Old 05-02-2013, 09:22 AM   #393
GotM
GotM's Avatar
Drives: 14 Porsche Cayman S
I have narrowed the noise down to the headliner right behind the driver seat. I have had the c-pillar covers off, and headliner pulled down on the rear side multiple times in the past several weeks. I have added foam to many areas in the headliner, around cables and connectors. And, have had no luck getting the sound to go away.
If I apply a slight pressure to the headliner behind the seat while it is rattling, it does go away.
I have checked the clamps on the airbag components, and they are all very tight.
My car is at the dealer for this right now...I gave up. They could not reproduce the sound yesterday...hopefully they get it to happen today. I happens for me every day.
The 2013 Forester loaner car they provided has a similar rattle, but it is even worse.
Previous cars:
2013 Subaru BRZ (2012-2017)
2009 BMW135 6MT (2009-2012)
1999 BMW M Roadster (2000-2010)
2004 Audi A6 2.7T (2004-2007)
GotM is offline   Reply With Quote
Old 05-02-2013, 12:35 PM   #394
Edwin88
Edwin88's Avatar
Drives: WR Blue M/T subaru BRZ
Works very good, the noise had gone completely, thanks man
Edwin88 is offline   Reply With Quote
The Following User Says Thank You to Edwin88 For This Useful Post:
Sigh-on-Rice (05-02-2013)
Old 05-04-2013, 11:51 AM   #395
31katys
31katys's Avatar
Drives: whiteout mt fr-s
Originally Posted by mr. slim View Post
So many TSBs coming out for this car. I still love it tho!
All cars have TSBs, especially the first model year.
31katys is offline   Reply With Quote
Old 05-04-2013, 07:43 PM   #396
tonytduc
tonytduc's Avatar
Try this, pull the headliner down in the rear like you did and you will see near the side airbag 3 10mm bolts. Tighten them down alittle bit more and the ticking noise should go away. 6 bolts total 3 on each side. Had the same problem and now FIXED!
tonytduc is offline   Reply With Quote
The Following 2 Users Say Thank You to tonytduc For This Useful Post:
dhuang (11-05-2017), GotM (05-05-2013)
Old 05-05-2013, 11:45 AM   #397
GotM
GotM's Avatar
Thanks. I will sends these details to the dealer...since they still have my car.
Previous cars:
Old 05-07-2013, 05:12 PM   #398
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Any thoughts on this buzzing noise at around 1400 rpm? (Ignore the image stabilization noise on the camera...forgot to turn that off for the video.) I don't think I had the noise until I installed the Perrin catback.
[ame]http://youtu.be/uowgMjO94X8[/ame]
Here's another short video without the image stabilization noise. There's just this buzz that's isolated around 1300-1400 rpm.
[ame]http://youtu.be/3UcA972FCuk[/ame]
Phaedrus29 is offline   Reply With Quote
Old 05-08-2013, 12:04 AM   #399
Nick L
Drives: FR-S Firestorm AT
Has anyone noticed a creaking noise coming from this area as well? I had the popping after getting my car back from the body shop, but it went away after a while.
However, after driving to Denver for my new job (almost 1800 miles - fun!), I've noticed that when there is a "twisting" force on the body (such as when I'm going up a driveway at an angle, for example) I can hear a creaking noise that seems to come from the same area that the popping did. Is it just that whatever was popping wore down enough to change the sound, or could it be something else? I might try the WD-40 trick to see if it goes away - if not I'll ask them to look at it when I get my oil changed.
Nick L is offline   Reply With Quote
Old 05-08-2013, 01:22 PM   #400
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Maybe you're talking about this noise?
I have that too and I'm using white lithium grease to get rid of that noise.
But it's only temporary. The noise comes back after a month or so.
I'll try WD40 next time to see if that lasts longer as rear deck noise is gone for 7 1/2 months now with WD40.
Old 05-09-2013, 11:42 PM   #401
GotM
GotM's Avatar
they found the rattle in my car. it has been gone for the last few days . It looks like they had to manipulate some of the pinch welds in the roof area close to the c-pillar.
Previous cars:
Old 05-11-2013, 05:46 PM   #402
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Mines booked in on Monday to have this looked at yay!.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 05-15-2013, 09:42 AM   #403
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
I got my car in February, and noticed this noise last week, in May. Found this thread, drenched the two areas inside the trunk with white lithium grease, and now i don't hear that noise anymore.
chenshuo is offline   Reply With Quote
The Following User Says Thank You to chenshuo For This Useful Post:
Sigh-on-Rice (05-15-2013)
Old 05-16-2013, 01:53 PM   #404
ollepellijeff
Thule Dude
ollepellijeff's Avatar
Drives: Scion FR-S
Got my car in February and had exactly this issue pop up after about a month and 2000 miles. Definitely a metallic 'click' sound like two parts snapping loose against each other, not dissimilar from the plastic bottle pop sound as some describe it.
Typically at low speeds when some bumps or irregularities int he road so that you torque the chassis. Folding down the rear seats and taking spare wheel and tools out of the trunk does not help. If anything it just makes you hear the noise louder.
Will bring it in to the Scion dealer tomorrow have them look at it since I don't have a garage to work in myself. I'll bring along the service bulletin and hopefully put them on the right track. Thanks for posting all the good info on this very annoying issue.
Edit after visiting the dealer:
They acknowledged the issue and said Toyota are working on a service bulletin. They will call me back for the official fix within a week or two they said. Will let you know if that fixes my issue.
Last edited by ollepellijeff; 05-17-2013 at 07:23 PM. Reason: After visiting the dealer
ollepellijeff is offline   Reply With Quote
The Following User Says Thank You to ollepellijeff For This Useful Post:
Sigh-on-Rice (05-16-2013)
Old 05-21-2013, 01:04 AM   #405
sastexan
Drives: '13 FR-S Ultramarine manual
I've tried twice. First time they did a spray like the Subaru TSB describes - worked for 2 days. Second time last week - dealer called Toyota and waited for a fix recommendation. They had the dealer insert felt pieces (called it a "noise cancelling kit" or something like that) - today the noise is back. Ugh.
'13 FR-S - Ultramarine manual
(GONE) '98.5 Contour SVT - modded (and threw rod with buyer)
'01 Camry 5S-FE (wife's old car)
'11 Odyssey EX-L - familymobile and hauler - food-encrusted carpets and other appropriate features
sastexan is offline   Reply With Quote
Old 05-21-2013, 10:34 AM   #406
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i think it's important what kind of grease you use. Some greasy will run off and you might hear the noise again. I use the WD-40 Specialist line of white lithium grease and i can see that the white stuff just stays there and doesn't run off. The WD-40 Specialist White lithium grease is significantly more expensive than other brands, but it's a good product. Give that a try. Just drench the two parts with this stuff. http://www.wd40specialist.com/produc...ithium-grease/
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
