver01 if you can do some step-by-step instructions and/or photos that would be incredibly helpful and cool of you, but I understand it takes time.
Old 05-27-2013, 01:54 AM   #53
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Driver01 if you can do some step-by-step instructions and/or photos that would be incredibly helpful and cool of you, but I understand it takes time.
i think from how it sounds, you wire in the solenoid in place of the purge valve, which then allows him to activate the boost solenoid via the ecu as if it were the purge valve. really simple way of describing something that is probably quite technical. lol
killerkid08 is offline   Reply With Quote
Old 05-27-2013, 01:56 AM   #54
vubaru
Now with Boost!
vubaru's Avatar
I understand the theory but I want to know how to identify the purge valve so I know what to remove and how to re-install the EBCS in place with the proper methods so I don't have vacuum leaks/boost leaks.
Old 05-27-2013, 07:51 AM   #55
driver01
Drives: brz 13
The charcoal canister stores all the fuel fumes created withing the fuel tank assembly, its a way of releasing pressure (created by heat) without releasing fuel fumes into the atmosphere. as the charcoal canister gets saturated with fuel we need to empty it, so we connect a hose between the charcoal canister and the intake manifold. now the engine will run too rich due to always having extra fuel from the charcoal canister, thats when the purge vsv comes into play. it is a valve opened and close by the ecu. and thus we control the amount of fuel fumes that go from the charcoal canister into the intake to be burnt out by the motor
@killerkid08 @vubaru Lets break down the install of the boost solenoid controlled by Ecutek in two parts.
- Boost hoses connection
- Wiring of the boost controller
I will edit this later ono when i have more time
The Following 4 Users Say Thank You to driver01 For This Useful Post:
King Tut (05-28-2013), M1K3 (05-27-2013), Sportsguy83 (05-27-2013), vubaru (05-27-2013)
Old 05-27-2013, 09:51 AM   #56
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Originally Posted by deucethemoose View Post
So what are the official modifications and when can we expect an official dyno chart?
So should we expect that zero info will be posted? Where is a dyno chart that shows boost levels, AFRs, and actual numbers for HP and TQ? What engine mods have been done (exhaust, fuel system, etc.).
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned Visconti Forced Induction 697 11-13-2013 06:18 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
Worlds fastest BRZ - Accelerated Performance Built - Visconti Tuned !!! Visconti Forced Induction 135 09-06-2012 05:43 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
