#43 |
Drives: 2013 Asphalt FR-S
[quote=vtmike;911550]You guys should both get a log of your long term fuel trims during a pull.
~Namaste~ |
#44 |
e85 or pump? 12:1 is too rich for pump if you want to make good power.. e85 will probably target high 11's to very low 12's.
~Namaste~ |
#45 | |
Drives: Scion FR-S
[quote=mad_sb;913053]
http://db.tt/F4U3KETY Sent from my Nexus 7 using Tapatalk HD |
#46 |
Grip>Slip
#47 | |
Drives: Scion FR-S
#48 |
Drives: Moped
I never said that it was...civicdrvr mentioned he had excess black soot accumulating on his exhaust tip, that coupled with him looking to be down on power can be an indication of a rich fuel mixture....
#49 |
Ahh, yeah, that makes more sense now. I'm waiting on openoffice to dl so i can peak at the log... just reloaded my laptop.
~Namaste~ |
#50 |
Ohh, For sure man. Sorry i was more addressing then smoke issue in general after looking at his plot and seeing the afr rather than your feedback to him.
~Namaste~ |
#51 |
Drives: Attitude
More familiar with the turbo world where an aftermarket wideband is necessary for tuning. Still probably not a bad idea. Thanks for the knowledge.
#52 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
O2 sensor datalogs still read pump gas AFRs on E85, unless configured by the user somehow. Since the actual measurement is lambda, unless told otherwise, the software will multiply that by the stoich AFR for pump gas.
#53 | |
For example here is my logs from a pull: ![]() vs:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#54 | |
If you know the fuels lambda values and what scale you are calibrated for you can figure out what to target since all wide band sensors read in lambda.
~Namaste~ |
#55 |
Correct, see that attached from the engine controls manual. 12.16 is as low as it reads. It's not a true wideband but it is a wide range sensor. No need to be richer than 12.5 NA though.
~Namaste~ |
| The Following 2 Users Say Thank You to mad_sb For This Useful Post: | OrbitalEllipses (05-06-2013), vtmike (05-06-2013) |
#56 | |
[quote=vtmike;913109]
Your long term trims through the dip area are showing +10% so your wot AFR there is 10% richer than the fuel map calls for. They tapper off some as the rev's climb and you move into higher maf output areas. I hate long term trims on these cars, they are applied in open loop and will crush your tuned afr, or in this case the desired factory afr.
~Namaste~ |
| 86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
| Richmond va dyno | vtmike | Mid-Atlantic | 102 | 05-20-2013 10:18 PM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| TRD cat back, any dyno results | MTCRX | Engine, Exhaust, Transmission | 4 | 11-26-2012 06:26 PM |
| My Fr-s Dyno Results!! Surprising if you ask me | track_warrior | Engine, Exhaust, Transmission | 36 | 07-02-2012 10:15 PM |
