Old 04-15-2013, 01:22 PM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by FullBlown View Post
I'm hoping to ship next week. I would assume it will fit a RHD.
Are you shipping one to me? Should I call to order this week?
Old 04-15-2013, 03:27 PM   #30
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
@FullBlown,
did you add additional vents anywhere to let the air that goes through the cooler escape? It seems like once air gets in there it doesn't go anywhere easily.
Good work
F1point4 is offline   Reply With Quote
Old 04-15-2013, 04:44 PM   #31
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Chris, I will email you as soon as we get the final pieces. We will have enough to fill all orders
FullBlown is offline   Reply With Quote
Old 04-15-2013, 04:45 PM   #32
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by F1point4 View Post
@FullBlown,
Good work
There is enough flow behind it to escape. Only other option is to cut the splash guard, which I don't recommend.
Old 04-23-2013, 11:46 AM   #33
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Old 04-23-2013, 11:58 AM   #34
2forme
Any chance you could do a log of you flogging the turboed car with this kit to show the oil temps?
The Following User Says Thank You to 2forme For This Useful Post:
Chewie4299 (04-23-2013)
Old 04-23-2013, 12:06 PM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I already posted about my oil temps in the thread in the less inducted forum. I did a log for John last night and in 6 3rd gear pulls in 66F degree weather I hit 255F oil temps. I have hit as high as 280s just doing 3rd gear pulls. I can post a graph of the oil temps if you would like as well.
Old 04-23-2013, 12:07 PM   #36
2forme
Holy hell that's warm. Although I hit 250 in 50 degree weather myself... I wasn't flogging it...too much.
Old 05-05-2013, 09:27 PM   #37
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by Speedygonzales View Post
this is WITH the cooler right?
No. The oil cooler is not available yet. That is with the OEM oiling system.
Old 05-05-2013, 09:46 PM   #38
nix
nix's Avatar
Drives: AVO BRZ
Most FI cars are easily seeing 270+. Mine has hit 278 on track. The cusco water-oil cooler apparently has a 265 f thermostat which I thought was high.
I'm in market for a cooler atm, very keen to see before and after logs of oil temp with this kit. May be interested in testing it on my RHD car.
nix is offline   Reply With Quote
The Following 2 Users Say Thank You to nix For This Useful Post:
2forme (05-06-2013), Speedygonzales (05-05-2013)
Old 05-24-2013, 04:34 PM   #39
xman11
Drives: Brz, R53
Kit looks very robust.
How much drop in pressure can be expected from this kit? Any tips on compensating for reduced pressure?
Also, does it come with thermostat?
xman11 is offline   Reply With Quote
Old 05-24-2013, 04:41 PM   #40
dabocx
dabocx's Avatar
Drives: Scion FRS
278 in a third wheel pull? Was that multiple pulls in a row? In 66f degree wheather no less....
Oil cooler is pretty much maditory at that point.
dabocx is offline   Reply With Quote
Old 05-24-2013, 04:51 PM   #41
FullBlown
FullBlown's Avatar
Drives: Scion FRS
No problem with pressure drop. Cooler oil will actually increase in pressure. Yes, It does come with a thermostat.
The Following User Says Thank You to FullBlown For This Useful Post:
xman11 (05-26-2013)
Old 05-24-2013, 04:56 PM   #42
mashal
DADA
mashal's Avatar
Drives: 2013
damn I was buying stuff from another vendor before and now it seems like ill be sticking with you for a while.
mashal is offline   Reply With Quote
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
You want it, you got it: PERRIN Oil Cooler GB JoeBoxer Groupbuys 96 06-16-2013 03:10 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
