Sam Strano
Old 05-09-2013, 10:37 AM   #29
ayau
Drives: Some rust bucket
Originally Posted by Sccabrz192 View Post
My concern is those bolts are smaller diameter than OE in order to offset the holes with the lobe so you are reducing the capability of the bolt in that joint when it comes to bolt shear and clamp load. I'll admit I'm being a little over cautious, but I'm not interesting in taking a chance of shearing off a strut bolt on my 28,000 vehicle because I was trying to get an extra .75 degrees of camber with a $40 dollar fastener. Michigan's roads are particularly what have me worried about it more-so than an autocross or track setting where most places are relatively smooth and your inputs are mostly mid and low frequency inputs.
which top plate are you using?
The factory recommended OEM crash bolts are also 14mm if I recall correctly. I'm not an engineer, but if Subaru engineers recommend using it, then I won't be arguing. If it helps, the bottom bolt doesn't have any play, and I think that bolt takes more punishment than the top bolt.
I'm using the top plates that were included in the Eibach R2 coilovers.
Old 05-09-2013, 11:01 AM   #30
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Any of you guys see the Street Tire comparison in the June issue of Grassroots? I just got mine in the mail yesterday and am looking through it a bit today at work.
I am kind of bothered that they didn't test the RS3 and that the test they did was on a STS prepped CRX. It sucks because last year when they did this tire comparo I had a ST Civic and they used a BMW. Now I have a car closer to the BMW and they did it on a car that is almost the same as the Civic... also, why no RS3s?!
I can scan in the article and post it up if anyone is interested and it isn't available online.
DylanFRS is offline   Reply With Quote
Old 05-09-2013, 11:15 AM   #31
ayau
Please scan it, thanks!
Old 05-09-2013, 11:49 AM   #32
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Originally Posted by Dezoris View Post
I will just add my build to this thread:
Dezoris RTR AutoX Build Thread
Shocks: OEM
Front ARB: Strano (From Stranoparts)
Camber Correction Front: OEM Crash/Camber Bolts (Subaru)
Tires: 225/45/17 Hankook RS3s (Discount Tire)
Brakes: Project Mu HC800 (Vendor CSGMike)
Alignment: (Private)
FR (Camber -1.5 - Toe Out -.05)
FL (Camber -1.5 - Toe Out -.05)
RL (Camber -1.3 - Toe In -.08)
RR(Camber -1.3 - Toe In -.08)
AutoX Video: (Forward to 11m:19seconds)
Final Thoughts:
In all honesty if you are strapped for cash, I would not even consider doing more than this, as it is completely competitive in local clubs for 1-3rd place in class. I have had 4 events and so far its even good for competing with your STX competition. All you need is some seat time to improve.
The car feels excellent, on the street and autocross. Very impressed.
It's a setup I stand behind for daily driving and driving right to any event no drama. (Brake pads are totally optional as they made fractional difference for me in performance overall)
However I doubt this would be competitive on a national level but, I have yet to try.
Might be using this as my alignment setup as well.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 05-09-2013, 12:55 PM   #33
edj
edj's Avatar
Drives: 2022 Toyota GR86
re: the FR-S/BRZ crash bolts
the Twins come with two different sized bolts to hold the steering knuckle to the strut.
(14mm and 16mm?).
the factory authorized crash bolt is the 14mm bolt. all you are doing is replacing
the larger OEM bolt with the smaller one. so you end up with two 14mm bolts.
There should be no worries about the crash bolt being strong enough.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 05-09-2013, 01:42 PM   #34
Dezoris
Dezoris's Avatar
(14mm and 16mm?).
Whiteline and SPC claim the bottom hole is more critical for load bearing.
Sheering the top bolt should be not a major concern. As long as they are installed properly and torqued I don't see how it is much more different than the OEM bolt. I would be more worried about small allen head lock nuts on camber plates slipping over that strut bolts.
Old 05-09-2013, 01:54 PM   #35
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Hahaha... for sure...
Everyone who is racing will soon be running both the crash bolts and top hats anyways. The real question is, how did you get 1.5* of camber out of them Dezoris?
Old 05-09-2013, 04:37 PM   #36
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I need to recheck for clarification but I believe the lastest Fastrack clarified that you may use Tophats OR Bolts. Not both
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-09-2013, 04:40 PM   #37
Kido1986
Dodging cones
Kido1986's Avatar
F. Strut-type suspensions may adjust camber using one of the following two options:
1. Adjustable camber plates may be installed at the top of the strut and/or the original upper mounting holes
may be slotted. The drilling of holes in order to perform the installation is permitted. The center clearance hole
may not be modified. Any type of bearing or bushing may be used in the adjustable camber plate attachment to
the strut. The installation may incorporate an alternate upper spring perch/seat and/or mounting block (bearing
mount). The spring’s upper mounting position relative to the chassis, and along the strut shaft centerline, must
not be higher relative to the chassis than the standard part (ie, the camber plate may not result in a lower ride
height). Caster changes resulting from the use of camber plates are permitted.
2. Camber bolts may be installed and one bolt’s mounting point(s) on the strut’s lower integral mounting bracket
may be slotted. Caster changes as a result are permitted.
To me, that reads as one OR the other.
Old 05-09-2013, 04:45 PM   #38
DylanFRS
Lost in Kansas
DylanFRS's Avatar
I was reading that as "camber bolts" being defined as aftermarket. Technically the crash bolts are just there in case of a suspension problem after an accident. So the car is 100% OEM with them in right? Thus the only mod from stock would be the upper camber plates.
I think it is worth talking about because it is not completely clear to me. :happy0180:
Old 05-09-2013, 05:05 PM   #39
TRev
This is the way I interpreted as well.
TRev is offline   Reply With Quote
Old 05-10-2013, 07:33 AM   #40
Biggins
Drives: Yes
Perhaps it is not too relevant, but could we also add what popular aftermarket rims/wheels are available and legal for the class?
I had a bear of a time finding 17x7 42-54 rims last year, so I'm still running the OEM rims. I still have not pulled the trigger, but I assume the Enkei and Kosei options are best?
Biggins is offline   Reply With Quote
Old 05-10-2013, 08:35 AM   #41
edj
edj's Avatar
The Enkei RPF1 wheels are your first (and really only) option.
The Kosei wheels are OK but if you are putting any tire on them wider
than a 225 then you will need a 1/4" spacer on the front wheels and
now you need longer lug bolts to get the lug nuts to fit properly.
Eric
Old 05-10-2013, 08:36 AM   #42
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Motegi Tracklites are also an option.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
