| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
#183 |
Drives: Toyota 86
Interesting, what's a set up like that cost? Something I should look at... I live and work in impractical areas so it'll suit me.
#184 | |
Drives: 2013 SWP BRZ
Airlift struts - 995 a set (need front, rear, so 1990) Airrex also has struts available but they are 2350 I believe Management system - You can opt to go for the eLevel system (which is a height sensor based system - 4 sensors are installed in each corner) but that is around 1800 last time I checked. I have the AutoPilot v2 which is a pressure based system (no sensors in each corner) and thats around 1200. Mine was cheaper because I already had parts of the system from my old sti. I actually had the elevel which is great, it does all the thinking for you, but I was hesitant to drill into a new car to install the sensors and theres more involved with installation on it, so I decided to try out the v2. I like both, the elevel is a bit easier to use but I like the fact that the v2 has a controller that you can see PSI in each corner, its great for tracking down leaks/monitoring (elevel has a controller but doesn't have a display for pressure, you would need to install gauges). You could do a basic management system with paddle valves for like 500-600 bucks, but you need to mount gauges to monitor the pressure, and also mount the paddle valves somewhere. Wandering on the VW forums, a lot of people prefer this setup because there are less working parts which means less leaks, less worry, and you don't have to worry about an ecu crapping out on you and getting stuck lol. It all really depends on what you want. It could cost up to 4.5k, down to 2500-3k. |
#185 |
Drives: 2006 STi
dont think the BRZ section has an aggressive wheel thread..
but here it is- BC Coils 18x10 front, 18x11 rear. ![]() ![]() ![]()
| The Following 6 Users Say Thank You to SLICVIC For This Useful Post: | 636 (05-10-2013), boucher (05-09-2013), jdmasfcuk (05-11-2013), SciOnDrifTtSlIdeR (12-28-2014), xxscaxx (05-09-2013), zenki_levin (05-09-2013) |
#186 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#187 |
Drives: Toyota 86
Have you got your Meisters yet?
SLICVIC - have you removed the collars from your BC's? |
#189 |
My FR-S has 5 gears
Ya both sets are at home... I'll be back in less then a month hopefully.
Omar GC
| The Following User Says Thank You to OmarGC For This Useful Post: | JDMenrique (05-09-2013) |
#190 |
OG <FR-S'less> Member
Drives: yes
Dem Porsche wheel ain't for me but props for being different.
| The Following User Says Thank You to jedichimp For This Useful Post: | SLICVIC (05-10-2013) |
#191 |
Drives: Fr-s
#192 |
My FR-S has 5 gears
Yeah 18x9.5 +27 bronze/gloss bronze
Then I also got a square set of 18x10's
Omar GC
#193 |
#194 |
FR-S Owner!
Drives: 2013 FR-S Ultramarine 6AT
XXR 530s w/Eibach Pro-Kit:
| The Following User Says Thank You to Moshpit37 For This Useful Post: | mgarcia707 (03-18-2019) |
#195 |
Drives: 13 FRS
18x10s
#196 |
| The Following 10 Users Say Thank You to PRORICAN For This Useful Post: | boucher (05-10-2013), chanomatik (05-21-2013), HATED1 (05-10-2013), Jesse@JDLAutodesign (05-10-2013), Juvenile (05-10-2013), M-17 (05-10-2013), sal (05-10-2013), tomato86 (06-12-2013), Wolfking (09-24-2014), Zaku (09-15-2013) |
| Tags |
| dontlike?dontlookmoveon |
| Post the Wheels You want On your FRS/BRZ!! | Zaku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1738 | 10-11-2017 04:29 PM |
| RPF1 and PF01 aggressive fitment size requests | Crossover Auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-22-2012 02:30 PM |
| post VIN with any problem thread? | fistpoint | Issues | Warranty | Recalls / TSB | 0 | 10-04-2012 10:11 PM |
| Do aggressive offsets cause more debris to kick up into the paint? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-26-2012 10:03 PM |
| Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 06-15-2011 02:20 AM |
