#15 |
Drives: 2013 asphalt fr-s
#16 | |
Drives: H8R FR-S
I took it to the dealer. They asked me if I had any mods and I said I don't have any mods to the powertrain. They replaced the coils under warranty. I had one track day after that but was a low speed track and not much WOT and no CEL. I will be on the track this weekend on two much faster tracks. I will see if I get any CEL and report here.
If you want to make a small fortune in motorsports, start with a large one
#17 |
Drives: BRZ, STI, 535, Tiffin Allegro
Given this diagram:
![]() I believe this teflon ring is the part that folks have found damaged or completely missing from their direct injectors: ![]() Can someone confirm? Did other folks find additional parts damaged? Update, others have also found these insulators damaged on many vehicles:
#18 |
Drives: White 86 Sport Plus
That is O-Ring. You also need direct port injector insulator.
#19 |
I think most of us replaced only insulators. Somehow, I got one missing O-Ring injector. Then, I replaced both.
#20 |
#21 |
#22 |
#23 |
#24 |
Drives: White MT FR-S
Can anyone describe or have photos of the visual clues to look for? Will there be fuel residue or some other indicator where the fuel injectors insert into the block? Is some fuel exiting past the Teflon seal? You could make a regular visual inspection when you check oil level or something.
#25 |
FWIW, I talked to someone at Subaru this weekend about TSB 11-130-13. Apparently it replaces a "shim" of sorts for the camshaft position sensor. I guess there were some instances where this shim was out of spec from the factory and can cause vibration in the CPS leading to misfires and also idle problems.
#26 |
Drives: 2013 Asphalt FR-S
So, what symptoms did you and the others you mention as "us" have?
~Namaste~ |
#27 | |
http://www.ft86club.com/forums/showt...t=20930&page=2 |
#28 | |
So, without that teflon seal, combustion gases were getting up the shaft of the injector, hence why #1 was brown and nasty while #3 was clean. The pop noise must be that insulator popping out of place under the pressure and that explains why it was worn down on the side. Any word if the seal did not get installed at the factory or just melted or what? Did you ever get miss-fire codes?
~Namaste~ |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
| Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 12:41 AM |
| Bulb codes | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-17-2013 03:25 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 05:03 PM |
