View Poll Results: Answer bellow!!! Interested. Also please make a post of what "issues you had"
1-2k miles 9 40.91%
3-5k miles 5 22.73%
6-8k miles 1 4.55%
9-11k miles 2 9.09%
12-14k miles 0 0%
over 15k 1 4.55%
Blown Engine 2 9.09%
No issues 7 31.82%
Boost issues 0 0%
drivetrain issues 1 4.55%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
Old 05-05-2013, 02:26 AM   #29
ft_sjo
Drives: GT86
Is it really fair for vendors to be voting on this poll?
Old 05-05-2013, 01:35 PM   #30
Supermassive
Supermassive's Avatar
Im currently at 10k miles on my P&L kit with zero issues, I'm only running 7lbs of boost atm but I certainly dont baby my car. Im waiting to turn up the boost until I finish up some other things on the car so we'll see how she reacts to that one of these days.
Supermassive is offline   Reply With Quote
The Following User Says Thank You to Supermassive For This Useful Post:
NickFRS (05-05-2013)
Old 05-05-2013, 04:41 PM   #31
NickFRS
Drives: 2013 Asphalt FRS
stock engine?
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-05-2013, 04:42 PM   #32
NickFRS
Originally Posted by DaBrz View Post
Question: I've never owned a Turbo or supercharged car before (not even from the factory). Is there any extra maintenance over running NA to avoid issues?
Yes. Oil changes have to be done sooner and you will have the check your oil every time you fill your tank. Well you should always check your oil when you fill your tank.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 05-06-2013, 06:07 AM   #33
Supermassive
Originally Posted by NickFRS View Post
stock engine?
Yes
NickFRS (05-06-2013)
Old 05-09-2013, 01:21 PM   #34
cf6mech
Drives: FRS Silver LS1 swapped.
You really need a poll option that has a square for issue with kit..i.e.fit and finish,..complete,...etc......The Blown engine choice should be thrown out,....as that can be from a bad tune or driver induced,....i.e. not paying attenton to engine vitals.
cf6mech is offline   Reply With Quote
Old 05-09-2013, 09:04 PM   #35
NickFRS
I can DD my Sti's every day w.o worrying about staring at gauges to make sure my engine isn't going to blow. If the fullblown requires you to watch AFR's and boost maybe there is something wrong with the kit. Driver error can always produce blown engines. But a flawless turbo kit shouldn't require someone to eye ball a gauge 24/7. But if the engine is blown due to shop or w.e it will be discussed. In a month or two i'll make a second post with another poll to see where everyone is at. Hopefully by then someone will be 20k+ and i'll make more options. I do agree with you.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 05-10-2013, 03:16 AM   #36
cf6mech
Don't have a Full Blown kit,... but no kit is flawless,...and none of us have a warrantee anymore going FI,....keeping an eye on vitals seems a common sense thing to do , not suggesting 24/7 but most definately more than periodical when running at higher rev ranges,..or,.. any time your seat of the pants gauge tells you something is different .....just my opinion.
The Following User Says Thank You to cf6mech For This Useful Post:
NickFRS (05-10-2013)
Old 05-10-2013, 03:40 AM   #37
ft_sjo
Drives: GT86
That is a ridiculous statement. Any aftermarket turbo kit provider doesn't have multi-million dollar budgets to develop at OEM standards and test in all scenarios all around the world.
If you CHOOSE to modify a car, then due diligence should be done for a) understanding roughly what's going on and b) how to detect a problem early.
Bear in mind that all these turbo kits are just manifolds, turbochargers, intercoolers and some pipework. The main difference is the tune that sits on top, which will either make or break a conversion. The other factor for durability is how the turbocharger lubrication is handled, which differs between the vendors.
The Following User Says Thank You to ft_sjo For This Useful Post:
Old 05-10-2013, 04:53 AM   #38
NickFRS
This is what some don't understand. These kits are not plug and play and go rev out your car. Also the reason for making this thread. Glad you agree with me good sirs. I'm personally sitting back and letting others be ginny pigs. I do believe that some of these kit's will be solid though. My main concern is in fact the internals. There is no such thing as a high compression engine loving high boost. well for very long at least.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 05-10-2013, 05:30 AM   #39
cf6mech
Precisely why I don't have a high compression engine and why I'm running 18psi of boost and looking for more. I have a stage 3 engne forged at 9 to 1,...but the OEM fuel system lacks the volume needed to sustain anything over that with e85 safely....so I'm going to a custum fuel system...
Old 05-10-2013, 05:38 AM   #40
NickFRS
Precisely why I don't have a high compression engine and why I'm running 18psi of boost and looking for more. I have a stage 3 engne forged at 9 to 1,...but the OEM fuel system lacks the volume needed to sustain anything over that with e85 safely....so I'm going to a custum fuel system....
Interesting. Didn't know you had a built block. That changes things good sir! What exactly is lacking in the system? Fuel pump? If thats the case look into radium Eng. They make lots of universal solutions and are also looking for a project car.... You might spark their interests if you have cash to help sway their minds in producing something. It's a local Portland shop that does turbo kits for lotus and BMW and anything looking to go big.... lol
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 05-10-2013, 01:55 PM   #41
cf6mech
Whats lacking is you reach a point in this engine where the demand exceeds the supply and it leans out, its not so much pressure but volume (E85). As noted this engine wasn't designed for FI. Ultimately in my build I'm looking for reliability in the long term for weekend driving and track duty. My car dyno'ed at 400whp but leans out bad with a 60mph roll on. Others like Don at AP , and the guys at Full Blown know of this issue hence the FA20 fuel rails I'm installing that,... some are confusing as only bling, along with pressure regulator, custom lines and, a return line to tank etc.. And this is with a relatively small GTX2867R turbo. Surge tank and or inline bosch pump may be necessary once we create the volume if the Deatchwerks tank pump can't keep up. We shall see.
NickFRS (05-13-2013)
Introducing the D3PE "KLR" turbo system... Evan@D3PE Forced Induction 25 06-15-2013 01:24 PM
How many miles do you have on your "Turbo Kit" + Other's poll questions NickFRS Forced Induction 0 05-01-2013 07:22 PM
At about 3000 Miles, Engine became quite a bit "smoother" jflogerzi Engine, Exhaust, Transmission 10 09-04-2012 12:11 AM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 02:53 PM
