Old 05-03-2013, 02:03 AM   #701
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Originally Posted by bakerr6 View Post
It's not e85
husker741 is offline   Reply With Quote
Old 05-03-2013, 06:59 AM   #702
CSI:86
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
100 RON FUEL/ 95 AKI
Does Unichip have tuning for 100RON / 95AKI fuel? Im from Australia and i fill up with 100RON.
CSI:86 is offline   Reply With Quote
Old 05-03-2013, 07:02 AM   #703
CSI:86
86 = First New Car
Originally Posted by xcelir8brz View Post
With the warmer weather and gripper tires on, and my current set up, I actually am in the consistent low 6's. With colder weather and different tires sometimes I would be in the high 5's.
The warmer weather definitely does something to this car moreso than any other I owned (outside of turbo).
Goddamn that fine... With an auto, and you getting high 5's? Thats very impressive
Old 05-03-2013, 09:34 AM   #704
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
It's not e85
Originally Posted by ScionFrsFan View Post
Haha man don't play with our hearts!!!
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 05-03-2013, 09:47 AM   #705
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Got a unichip that will work for CAI, Individa Front Catless Pipe, Perrin Overpipe, and Borla Catback Exhaust?
Chattanooga Scikotics MFIC
Red Robin Build
L3P47 is offline   Reply With Quote
Old 05-03-2013, 02:35 PM   #706
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
Thanks for the posts.
100 RON/95 AKI… if anybody runs higher than standard octane fuels (remember the 5-ish point variance between rating systems) I’d use the standard premium map for your Main Map Set (92 F~T~ ) and a more aggressive reduced fuel/increased timing map for Map 2 (92 F-T+ is the most aggressive).
L3P47… what sort of intake are you using?
Cheers
Unichip Jack is offline   Reply With Quote
Old 05-03-2013, 02:49 PM   #707
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Threw a cel with my map. Best map now???
I threw a CEL yesterday with the map I was running.... standard timing, 91 octane, drop in filter, all headers, all cat-back. I took out the Unichip and went to the dealer. They said it was reading way too rich. (I suppose it would without the Unichip on top of things.)
I have been running a drop-in filter, header-back exhaust (front pipe without the 2nd cat) and Perrin intake hose... and this map seemed to perform well until the CEL.
So... called Unichip today and talked with Arron (very helpful man) who said to use the same map I was before but pick the 87 octane.
Does this sound right? Or, should I be using another map?
Thanks for the help.
Mark
mtimney is offline   Reply With Quote
Old 05-03-2013, 02:51 PM   #708
L3P47
L3P47's Avatar
Cheers
Vigilant Motorsports
Sent from my DROID BIONIC using Tapatalk 2
Red Robin Build
Old 05-03-2013, 06:57 PM   #709
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Mark
Just wondering but why are you running the all header map when you dont have aftermarket headers?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 05-03-2013, 07:12 PM   #710
mtimney
mtimney's Avatar
Why all header-back?
That's what Unichip suggested I run when I sought support to operate the mapping software. I wondered about that too.
Given my setup--- drop-in filter, header-back exhaust (front pipe without the 2nd cat) and Perrin intake hose ----what would you run?
Mark
Old 05-03-2013, 07:23 PM   #711
husker741
Mark
Headerback means your exhaust is from the header, back. So you have an overpipe, front pipe, midpipe, and muffler. That does not mean you have headers. So you should only run the drop-in, all cat-back map with whatever octane and timing/fuel you choose. Do not use the all-headers map.
Old 05-03-2013, 07:39 PM   #712
l0aded
Addicted
l0aded's Avatar
Mark
Pretty much what Husker said. all catback might fit the profile better. Adding headers makes a pretty big difference.
Old 05-03-2013, 07:49 PM   #713
xcelir8brz
I disagree. Header back does not assume you swapped headers. It means after the header on back all stock pipes replaced. Run all headers with premium base of t and f and second of premium t+ f-. Pull cable on battery and then run for a day and drive around. Between the ECU and Unichip both will learn and be all good.
xcelir8brz is offline   Reply With Quote
Old 05-03-2013, 08:02 PM   #714
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Why would you run a map made for a car with headers if you didn't have headers?
SubieNate is offline   Reply With Quote
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
