Old 05-03-2013, 12:06 PM   #5027
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by pheoxs View Post
I think what John is saying is, it does seem to work for most people, but no one knows why it works and if it'll keep working. It could work for a month straight then not and unfortunately that could mean a blown engine if someone is on the wrong map. So beware and always double check just incase.
Sent from my Nexus 4 using Tapatalk 2
That's why i opted not to use it. I would do it, then have to check to see if it worked. Why not just skip a step and set the map to start.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
Old 05-03-2013, 12:13 PM   #5028
Visconti
Drives: 05 STi
The problem is when people continue to talk about it like it's something reliable - when it's not.
-John
Visconti is offline
Old 05-03-2013, 06:27 PM   #5029
cuddefred
Drives: Black 86 GT
It's worked every time for me so far ... but I still check it just in case!!! It would be great if someone like Ecutek could fix it up to ensure it is fully reliable for us all.
cuddefred is offline
Old 05-03-2013, 07:50 PM   #5030
ICEBONEZ
ICEBONEZ's Avatar
Drives: '13 WRB 6MT BRZ Limited
-John
We use John for a reason guys. He's our tuner and telling us proper steps to enjoy our cars. I asked only to see where it was but when John says no then I'm waiting until he's ready. Thanks for all you do @Visconti
2013 BRZ Limited WRB
ICEBONEZ is offline
Old 05-03-2013, 08:05 PM   #5031
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Why I use the 3 pulls? Because it save me lot of time.
I open door same time I'm seating down I pull three time on the Start button, As soon as I'm seat down I press press clutch and press one more time to start engine and as I engage first gear I pull cruize control to double check it stayed on my E85 tune and then put seat belt on as I released clutch to move on.
Maybe I'm hyper active but I have no time to loose for seat down press two time then select E85 map then start engine. I'm already far by that time
Mars2 is offline
Old 05-05-2013, 07:16 PM   #5032
Nardi330
Nardi330's Avatar
Drives: 86
Just flashed my car on the weekend on STG1 pump gas map (only mod i have is Perrin panel drop in and Perrin header back). car seems to be fine and there are stronger pull from 2500rpm then hit the torque dip then pull strong again from 4000rpm.
however i seem to hear some knock sensor sound around 3000 - 4000rpm. is it normal or is it the DI sound? i don't think i heard this before flashing.......
would data logging capture this? ambient temp was around 22 degrees C (around 72 degrees F), water and engine oil temp were warm and normal.
thanks.
Nardi330 is offline
Old 05-05-2013, 07:18 PM   #5033
Opposed
Drives: 2013 Asphalt FR-S
however i seem to hear some knock sensor sound around 3000 - 4000rpm. is it normal? would data logging capture this?
thanks.
I thought the same thing too, but I think its intake sound. He recently revised a more aggressive cam timing map in that RPM range to help with more mid-range.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 05-05-2013, 07:25 PM   #5034
Nardi330
Nardi330's Avatar
Drives: 86
thanks for your reply. it's more like ta-ta-ta-ta sound so i doubt very much its intake sound. this sound is quite common with my previous rides on lower octane gas but i don't think i've ever heard this on my 86 before ecu flash.
Nardi330 is offline
Old 05-05-2013, 07:27 PM   #5035
Opposed
Oh, its a metallic sound for sure. Def have John look over the logs though just in case. Wait until you try E85
Opposed is offline
Old 05-05-2013, 07:35 PM   #5036
Nardi330
Nardi330's Avatar
Drives: 86
unfortunately can't do E85 as they are not common around where i live.
my best bet is to get a header.
Nardi330 is offline
Old 05-05-2013, 07:37 PM   #5037
Visconti
Drives: 05 STi
thanks.
It's my magical AVCS Timing map, the heart of my tune.. It's a good sound, nothing to worry about
John
Visconti is offline
Old 05-05-2013, 07:47 PM   #5038
welllam
Drives: STi
Can this sound be reduced by blocking the sound tube?
Sent from my GT-N7105 using Tapatalk 2
welllam is offline
Old 05-05-2013, 07:48 PM   #5039
Visconti
Drives: 05 STi
No idea ..
Visconti is offline
Old 05-05-2013, 09:54 PM   #5040
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Why wouldn't you want to hear that? I play with it all the time while punching it. Indeed a good sound.
Jeff86 is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
