Old 04-13-2013, 07:43 PM   #29
fldoc
fldoc's Avatar
Just got home from the dealer after swapping OEM tires for the MPSS. I echo the "night and day" response from the thread. The steering has a more on-center feel and the car feels more settled all around (probably the rubber they "should" have put on the car). I used to run these tires on my '10 GT3 and loved them. I used to say that if Michelin PS2 and Sport Cups had a child...it would be the MP Super Sports!
Track report to come soon....
_____________________________
-Ramon
'10 GT3 (gone but not forgotten), '12 GT-R Black Edition, '13 FR-S
fldoc is offline   Reply With Quote
The Following User Says Thank You to fldoc For This Useful Post:
Clipdat (06-20-2013)
Old 04-13-2013, 09:12 PM   #30
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Size and approx PSI?
Khyron686 is offline   Reply With Quote
Old 04-13-2013, 11:33 PM   #31
fldoc
fldoc's Avatar
Stock 215/45/17, think they filled it to 35 cold. I usually run this tire at low-mid 30's hot on my other cars, although I will see how they work at those pressures with such a light car.
-Ramon
Old 04-14-2013, 01:12 AM   #32
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I loved the Pilot Super Sports on my 550i. They did wear a bit quickly, I must say. They also got sort of slippery on the track, but it was a 4000lbs car. Wonderfully predictable on losing grip once they were a bit warmed up. Tons of fun. When I'm done with the Primacys, I'll switch to them, probably. Then again, there are soooooo many options...
Old 04-14-2013, 06:27 AM   #33
Jaqub Jackson
Drives: Honda Civic
The stock which was swapped out for Pilot Super Sports cars are really gorgeous. The new styles of tires are also impressive. I am madly waiting for Sunday when you view the new skins. Thank you so much.
Jaqub Jackson is offline   Reply With Quote
Old 05-07-2013, 11:02 PM   #34
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
I just bought PS2s for my FRS, and i lose traction like its nothing?
What do people have their tire pressure set at?
running 225/40/18 && 255/35/18
Scalzo is offline   Reply With Quote
Old 05-11-2013, 07:59 PM   #35
EAGLE5
Dismember
EAGLE5's Avatar
PS2 or pilot super sport? different tires. Tires should be set at what the door says.
Old 05-11-2013, 08:52 PM   #36
Scalzo
Scalzo's Avatar
PS2, but they are different sizes, isn't the door PSi for stock set up.
Old 05-11-2013, 10:38 PM   #37
EAGLE5
Dismember
EAGLE5's Avatar
Usually they recommend what's on the door. You can always change from there. Tires can go much higher, of course, but when you heat them up, they'll go higher still. Just try some different amounts until you find something that grips better. You can also draw with chalk on the treat and see if it's rubbed off evenly after you drive. If there's more left in the middle, you're under-inflated. More on the edges and you're over inflated.
Old 05-13-2013, 02:08 AM   #38
supra2nv
supra2nv's Avatar
Drives: 10 Series TRD
are these what come on the trd car? I believe I will be ordering a set of these tires myself.
supra2nv is offline   Reply With Quote
Old 05-13-2013, 02:45 AM   #39
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I swear by the Super sports for all around tires. with a bit of spirited driving and normal commuting they are the real deal, and they also look sweet. The only issue we had with them is that they get eaten up real quick , very very quick but that was on a torque crazy monster cl63 and a Ferrari 458 so i assume they are going to last a lot on the 86's.
Old 06-20-2013, 10:34 AM   #40
Thevillageidiot
Drives: 2013 Limited Subaru Brz
I had Super Sports on my Mk6 gti they made a huge difference. I used the stock oem size as well, however with the brz should i go up one size larger in tire from the 215 stock to a 225?
Thevillageidiot is offline   Reply With Quote
The Following User Says Thank You to Thevillageidiot For This Useful Post:
sanbaifo (09-26-2022)
Old 06-20-2013, 12:59 PM   #41
EAGLE5
Dismember
EAGLE5's Avatar
Remember, the Super Sports have treadwear warranty!
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 06-23-2013, 09:47 AM   #42
immortal_suby
Drives: 2015 BRZ Limited 6MT
I've been debating this in my head for a while. I think I want more grip, but I'm not planning on any power mods - so maybe I don't want more grip.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
Wheel Directory: OZ Ultraleggera 17x8.0 +48 Mageep Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 104 04-11-2021 12:03 AM
Wheel Directory: OZ Alleggerita HLT 18x8.0 +48 O.Z. BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 04-16-2015 06:49 AM
Michelin Pilot Super Sports Warrenty? FLASCH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-11-2013 10:39 PM
Pilot Super Sports Got3n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-10-2012 12:23 AM
Michelin Pilot Super Sport 17 inch DieselBoXXer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-05-2012 10:17 PM
