Old 05-03-2013, 03:42 PM   #15
hapa_kcm
hapa_kcm's Avatar
Drives: WRB BRZ Limited
I have the Hotchkis one and love it. IMHO I like the the look of the Hotchkis one over the AEM because the Hotchkis one uses oval tubing instead of round tubing like the AEM. Technically speaking, the round tube would provide less deflection if the widest part of the elipse equallys the diameter. Now if they weigh the same, the oval tubing would actually deflect less. I personally do not know the actually dimensions of the tubing of either (don't know wall thickness of the Hotchkis one), so I cannot say what theoretically will deflect less. On the side note, I actually know both people that did design both of them (used to work with both of them actually). I will try to contact the guy with the AEM one and ask him if he know an ETA
hapa_kcm is offline   Reply With Quote
Old 05-08-2013, 01:04 AM   #16
hapa_kcm
hapa_kcm's Avatar
I'm a little slow on the response with the AEM brace. So they do plan on releasing it soon (a lot of stuff at sema is feelers), but there will be a very intriguing improvement to it's strut brace over what has been publicly seen. They expect to add a master cylinder brace to it too!!!!! Pretty crazy. If I get some pics of it, will definitely post it up
Old 05-08-2013, 02:25 AM   #17
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Really? Waiting on these!!!
Old 05-08-2013, 02:39 AM   #18
hapa_kcm
hapa_kcm's Avatar
Might get a pic of it tomorrow, or atl east within the next week. I'll keep you posted
Old 05-13-2013, 01:55 AM   #19
OICU812
Just a dude
OICU812's Avatar
That damned AC line is in the worst spot, over time has anyone seen some of the hose externally rub away? Wish it was as easy as an unbolt and over, but with the Hotchkis design is there enough slack to go over and under the bar anyhow??
Old 05-13-2013, 02:02 AM   #20
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Young Tea ( i hope i have his name correct) has the AEM front strut installed, I've seen it a couple of time in the DJ jamboree irvine meet. It looks pretty sweet, but i bet Hotchkis would preform similar. He did state that it had some stop or a part that holds the brake fluid tank in place ( something to do with hard track driving, I'm no suspension guy but thats what he stated+ he's also sponsored by them so thats why)
Old 05-13-2013, 02:06 AM   #21
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Originally Posted by NickFRS View Post
sweet deal sounds good. For the price of all the strut bars out there it looks like it's the best for my buck!
I also got the Hotchkis front strut brace.. I like the way it looks and how integrates all 3 braces. I actually took the sticker off to give it a stock look.
mike_ekim1024 is offline   Reply With Quote
Old 05-14-2013, 04:50 AM   #22
OICU812
Just a dude
OICU812's Avatar
Has anyone attempted to take the H bar on install and rotate it in manor when installing to have the AC hose over top of the front bar, versus underneath? Is there enough slack to do so on that line with this bar?
Old 05-14-2013, 09:50 AM   #23
DriftEm
DriftEm's Avatar
I tried but the AC hose doesn't have enough slack, if you want the hose on top, you need to remove it to re-route.
DriftEm is offline   Reply With Quote
Old 05-17-2013, 10:49 AM   #24
hapa_kcm
hapa_kcm's Avatar
@OICU812
Here you go
The Following User Says Thank You to hapa_kcm For This Useful Post:
OICU812 (05-22-2013)
Old 05-22-2013, 10:45 PM   #25
OICU812
Just a dude
OICU812's Avatar
Hotchkis bar..
So I got this, easy enough to place in. Without even driving yet went to take off due to my master cylinder brace came in. Long story short what's the trick to removing? Pulled every which way like a mad gorilla and seems the two points where it bolts to the strut studs is literally wedged onto those bolts??
I installed the master cylinder brace obviously without removing the hotchkis strut tower brace but... I can see more cursing the day I actually need to remove this brace...
That AEM with incorporated brace looks "simpler" Ahhh well seems my patience is my enemy sometimes ...
Old 05-22-2013, 11:03 PM   #26
DriftEm
DriftEm's Avatar
Hotchkis bar..
I took off mine with no issue, I mean I needed to wiggle it a little but it was easy.
Old 05-23-2013, 12:59 AM   #27
OICU812
Just a dude
OICU812's Avatar
Strange I was doing more then wiggling lol...
Old 05-23-2013, 10:48 AM   #28
hapa_kcm
hapa_kcm's Avatar
Hotchkis bar..
When it is hard to install/uninstall single piece strut tower braces, try lifting one of the corners of the car to make the body twist a little bit. I had to do this with a Neuspeed brace on my EM2 Civic back in the day. Better to a have a rigid piece to brace then something that is adjustable when it can come loose
My Strut Brace Mod... Andrew666 AUSTRALIA 4 03-04-2013 10:38 PM
FS: [VIC] *NEW* Cusco Front Strut Brace w/ Brake Cylinder Stopper green_comet Australia Classifieds 1 12-11-2012 10:10 PM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
Which Rear Strut Brace? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-21-2012 10:01 AM
