Old 05-11-2013, 09:40 PM   #15
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
Originally Posted by ATL BRZ View Post
Not likely related, probably just exhaust backfires, which are normal especially with aftermarket exhaust.
I had this issue with the stock exhaust. First time I heard it it was embarrassing to say the least lol
Asphaltfrs1 is offline   Reply With Quote
Old 05-12-2013, 12:33 PM   #16
fishek
Drives: H8R FR-S
Originally Posted by romin View Post
I first hit CEL P0351, cylinder 1, while running on the track, cleared it a couple times but it kept coming back.
^^^ This (though not sure which cylinder/coil pack).
I took it to the dealer. They asked me if I had any mods and I said I don't have any mods to the powertrain. They replaced the coils under warranty.
I had one track day after that but was a low speed track and not much WOT and no CEL. I will be on the track this weekend on two much faster tracks. I will see if I get any CEL and report here.
If you want to make a small fortune in motorsports, start with a large one
fishek is offline   Reply With Quote
Old 05-12-2013, 02:21 PM   #17
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
Given this diagram:
I believe this teflon ring is the part that folks have found damaged or completely missing from their direct injectors:
Can someone confirm?
Did other folks find additional parts damaged?
Update, others have also found these insulators damaged on many vehicles:
romin is offline   Reply With Quote
Old 05-12-2013, 08:12 PM   #18
peachch
Drives: White 86 Sport Plus
Given this diagram:
That is O-Ring. You also need direct port injector insulator.
peachch is offline   Reply With Quote
Old 05-12-2013, 08:15 PM   #19
peachch
I think most of us replaced only insulators. Somehow, I got one missing O-Ring injector. Then, I replaced both.
Old 05-12-2013, 10:01 PM   #20
romin
romin's Avatar
OK cool, I have four of the insulators as well.
What kind of damage did you find on the insulator, any photos?
Old 05-12-2013, 10:09 PM   #21
peachch
The picture I posted above is where the insulators got damage. The coating was gone.
Old 05-12-2013, 10:18 PM   #22
romin
romin's Avatar
Did you replace these parts yourself?
Old 05-13-2013, 12:26 PM   #23
peachch
The hardest part is replacing O-ring since I do not have SST.
Old 05-13-2013, 01:00 PM   #24
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
Can anyone describe or have photos of the visual clues to look for? Will there be fuel residue or some other indicator where the fuel injectors insert into the block? Is some fuel exiting past the Teflon seal? You could make a regular visual inspection when you check oil level or something.
Amadeus is offline   Reply With Quote
Old 05-13-2013, 01:55 PM   #25
2forme
FWIW, I talked to someone at Subaru this weekend about TSB 11-130-13. Apparently it replaces a "shim" of sorts for the camshaft position sensor. I guess there were some instances where this shim was out of spec from the factory and can cause vibration in the CPS leading to misfires and also idle problems.
Old 05-13-2013, 03:00 PM   #26
mad_sb
Drives: 2013 Asphalt FR-S
So, what symptoms did you and the others you mention as "us" have?
Old 05-13-2013, 07:48 PM   #27
peachch
http://www.ft86club.com/forums/showt...t=20930&page=2
Old 05-13-2013, 08:45 PM   #28
mad_sb
Wow, that really is a pop sound, like a pop-gun or the pop noise you make with your finger flipping it out of your mouth... lol I thought you meant pop like a small explosion in the intake runner would make....
So, without that teflon seal, combustion gases were getting up the shaft of the injector, hence why #1 was brown and nasty while #3 was clean. The pop noise must be that insulator popping out of place under the pressure and that explains why it was worn down on the side.
Any word if the seal did not get installed at the factory or just melted or what?
Did you ever get miss-fire codes?
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 12:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 03:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
