Old 05-08-2013, 10:06 PM   #1
Sniper2606
Sniper2606's Avatar
Broke the stock overpipe bolt :/
So while installing my front pipe today, one of the stock overpipe bolts broke because the nut did not wanna come out even tho it only had just a lil bit left to go not sure why it got stuck towards the end, so the bolt broke, i now have a leak, what can i do to fix this? should i just get a aftermarket overpipe? or would i need a tune for that
Thanks.
Sniper2606 is offline   Reply With Quote
Old 05-08-2013, 10:27 PM   #2
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I haven't seen one up close, so I'm talking out of my rear, but perhaps you can press the broken stud out? Be sure to replace it with a bolt that can handle heat. On the other hand, since you'll have to remove the stock overpipe it would be the perfect time to put in an aftermarket one.
You wouldn't necessarily need a tune, but it would help you get the most out of a new OP/FP combo.
Chimpo is offline   Reply With Quote
Old 05-08-2013, 10:30 PM   #3
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Got any pics? I'm gonna switch out my front pipe tomorrow night. If I can get a visual, maybe I can give some advice. Can you drill out the broken bolt? (Without ruining the threads on the nut of course.) Or take it to a muffler shop and get it repaired...
JimmyMac is offline   Reply With Quote
Old 05-08-2013, 10:30 PM   #4
Sniper2606
Sniper2606's Avatar
Well if i dont need a tune, might as well buy it
Old 05-08-2013, 11:11 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks.
It got stuck most probably because it was cross threaded towards the end. Whomever assembled it doomed you from the start. There are tools to remove broken bolts.
Either that or use it as an excuse to get an aftermarket piece
Old 05-08-2013, 11:17 PM   #6
Sniper2606
Sniper2606's Avatar
Well fudge, i just spent $4k on the supercharger ugh fml, whats the cheapest overpipe i can get lol
Old 05-08-2013, 11:17 PM   #7
mkivsoopra
Same thing happened to me. You'll have to drill it out or get creative, depending on how much of the stud is left. It'll probably be easier just to get an aftermarket overpipe.
mkivsoopra is offline   Reply With Quote
Old 05-08-2013, 11:18 PM   #8
Sportsguy83
Drives: Limited BRZ
I believe FA20 club. Hey, after 4K on the charger, its a good thing to start with the exhaust Good Luck!!
Old 05-08-2013, 11:21 PM   #9
Sniper2606
Sniper2606's Avatar
True, just wasnt expecting on upgrading the over pipe yet, i was planning on buying that along with UEL headers, but im SOL right now, unless i wanna drive with a leak
Old 05-08-2013, 11:26 PM   #10
Sniper2606
Sniper2606's Avatar
And also i heard the install is a bitch on the overpipe
Old 05-08-2013, 11:26 PM   #11
cnk
Drives: '13 DGM BRZ Limited
If there is enough stud left you can try using a stud remover. You can get replacement studs from Pep Boys, Advanced Auto Parts, Autozone, etc. Just spray the stud down with some PB Blaster and let it sit a while, then use the stud remover. They have different kinds, one is a cam type and another is one where you hammer it on the stud and use a wrench to take it out. The stud is threaded in so you can't just punch it out.
Old 05-08-2013, 11:42 PM   #12
Xdragonxb0i
Drives: ex500r
it is a bitch to remove / install the overpipe. Easiest way is just to lift the engine a few inches.
Want to buy my stock overpipe, give me an offer?
Xdragonxb0i is offline   Reply With Quote
Old 05-08-2013, 11:49 PM   #13
Sniper2606
Sniper2606's Avatar
Can it be done with out lifting the engine?
Ill go ahead an order aftermarket, might as well
Old 05-09-2013, 12:13 AM   #14
Xdragonxb0i
Drives: ex500r
i dont think you can? I couldnt twist it out even with the headers removed. it was just easier for me to lift it.
Maybe other members can chime in.
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
Oh-Oh's, I Think I Broke It! track_warrior Issues | Warranty | Recalls / TSB 232 06-12-2013 10:58 PM
Selling stock overpipe, midpipe, and exhaust for anyone interested markmatley Hawaii 0 02-20-2013 09:37 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
Replace stock hubs with different bolt patern ones? ahausheer Other Vehicles & General Automotive Discussions 10 02-07-2012 12:24 AM
