Old 05-08-2013, 04:46 PM   #15
oofie
Originally Posted by Dezoris View Post
No only toe. Sucks big time.
Thanks! So how were you able to do -1.3* of camber in the rear? Or does it come from factory that way?
oofie is offline   Reply With Quote
Old 05-08-2013, 04:48 PM   #16
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Originally Posted by Sccabrz192 View Post
Andrew and Sam posted info on how to adjust rear toe through the subframe bushings if you find your car came from the factory with left to right toe imbalance.
Why would you adjust at the subframe bushing rather than just evening the toe out through the toe adjustment?
DylanFRS is offline   Reply With Quote
Old 05-08-2013, 04:52 PM   #17
ayau
Drives: Some rust bucket
I think it's important to note that you can only use OEM Subaru or Toyota crash bolts. Dedicated camber bolts aren't allowed in stock class.
Old 05-08-2013, 04:57 PM   #18
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I said OEM. I plan on finding the part # later to post in the OP.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 05-08-2013, 04:59 PM   #19
Kido1986
Dodging cones
Kido1986's Avatar
I wonder if he was mistaken and meant Camber? Since toe is easy to adjust on rear.
Old 05-08-2013, 05:00 PM   #20
ayau
Toyota: SU003-02818
Subaru: 901000394
Old 05-08-2013, 06:52 PM   #21
TRev
When you get a chance, please add Whiteline 20mm bar under the front sway bar section as well as adjustable end links.
Also maybe a shock/strut tuning section that includes this info?
Corner entry over steer: Soften rear rebound
Corner entry under steer: Stiffen rear rebound
Corner exit over steer: Stiffen front rebound
Corner exit under steer: Soften front rebound
Mid corner over steer: Stiffen front bar
Mid corner under steer: Soften front bar
TRev is offline   Reply With Quote
Old 05-08-2013, 08:54 PM   #22
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Doh, got distracted while writing and lost my train-of-thought... (is that the proper spelling of train in that context? Oh well) yes I meant camber.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 05-08-2013, 08:58 PM   #23
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Yet... if street class passes it would become legal in 2014.
With that said, would anyone in Street be daring enough to use something like the Whiteline 14mm camber bolt? I don't think I'm going to be that brave. Not to use daily, especially in MI. I will probably just slot one of the strut bodies personally once that allowance is legal.
Old 05-08-2013, 09:35 PM   #24
ayau
Is the 14mm Whiteline bolt the one with the adjustable cam lobe? Are you worried that the bolt will slip?
I have OEM crash bolts and camber top plates and can get more than -3.5 (estimate). Without the top plates, I was only able to get about -1.2 with just the OEM bolts.
Old 05-08-2013, 10:08 PM   #25
TRev
If they leave the adjustable camber plate allowance in the proposed rules, I will definitely be going that route (caster).
Since our cars are currently allowed to use the factory adjustable camber bolt, do the proposed rules imply that we can use those bolts along with the camber plates?
Old 05-09-2013, 01:47 AM   #26
suaveflooder
I have no issues with wear as that toe is still within factory spec.
With all my cars I run on the street and track I always setup slight toe out in the front as it improves turn in/steering feel.
Toe in on the back for braking stability.
I have done this on my Lotus, Atom and S2000 and have been very confident. There are benefits to zeroing toe in the rear on this car but not many for street driving aside from potential wear. As always this is driver dependent, but that's why I do it in short.
Nice! Thanks for the information! :happy0180:
suaveflooder is offline   Reply With Quote
Old 05-09-2013, 06:56 AM   #27
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
My concern is those bolts are smaller diameter than OE in order to offset the holes with the lobe so you are reducing the capability of the bolt in that joint when it comes to bolt shear and clamp load. I'll admit I'm being a little over cautious, but I'm not interesting in taking a chance of shearing off a strut bolt on my 28,000 vehicle because I was trying to get an extra .75 degrees of camber with a $40 dollar fastener. Michigan's roads are particularly what have me worried about it more-so than an autocross or track setting where most places are relatively smooth and your inputs are mostly mid and low frequency inputs.
which top plate are you using?
Old 05-09-2013, 09:46 AM   #28
DylanFRS
Lost in Kansas
DylanFRS's Avatar
I was a bit weary about using the OEM crash bolts for the same reason but since they are factory approved I figure they must have a decent safety factor built in even on the smaller bolt.
I was planning to use these, which are the same as the ASTs according the posts in the thread. But supposedly they maintain stock ride height.
The Whitelines also look nice, here, but they don't say anything about whether or not they maintain stock ride height.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
